Old Jan 06, 2006, 09:31 PM
slowracing is offline
Find More Posts by slowracing
Build...Crash...Build...
slowracing's Avatar
Williamsburg, Virginia
Joined Apr 2005
Help!
T6XAsuper DLG flap control via throttle stick (channel 3) help needed
I have a Spinner XT I have setup on my Futaba T6XAsuper radio. I want to control the flaps with the throttle stick.
Here is my setup so far.
Channel layout:
Elevator CH-2
Flaperon (right wing) CH-1
Flaperon (left wing) CH-6
Rudder CH-4
FLPR (Flaperon mixing) is ON
6->2 Flap->Elevator mixing is ON
Note: Flaps are controlled by the flap trim knob. Everything works as it should.
Here is what Ive tried.
PMX1 ON with CH-3 as the master and CH-6 as the slave. This works sort of!?!? When the throttle in moved only the flap on the left wing moves. The flap moves to about half throttle in one direction then moves the other way at full throttle.
Can this radio be setup to do what I want (full flaps when the throttle is fully extended)?
If so how?
slowracing is offline Find More Posts by slowracing
Old Jan 09, 2006, 11:35 AM
Tfour2 is offline
Find More Posts by Tfour2
Southwest Ohio USA
Joined Sep 2002
I don't think the 6XAS will do what you want.
The channel 3 on the PMIX works like a center-stick channel so you might have to mess with the subtrims and EPAs to make it sorta linear.
There is no "link" function on the 6XAS PMIX so you would need 2 PMIX's, one assigned to each flaperon, to make the ailerons act like flaps.
Since I believe there is only 2 PMIX's available that leaves you one short, even if you could work out the throttle non-linearity issue.
Sorry,
Buzz
On second thought maybe you can set PMIX1 ch3 to ch1 and PMIX2 ch3 to ch6 and fiddle with the sub trims and EPAs and work something out. I don't have a flaperon a/c set up at the moment or I would try.
Tfour2 is offline Find More Posts by Tfour2
Discussion Rudder servo control on (left)throttle stick -vs- rudder control on (right)stick. chewbaca Electric Plane Talk 17 Feb 01, 2006 08:16 PM
'throttle' stick for camber control? Arbo Hitec/Multiplex USA 4 Oct 14, 2005 06:03 PM
Airtronics RD6000 - Flap on throttle stick blewis01 Radios 4 Jun 24, 2005 08:49 PM
Do any positive-shift 72 MHz transmitters put the throttle signal out on channel 3? BEC Radios 17 Sep 18, 2004 12:36 AM
Need help programming throttle stick for both throttle & spoilers pik20 Electric Sailplanes 0 Jul 12, 2002 12:48 PM
