Old Jan 03, 2006, 02:33 AM
Snoopy66 is offline
Find More Posts by Snoopy66
Snoopy66's Avatar
Adelaide, South Australia
Joined Oct 2005
I have two aircraft. One with just rudder and elevator and one with ailerons as well.
When using the rudder/elevator plane we use only the left stick... rudder and elevator. When we switch to the aileron plane we use the left stick for aileron and elevator and shift the rudder to the right stick with the throttle and barely touch it.
Snoopy66 is offline Find More Posts by Snoopy66
Old Feb 01, 2006, 07:26 PM
EFlyBoy58 is offline
Find More Posts by EFlyBoy58
BackInTheHobby
Toronto
Joined Jan 2006
I hear the expression "Mode 1" or "Mode 2" or whatever. Maybe someone would kindly explain what is what.
I learned to fly on a glider with elevator & rudder on the right stick (Mode ?). Years later I got into e-flight with elevator & rudder on the right stick & throttle on the left (Mode ??)
Now I have just bought a Tiger Moth and will be putting the ailerons on the right stick with elevator. Rudder & motor will be on the left stick (Mode ???).
I think there is at least one other choice of Mode.........????
This forum is a huge help to me as a relative Noob to e-flight. Thanks everyone
Regards, Rod
EFlyBoy58 is offline Find More Posts by EFlyBoy58
Old Feb 01, 2006, 08:16 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Mode 2... aileron and elevator on the right stick.
rudder and throttle on the left stick.
Most people use this configuration.
Note it makes your airplane flyable by someone else..
And you can fly someone else's plane without re-training your skills.
Sparky Paul is offline Find More Posts by Sparky Paul
'throttle' stick for camber control? Arbo Hitec/Multiplex USA 4 Oct 14, 2005 06:03 PM
b-29 - rudder control on a 2-channel? abdulf Beginner Training Area (Aircraft-Electric) 3 Nov 19, 2004 06:01 PM
Ailerons on left stick, rudder on right. Solcat Radios 4 Jul 05, 2004 12:14 PM
Converting Bit Charge tx to stick type rudder control Graham Smith Scratchbuilt Indoor and Micro Models 13 Nov 13, 2003 07:09 PM
Rudder and throttle on left control stick on Pico Stik xadmin Foamies (Kits) 5 Dec 16, 2001 07:15 PM
