Old Jan 06, 2006, 01:51 AM
StephanB is offline
Find More Posts by StephanB
Restricted User
StephanB's Avatar
Frankfurt-region, Germany
Joined Mar 2003
Video is working now.
Stephan
StephanB is offline Find More Posts by StephanB
Old Jan 06, 2006, 02:33 AM
Darkdevil_725 is offline
Find More Posts by Darkdevil_725
Joined Nov 2005
add some starwars music to the beginnings credits lol the planes flys nicely who was that with the chopper in the background.
Darkdevil_725 is offline Find More Posts by Darkdevil_725
Old Jan 06, 2006, 09:24 AM
Vifo is offline
Find More Posts by Vifo
Singapore
Joined Jan 2005
Detachable Wing Conversion Plane
Hi Stephan,
Yes, your video is working, flies gracefully well.
When you fix the motor to the front, do you cross over the Motor and reverse the propellor?
Vifo is offline Find More Posts by Vifo
Old Jan 06, 2006, 09:34 AM
wrapperworm is offline
Find More Posts by wrapperworm
Joined Dec 2005
wot glue sud i use to stick my plane back together???
wrapperworm is offline Find More Posts by wrapperworm
Old Jan 06, 2006, 09:41 AM
troyboy162 is offline
Find More Posts by troyboy162
Joined Dec 2005
its got to be that 3m adhesive (77 or 68 ones bad not sure witch) that is mentioned in all the foam posts because its definaly not normal glue in there and it would be nice to alway be able to pry open your plane to fix things
troyboy162 is offline Find More Posts by troyboy162
Old Jan 06, 2006, 10:13 AM
StephanB is offline
Restricted User
StephanB's Avatar
Joined Mar 2003
Originally Posted by Vifo
Hi Stephan,
Vifo,
you have to cross the cables and to turn around the prop.
cable: black to white and white to black, blue to red and red to blue for the other side. It is less noisy than a pusher with slots in the wing and i wanted a puller after all these pushers.
Thanks for nice comment on video.
Stephan
Old Jan 07, 2006, 01:43 PM
Joined Dec 2005
heya,
whay ohms are the motors? i think there 10 i just need to be sure,
Old Jan 07, 2006, 02:52 PM
defranci is offline
Find More Posts by defranci
Central Ohio
Joined Feb 2003
heya,
It's been posted that they are 5.3 ohm. Don't have a link to the exact post. It's back in part 1 somewhere.
Don
defranci is offline Find More Posts by defranci
Old Jan 07, 2006, 07:00 PM
micro_builder is offline
Find More Posts by micro_builder
micro_builder's Avatar
United States, MN, Corcoran
Joined Jan 2005
you can switch from a pusher to a puller without resoldering the wires. all you have to do is take the left and right props, flip them over, and put them on the other motor (left prop flipped over and put on right motor. right prop flipped over and put on left motor).
double sided tape can be used to put the plane back together. it'll allow you to take it back apart if you need to sometime down the road. and Don is right, the motors are 5.3ohm 6mm's. 6ohm-10ohm motors could be used for replacements.
nick
micro_builder is offline Find More Posts by micro_builder
Old Jan 07, 2006, 08:10 PM
Hotflyer is offline
Find More Posts by Hotflyer
Joined Apr 2005
so i just got an xufo and I was wondering how to control my aero ace with the tx. do I need to take the crystal out of the aero ace tx and put it in the ufo tx?
Hotflyer is offline Find More Posts by Hotflyer
Old Jan 07, 2006, 09:14 PM
Hotflyer is offline
Joined Apr 2005
while waiting for the ufo to charge, I did the Tx diode mod (jumping those two pads to P11) IT WORKED GREAT!!!! Waaaaay easier than doing the hardwire job. (no offence nitrocharged, both mods do the same thing, this one just uses the existing tx connections.) anyway, I am so pleased and impressed that there are so many smart people here sharing information about how to make good things better. Thanks a lot, all of you.
Old Jan 07, 2006, 11:06 PM
lobopac is offline
Find More Posts by lobopac
Joined Jan 2006
broken wires
hi all. first post......only due to a problem.
i picked up my first rc plane and had a wonderful 20 flights or so before the wires on the right wing motor broke off. too many head ons with the trees and street caused the motor to start falling off. no big deal, i just reattach it and off it goes.
is it possible to solder the wires back on, or possible to open up the motor to reattach them somehow? i have zero modding, or electronics experience....so please keep that in mind.
the motor still works if i touch the broken wires together with the throttle on. please help if you can, if not...i have some parts for mods and i'll definatly pick another one of these fun little planes up.
lobopac is offline Find More Posts by lobopac
Old Jan 07, 2006, 11:07 PM
Joined Dec 2005
two questions about normal aeroace behavior
1. i though these planes kept flying when they ran out or range of the tx? this one just shuts off
2. when the battery is running low this one it just shuts off. is that normal?
Old Jan 08, 2006, 07:23 AM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
http://www.rcgroups.com/forums/showp...3&postcount=94
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Jan 08, 2006, 07:24 AM
quax is offline
Find More Posts by quax
quax's Avatar
NRW, Germany
Joined Apr 2004
Hotflyer,
There's no need to change the crystal of the xufo tx. But have to do some modifications. Here you can find the "how to":
http://home.versanet.de/~b-konze/xtw...ufo_mod_en.htm
Quax
quax is offline Find More Posts by quax
Stevens Aero Appreciation Thread - Show Off Your Models!!! (Part 2) doc-e Parkflyers 1109 Apr 26, 2016 10:52 PM
Discussion X-Twin, Aeroace - post your mods - part 3 osmium_192 Micro Ready-to-Fly 4345 Dec 22, 2014 09:41 AM
Discussion PiccoZ, GyRotor - post your mods - part 1 MegaTesla Micro Ready-to-Fly 1800 Dec 19, 2009 09:04 AM
Post Your X-Twin Aeroace pics & vids here Darkdevil_725 Scratchbuilt Indoor and Micro Models 2 Nov 16, 2009 07:45 AM
Discussion X-Twin, Aeroace - post your mods, links etc. epilot Micro Ready-to-Fly 1011 Jan 05, 2006 03:49 AM
