Old Jan 02, 2006, 07:16 PM
fatboy is offline
Find More Posts by fatboy
fatboy's Avatar
Joined Aug 2003
Blade CP2 - Tx Probs, servo probs
OK, it's been a week of practice for 3 of us on one Blade. Hovering in the garage, learned to slow down bigtime w/the learning curve.
Here's what we notice...
Barely touch the "elevator" stick and the servo jumps and jitters up and down. Applied slight pressure on the PC board attached to the "elevator" pot on the TX and it disappears, for a few flights.
Applying full up "elevator" there is a jump in the throw as if there is a gear binding in the servo (in normal flight we never go there...yet).
Sorry for the lack of knowledge in terminology of the surfaces, hope you get the idea.
Anyone else experiencing this???
I'm 99% convinced this needs to go in for service.
AARRRRGGG. Just about the time we figure out all kinds of wonderful stuff (balance, throws, tweaking here there and everywhere), we spot disturbing problems.
Thanks for your input.
fatboy is offline Find More Posts by fatboy
Old Jan 03, 2006, 01:12 AM
sting17 is offline
Find More Posts by sting17
Fort Worth, Texas
Joined Aug 2004
Bump ...
sting17 is offline Find More Posts by sting17
Old Jan 03, 2006, 01:41 AM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
I don't have a Blade CP, but this sounds like a potentiometer problem.
If you look at a transmitter joystick, there are two electronic devices mounted in the gimbals of the joystick, with either two or three wires going to each device. These devices are called potentiometers, or sometimes rheosats.
These are basically sensors that detect the rotational position of the gimbal. They are basically variable resistors where the resistance of the device is equal to the rotational position of the gimbal.
There are basically two types of construction used for potentiometers.
The first type of potentiometer is a wirewound potentiometer. In this type of device, there is a torus with many turns of high-resistance wire wound through the center of the torus. (Not the way women wrap hair around a hair curler...but through the center of the torus for each turn of wire). There is a rotating wiper arm which touches the wire, and the insulation is scraped bare at the touch point so electricity can be conducted. The resistance of the unit is directly proportional to the rotational position of the shaft attached to the wiper arm because the wiper arm makes contact at the wire at a farther distance depending on the shaft rotation.
This type of wirewound potentiometer is of good quality and is very reliable.
The other type of potentiometer is a carbon composite potentiometer. Instead of using a torus with loops of wire wrapped around it, this type of potentiometer uses a partial torus of high-resistance carbon composite material. The wiper arm rotates along the carbon composite material and the resistance is directly proportional to the shaft position, as in the wirewound potentiometer.
The carbon composite type potentiometer is of lower qualtiy and less reliable than the wirewound potentiometer for the following reason: as the wiper arm rotates along the carbon composite material, it scrapes off material and builds up "gunk" which makes the potentiometer jittery and unreliable.
Since the Blade CP is rather a cheap helicopter, I suspect the transmitter uses low-quality carbon composite potentiometers rather than high-quality wirewound potentiometers. If this is true, then there are at least three solutions to this problem which I can think of offhand:
1. The cheap solution is to squirt contact cleaner into the potentiometer periodically to clean out the gunk. Contact cleaner is available at most electronics shops such as Radio Shack:
http://www.radioshack.com/product/in...entPage=search
The contact cleaner can should have directions printed on it, but if it doesn't, you should squirt a quick burst of contact cleaner into the potentiometer, then move the joystick back and forth several times to clean off the wiper. You may need to repeat this process a few times for best effect.
2. A better but more expensive solution is to replace the carbon composite potentiometers in the joystick gimbals with wirewound equivalents. This would require sourcing a wirewound potentiometer with the equivalent resistance range and physical dimensions of the stock potentiometers. Electronics supply houses such as Digi-key would be the best source for such replacements.
3. Probably the best solution is to replace the transmitter with somethiing decent, such as a JR/Futaba/Hitec/Multiplex transmitter. As far as I know, all these transmitter manufacturers use good quality potentiometers that do not have jitter problems.
Toshi
TMorita is offline Find More Posts by TMorita
Old Jan 03, 2006, 02:09 AM
TMorita is offline
Joined May 2002
I forgot to mention the wirewound potentiometers generally cost more becuase the manufacturing process is more complicated.
For a carbon composite potentiometer, the resistance element is molded in a machine, which is very simple, very fast, and very cheap.
For a wirewound potentiometer, the reistance element requires a few hundred or more turns of wire be wrapped very neatly and precisely around a torus. This is a more complicated process which results in a more expensive product, albeit of much higher quality.
Toshi
Old Jan 03, 2006, 08:12 AM
FenceMagnet is offline
Find More Posts by FenceMagnet
Vintage Flyer
Treasure Island, FL
Joined Jan 2002
As all early Kraft and Heathkit RC owners know, wirewound pots in RC transmitters were abandoned about 30 years ago... why? if it fails, it's catastrophic.... the channel goes to the extreme throw.... if a composition potentiometer fails, it's usually a case of "noise", as noted above, and one can "usually" still get the model down....
PS.... I work for a company that makes both kinds... one of the few survivors
FenceMagnet is offline Find More Posts by FenceMagnet
Old Jan 03, 2006, 07:01 PM
TMorita is offline
Joined May 2002
Then I guess the better-quality transmitters just use better-quality composite potentiometers where the material doesn't gunk up the wiper?
Toshi
Old Jan 03, 2006, 07:42 PM
Crewdogg998 is offline
Find More Posts by Crewdogg998
Crewdogg998's Avatar
Battle Creek Mi
Joined Jan 2005
Toshi, sometimes you impress the hell out of me. Thanks for the wisdom, its' nice to know how things work. Regards, Crewdogg
Crewdogg998 is offline Find More Posts by Crewdogg998
Old Jan 03, 2006, 08:35 PM
Ah Clem is offline
Find More Posts by Ah Clem
Team Compass/KBDD Team Pilot
Ah Clem's Avatar
Joined Mar 2005
Fatboy,
I would contact EFlite and let them know about the problems with your transmitter. Although I have not had to use it yet, their support is known to be excellent.
Ah Clem is offline Find More Posts by Ah Clem
Old Jan 04, 2006, 09:10 AM
Vintage Flyer
Treasure Island, FL
Joined Jan 2002
"Then I guess the better-quality transmitters just use better-quality composite potentiometers where the material doesn't gunk up the wiper?"
yes.... the cheapy Noble pots are screened carbon material, and a bit soft... the better pots, like CTS or Spectrol or Bourns (all mid-quality BTW) are molded carbon... quite a bit harder and more durable...
wiper design is a whole 'nother ballgame...
Sim Cable for Blade CP Tx (E-flite) Jersey-Joe Micro Helis 6 Oct 22, 2008 09:19 AM
Discussion Servo Reverse Setting CP2 (TX) blade strike Micro Helis 3 Feb 26, 2006 10:23 PM
Question JR 347 TX, 4-Servo DLG, and Channel 1 Question marctrudeau Hand Launch 2 Mar 01, 2005 05:52 AM
FS: HPI TX, RX, and servo from RTR Sprint CH6 soulys Cars - Cars and Parts (FS/W) 1 Jan 13, 2005 04:38 PM
New/usd Airtronics/Hitec Tx,Rx, Servo eBay Roger_One Aircraft - Fuel - Airplanes (FS/W) 0 Mar 16, 2003 02:29 PM
