Old Jun 06, 2002, 03:13 PM
JIMJAM is offline
Find More Posts by JIMJAM
JIMJAM's Avatar
Columbia, South Carolina, United States
Joined Feb 2000
Pics Of Initial U-Boat Trimming
This forum is pretty dead so hope you dont mind some more pics.I needed to retrim the boat after removing the torpedo system from the front and also wanted the boat to sit lower in the water than it was. This involves a trial and error method of adding,removing,moving weight and flotation around. Its relationsship to the waterline is also important because the boats CG changes as the boat submerges. This beast weights in at around 50 pounds wet so Im worn slap out after lifting her in and out the pool a few dozen times. To give you an idea of its size, the pool is 9 foot from wall to wall. This is the boat with ballast tank dry.
JIMJAM is offline Find More Posts by JIMJAM
Old Jun 06, 2002, 03:15 PM
JIMJAM is offline
JIMJAM's Avatar
Joined Feb 2000
Ballast tank flooding
Old Jun 06, 2002, 03:18 PM
JIMJAM is offline
JIMJAM's Avatar
Joined Feb 2000
Decks Awash
Old Jun 06, 2002, 03:21 PM
JIMJAM is offline
JIMJAM's Avatar
Joined Feb 2000
Midway up the Conning Tower. About where I wanted it.
Old Jun 06, 2002, 03:23 PM
JIMJAM is offline
JIMJAM's Avatar
Joined Feb 2000
Water level View
Old Jun 06, 2002, 03:25 PM
JIMJAM is offline
JIMJAM's Avatar
Joined Feb 2000
Everthing checks out so this time next week Im going to run her in some real water.
Old Jun 06, 2002, 06:39 PM
totalboss is offline
Find More Posts by totalboss
Gaithersburg, MD, USA
Joined May 2000
Is this from a kit, or is it custom made? Incredible detail!
totalboss is offline Find More Posts by totalboss
Old Jun 06, 2002, 09:03 PM
JIMJAM is offline
JIMJAM's Avatar
Joined Feb 2000
Unlike most other r/c,when it comes to subs there are very few complete kits. You try and gather up what you can and scratch build and fabricate the rest. The hull is a now out of buisness 32nd parallel. Its basically a smooth hull that requires alot of work sanding and cutting holes. The deck is a custom brass deck from I beleive Jeff Larue. Not only does it look better but also keeps you from cutting hundred of deck slots. The tower is scratch built from fiberglass along with the railings,floor and most antenna and periscopes. The WTC housing the electronics is a D&E 3.5 modified for 2 motors and alot of the electric gizmos come from Subtech. The guy who built it is one of the best and builds only WW2 German subs. He spent 9 months to complete it. I got her from a retired Naval Officer who had it built for him. He only ran it a few times. The size and weight was just too much for him to manage.
Old Jun 06, 2002, 09:25 PM
Don Sims is offline
Find More Posts by Don Sims
Don Sims's Avatar
Outside of Dyer, Tn. USA
Joined May 2000
Beautiful sub! Does it have compressed air tanks to blow the ballest tanks? Or do you do that manually... That is a monster if the pool is 9' across! ENJOY!
Don Sims is offline Find More Posts by Don Sims
Old Jun 06, 2002, 10:20 PM
JIMJAM is offline
JIMJAM's Avatar
Joined Feb 2000
Using a switch on the radio, you allow as much water to enter the ballast tank until the desired depth is achieved. To evacuate the tank, a brass tank filled with Super Duster or simular, displaces the water out the bottom. A must have saftey feature is a device "subsafe" which in the event of signal loss after a user defined time period has been preset, blows the tank. The brass tank is filled with the same that you can find at electronics stores which is used to blow off electronics or computers. The trick is that you hold the can upside down when filling the tank with the liquid. The liguid has no pressure in that state.
Old Jun 17, 2002, 06:14 PM
Casey Thrower is offline
Find More Posts by Casey Thrower
Joined Jun 2002
May not be dead long
After the post to the Subcommittee webpage about this location, the place may take off with pictures and posts.
Casey Thrower is offline Find More Posts by Casey Thrower
Old Jun 18, 2002, 11:07 AM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Welcome to RCGroups Casey!
What is the Subcommittee? Sounds interesting. I hope we can get some good discussion going on!
Jim McPherson is offline Find More Posts by Jim McPherson
Old Jun 18, 2002, 05:00 PM
Joined Jun 2002
http://www.subcommittee.com/
We are a world wide not-for-profit organization focusing on submarine modeling, both R/C and static. Currently, we have over 1,000 members from over 25 countries! We publish an excellent 75+ page magazine called The SubCommittee Report. To get a sampling of some of the Articles that have appeared in the SCR, please check out our Articles Section. There are also hundreds of photo's. Check us out.
Old Jun 27, 2002, 12:23 AM
MrTracy is offline
Find More Posts by MrTracy
Bowie, Maryland
Joined Jun 2002
SUB
A wireless camra along with a small light for underwater visibility would be nice
MrTracy is offline Find More Posts by MrTracy
Old Jun 27, 2002, 09:51 PM
JIMJAM is offline
JIMJAM's Avatar
Joined Feb 2000
I grew up on the lake and made money as a teen travelling around lake to lake scuba diving. I cleaned the bottoms of boats, fixed docks and was paid to find lost watches,props,lures ect. Theres really not much to see other than beer cans,tires,stumps and just about anything else you can imagine.
U- BOAT Sub on Patrol Pics alligator Submarines 4 Jan 03, 2005 05:32 PM
New U-Boat Patrol Pics JIMJAM Submarines 16 May 13, 2004 09:24 PM
Just Postin Pics U-Boat JIMJAM Submarines 4 Nov 18, 2002 11:43 PM
Another Succesfull U-Boat Patrol-Pics JIMJAM Submarines 11 Aug 12, 2002 11:12 AM
U-BOAT 1st Trials,Pics JIMJAM Submarines 3 Jun 17, 2002 03:57 PM
