Old Jan 01, 2006, 09:08 AM
seismic is offline
Find More Posts by seismic
Seismic
seismic's Avatar
Turkish Republic
Joined Feb 2004
new 11.1V 1200mAh 10C Li-Po doesnt charge shows 8 Volt
Hi,
i searched a post like my problem but i couldnt find.
I purchased new lipo. First charge was wonderful, it's charge was 11.1 volt and my Slow Stick flied like a bird but my next flight (first fly wasnt to long 4-5 minutes) motor didnt start it was working but too slow, after that i want to learn my lipo battery's volt and I measured it, it was 8 volt so i tried to charge it, (i have a hobbico field charger) but charger didnt charge it, at 8 volt charger suddenly stoped (this means battery is full), i dont understand the problem, i couldnt charge it, i used a old motor to finish battery energy, now it's 4 volt and charger stop at 4 volt.
i have a same problem with my old lipo, after a crash it wasnt charged full but this lipo is new and i couldnt resolve problem.
seismic is offline Find More Posts by seismic
Old Jan 01, 2006, 09:21 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
You over discharged the LiPoly. At the end of a flight the voltage nust be atleast 10.5 volts and really should be 11.1-11.4 if you want the battery to last a long time.
A fully charged 3S LiuPoly is 12.6 volts and the normal charged range is 12.40 --12.48 .
You need to be using an ESC with a LVC which is LiPolys safe. It should be set to cut the motor off at no lower(less) than 3.0volts per cell (9 volts for a 3S/11.1V LiPoly).When the motor cut off the voltage will increase some. Do not continue to fly as the battery needs to be recharged at this point.
http://www.rcgroups.com/forums/showp...28&postcount=2
Charles
Old Jan 01, 2006, 09:33 AM
seismic is offline
Seismic
seismic's Avatar
Turkish Republic
Joined Feb 2004
thanks for the answer everydayflyer
is there a way to recharge it or
now it's garbage
my speed control is Jeti 30 Amp Microprocessor Motor Controller and i plug it "lipo on" mode
Old Jan 01, 2006, 10:28 AM
Southern Pride
Some ESCs in the LiPoly mode have auto cell count. This works OK if the battery is fully charged however it does not work correctly if the battery is not fully charged.
Example. You connect a fully charged 3S that has a voltage of between 12.45-1255(normal trange) and it sets the cutoff correctly for 3S (approximatelt (2.7-3.0 volts per cell) as different ESCs use different values.
If the battery is a 3S but was not fully charged as in has been flown without recharging or was never charged to begin with then the voltage could be in the range of the voltage for a 2S battery. The ESC would then set the cutoff to low.
There are means by which an over discharged LiPoly can be saved. These practices are best left to those with the proper equipment and experience. The LIPolys so revived will never be as good as they were.
Charles
Old Jan 01, 2006, 11:34 AM
BrunswickOH is offline
Find More Posts by BrunswickOH
Brunswick, Ohio
BrunswickOH's Avatar
Joined Aug 2003
Or if you left the battery plugged into the speed controller by accident after your flight that would drain down the voltage.
Jim
BrunswickOH is offline Find More Posts by BrunswickOH
For Sale 2000 mha 11.1v 3-cell li-po totalywicked Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 06, 2006 01:49 PM
Discussion Anyone use the E-Power 11.1V 1300mAH 3S Li-Po Battery? SteveCH Micro Helis 33 Aug 22, 2006 03:44 PM
Discussion How do I charge my 11.1v 1300mAH 3S Li-Po KavanElwood Batteries and Chargers 10 Jun 19, 2006 11:38 AM
For Sale Brand New 11.1V 15C Dynam Li-Poys Lt.Smash Aircraft - Electric - Batteries & Chargers (FS/W) 4 Apr 16, 2006 09:28 PM
Sold Great Planes 640 11.1V three cell Li PO pro bro steve Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 18, 2006 12:01 PM
