Old Jan 06, 2006, 09:42 AM
RedTeam is offline
Find More Posts by RedTeam
Joined Jan 2006
Changing the electronics in a Gen.1 xmod
Hi guys, I’m quite experienced in R/C 1/10 on-road class but recently my brother gave me his 2 xmods Gen1 cars, and I want to replace the stock transmitter and electronics on board with more appropriate ones. And since I’m new in xmods, I might have few topics to rise.
If the space it’s limited I want to save as much space as I can, therefore I was thinking to use a 2 in 1 unit – receiver + speed control but I don’t know the brand, and I never used such unit. Any of you used such component? If so, could you give me your feedback, please !
Here it’s the unit :
TP-RM6R(FORWARD AND REVERSE)
Receiver Plus Speed Controller Two In One R/C System -27AM
http://www.rcmart.com/catalog/produc...ducts_id=11780
SPECIFICATIONS:
SPEED CONTROLLER
*Operating voltage: 6V-9.6V (5-8 Cells)
*Maximum pulse current: 160A (Forward)
*Maximum continuous current: 75A (Forward)
*Int. resistance ohms: 0.008x2
*weight: 50g
*Dimensions: 59x31x18.5(mm)
RECEIVER
*Type: Single Conversion AM
*IF: 455kc
FEATURES:
*Consists of receiver and speed controller
*Forward and reverse
*Neutral & full power adjustment
*Battey elimination circuitry
*Built-in pulse checker
*Mos fet circuit
What about servos: what should I choose: Hitec HS 50 ( well-known servo, but a bit to big for such scale, although many of you are using it ) or less known brands – for me at least – servos ( but smaller size ), like :
Blue Bird 3g Ultra Micro Servo
http://www.rcmart.com/catalog/produc...ducts_id=16071
• Weight: 3.4g / 0.13oz no wire
• Size(mm): 19 x 7.5 x 15.5 mm / Size ( inch ): 0.75 x 0.29 x 0.61 inch
• Speed: 0.11sec / 60 deg at 4.8V
• Torque: 0.7kg/cm , 11 oz/in at 4.8V
• Motor type: coreless motor!!!
• Ball bearing: none
Or: Saturn S44D Electron Digital
http://www.ripmax.com/item.asp?itemid=P-SAT44D
Torque (Kg/cm) 1.0 (4.8v) 1.25 (6.0v)
Speed0.12s/60deg (4.8V) 1.25s/60deg (6.0V)
Weight: 4.4g
Or: SERVO FS-30 PICO
http://at.robbe-online.net/rims_at.s...1c3e0dc14605e5
Dimensions: 20x8x17.6 mm
Mass/weight: 5.50 pond/g
Operating voltage: 4.8 Volts
Nominal voltage: 4.80 Volts
Torque: 9.00 Ncm
Transit speed: 0.10 Sec/45°
Thanks for your info !
RedTeam is offline Find More Posts by RedTeam
Old Jan 06, 2006, 11:36 AM
Rusted is offline
Find More Posts by Rusted
Wheres my money gone?
Rusted's Avatar
Colwyn Bay North Wales
Joined Apr 2005
NO!!!! dont get it!!! two in one units are crap!!! trust me i have had nothing but crap out of mine!!! go for micro electronics but both of them seperate.
Rusted is offline Find More Posts by Rusted
Old Jan 06, 2006, 02:28 PM
TueLe is offline
Find More Posts by TueLe
United States
Joined Dec 2004
Mini-Z cars use a similar circuit boad consists of a receiver and a esc, have u look at it?
TueLe is offline Find More Posts by TueLe
Old Jan 07, 2006, 04:53 AM
RedTeam is offline
Joined Jan 2006
Thanks, I I'll keep U updated with my project !
Old Jan 21, 2006, 08:59 AM
Dog Boy Dave is offline
Find More Posts by Dog Boy Dave
Joined Jan 2006
Hello Red Team,
There is a forum. MiniZracer.com that discuses these issues adnausium. I beleive you will find that it isnt cost effective at all to do the modifications you are considering. Now if you are doing it just for the love of the challange you might consider picking up a miniZ MR01 on Ebay. They have been replaced by the 02 and they go for about 40 bucks with transmitter and reciever. Anotehr source for the x mods is Atomicmods.com. There is another 1/28 car out ther the I waver that also has a board that would fit. Problem is the Mini Z are so good that there is no reason other than cost to go withthe other competitors. Unless you are just driven to take an inferior product and modify it to beat the better one. I have both and the Mini Z's handle like butter. Both designs have gobs of mod parts though and they are a blast to drive. Even better you can do it inside the house...all year
DBD
Dog Boy Dave is offline Find More Posts by Dog Boy Dave
Question Dragonfly-changing 3 in 1 mixer grahammau Micro Helis 6 Nov 13, 2004 04:25 PM
Wore out a 300 in 5 1/2 hours?? Basketcase Parkflyers 77 Mar 11, 2003 11:33 PM
How to de-skin bluecor foam in <1 min/side AndrewsJr Foamies (Kits) 12 Apr 16, 2002 04:03 PM
Problems changing xtal in Futaba 9Cxx AndrewsJr Electric Heli Talk 11 Jan 10, 2002 04:24 PM
Wattage B-2/N-20/China 8710 type motors at Tanner Electronics in Dallas? Thomas B Parkflyers 23 Nov 16, 2001 09:08 AM
