Old Jan 02, 2006, 11:45 AM
chewbaca is offline
Find More Posts by chewbaca
Joined Nov 2005
Aileron Rudder Mixing fo 1st time 3d flyer
My son is experienced Slow Stick pilot. He now about to take maiden flight with Typhoon 3D with ailerons and I am wondering if we should mix the ailerons with the rudder? Radio is JRXP6102.
chewbaca is offline Find More Posts by chewbaca
Old Jan 02, 2006, 01:02 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
It's probably better to not do the mixing until he gets some experience with the airplane's characteristics.
Using rudder as rudder is a learning experience all by itself.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jan 02, 2006, 02:02 PM
flyingflipper is offline
Find More Posts by flyingflipper
flyingflipper's Avatar
Joined Sep 2004
I have a Typhoon and have the option of mixing on an unused switch on my Optic 6. You can do the same on your JR radio as well.
Having the option at any time was helpful in learning how to make coordinated turns. I would try a figure 8 with mixing and then without. I could see how the airplane tracked with proper rudder input with it mixed and then attempted to maintain the same pattern without it.
Nothing helps someone learn faster than instant feedback. As he progresses, you can cut the percentage of mixing back requiring manual rudder control to coordinate the turn.
Everyone learns differently - I hope this tip will be of help.
flyingflipper is offline Find More Posts by flyingflipper
Old Jan 02, 2006, 04:29 PM
Joined Sep 2004
I forgot to mention that I add +40% rudder mixing to start. It also would be wise to factor in some exponential value as well.
Old Jan 03, 2006, 07:38 PM
Popsflyer is offline
Find More Posts by Popsflyer
Oldie but goodie
Popsflyer's Avatar
United States, CA, Orange
Joined Jun 2003
Most of my 4CH planes (including my 3D) use some sort of opposite rudder mixing to keep the nose from dropping when banking, as my fingers are not proficient enough to do it manually.
Popsflyer is offline Find More Posts by Popsflyer
Aileron/Rudder mixing help KDB@KAM Electric Plane Talk 4 Mar 18, 2003 11:11 PM
Question about aileron/rudder mixing ChodeMan Parkflyers 17 Mar 02, 2003 11:45 AM
Aileron/Rudder mixing? nikko Radios 4 Dec 10, 2002 09:29 AM
Aileron / Rudder mixing ques? me11owman Electric Sailplanes 5 Dec 30, 2001 07:13 PM
