Old Jan 02, 2006, 06:47 PM
U.S.U.L is offline
Find More Posts by U.S.U.L
diy heli maker
U.S.U.L's Avatar
Poland
Joined Sep 2004
Build Log
Building my own DIY submicro heli
Hi all
It's my first post here
As mentioned in title. I loved to watch pixel(by alexander van de Rostyne) heli series and all your work here.
I'm so excited about building my own bugger. Cant wait to fly it over my room.
I plan to use:
-"200" brushed motor
-5A esc
-8g tailmotor
-GWS 5.4g servos
-4g receiver
-3s 360mAh lipo pack
This is what i made so far.
Oh, and wish me luck
U.S.U.L is offline Find More Posts by U.S.U.L
Old Jan 03, 2006, 07:49 AM
U.S.U.L is offline
diy heli maker
U.S.U.L's Avatar
Poland
Joined Sep 2004
Ok, swashplate is ready. 5mm ball inside bearing, upper and lower plate from plywood. Motor and gear on its place too.
So, take a look and tell what do you think about it, please
I'll need some support and motivation from you
Old Jan 03, 2006, 10:25 AM
Rooney7783 is offline
Find More Posts by Rooney7783
All Thumbs
Rooney7783's Avatar
College Station Texas, Home of the Fightin Texas Aggies
Joined Dec 2005
Wow, got me thinking about building one of these little guys once I have gotten the hang of my NR3D. I'm impressed with the wood work, but (pardon me if this is a dumb question) will it hold up to the rotational forces created by these things?
Rooney7783 is offline Find More Posts by Rooney7783
Old Jan 03, 2006, 10:38 AM
U.S.U.L is offline
diy heli maker
U.S.U.L's Avatar
Poland
Joined Sep 2004
Yes it will. Plywood constructions are very rigid. Beside that i reinforced it with CA and tested with blades on under 2000rpm. In fact rotor and head are very stable. I'm thinking of adding some weights on paddles to increase stability.
Old Jan 03, 2006, 05:40 PM
Rad Racer is offline
Find More Posts by Rad Racer
Hi Wattage Electrics - Cool
Rad Racer's Avatar
Jordan, Minnesota
Joined Jan 2004
Interesting blades, are they made completely from balsa? If so, do you plan to add re-enforcement to the hub area?
Rad Racer is offline Find More Posts by Rad Racer
Old Jan 03, 2006, 07:52 PM
U.S.U.L is offline
diy heli maker
U.S.U.L's Avatar
Poland
Joined Sep 2004
Blades are completetly from balsa with little plywood mounts for screws. I think i'll cover them using some solarfilm and eventually add some weights.
Old Jan 03, 2006, 09:09 PM
seravios is offline
Find More Posts by seravios
seravios's Avatar
Joined Oct 2005
increasing the weight on the paddles,will it increase the stress on the rotor hub?
seravios is offline Find More Posts by seravios
Old Jan 04, 2006, 04:39 AM
U.S.U.L is offline
diy heli maker
U.S.U.L's Avatar
Poland
Joined Sep 2004
Ofcourse it will but it doesnt matter, this little rotorhead is very strong and rigid. I'm safe until the forces will pull it exactly contrary, otherwise i'll end with vibrations.
Old Jan 04, 2006, 08:14 AM
U.S.U.L is offline
diy heli maker
U.S.U.L's Avatar
Poland
Joined Sep 2004
Servos and all links with mixers installed. I decided to use mechanical mixing because of proper cg. Now almost everything is done and i'm waiting for kokams, esc's and maybe gyro(ikarus micro-gyro).
Hmmm, i can't still find anything that would match as canopy...
Old Jan 04, 2006, 10:49 AM
glxy is offline
Find More Posts by glxy
4-D traveller
glxy's Avatar
New Location
Joined Dec 2003
Good work! You have the simplest chassis I've ever seen. The way your servos are mounted is new. But your brushed main motor could be too weak for the heli. Why not go brushless?
glxy is offline Find More Posts by glxy
Old Jan 04, 2006, 02:09 PM
U.S.U.L is offline
diy heli maker
U.S.U.L's Avatar
Poland
Joined Sep 2004
It's simple and does its work well enouht. Did some thrust tests and everything is ok. It seems it will hang it in the air well. I don't like the concept of big powerfull motors with short blades, heavy equipment and high head speeds. I'd like to see nice, light, simpe and quiet bird floating in my room
Old Jan 04, 2006, 02:18 PM
U.S.U.L is offline
diy heli maker
U.S.U.L's Avatar
Poland
Joined Sep 2004
Guess what i'm using as ball links...pins with round heads. Works well too.
Old Jan 04, 2006, 02:50 PM
All Thumbs
Rooney7783's Avatar
Joined Dec 2005
Let's see a vid of it in action when ya get the chance.
Old Jan 04, 2006, 02:59 PM
U.S.U.L is offline
diy heli maker
U.S.U.L's Avatar
Poland
Joined Sep 2004
You got it
Old Jan 08, 2006, 04:13 PM
U.S.U.L is offline
diy heli maker
U.S.U.L's Avatar
Poland
Joined Sep 2004
Oups, i made a mistake in the begining. It's not "200" motor but FK-050SH, so i shouldn't have any problems with lifting her up
I'm still waiting for kokams and esc's.
By the way, how can you compare 050 to IPS? I know both weight about the same(15,16g) how about power, current, lifetime and efficiency?
Building my own EPP flying wing soholingo The Builders Workshop 4 Apr 29, 2004 12:50 AM
building my own...thing that i think can fly =) ReasonSwe Electric Plane Talk 6 Apr 20, 2004 06:01 PM
Scratch Building My Own Bird Dog Rogerdoger Parkflyers 78 Feb 03, 2004 01:47 PM
thinking of building my own newtonian telescope logan5 Life, The Universe, and Politics 23 Aug 29, 2003 10:55 PM
Building my own NIMH packs? JayParke Power Systems 5 Oct 17, 2001 10:18 PM
