Old May 19, 2006, 12:49 AM
SMonkey is offline
Find More Posts by SMonkey
A.K.A. Reaper Keeper
SMonkey's Avatar
United States, NV, Sparks
Joined Feb 2006
Looks like the spar is ~19 1/2inches stock. I cut mine down to 19 1/4in and it fits perfect.
SMonkey is offline Find More Posts by SMonkey
Old May 19, 2006, 05:40 AM
JB48 is offline
Find More Posts by JB48
Joined Apr 2006
My EasyStar comes from a kit and I also had to cut 1/4 inch from the spar in order to fit. It looks like everybody has to cut the spar. Strange that the building instructions never mention that? Maybe that the composite rods supplier goofed a bit! Who knows?
JB48 is offline Find More Posts by JB48
Old May 19, 2006, 07:05 AM
sargentw is offline
Find More Posts by sargentw
"SARGE"
sargentw's Avatar
Fairfax Station, (Northern) Virginia
Joined Jun 2003
Leave it at 19.5. The only thing you have to do is push/twist it in only 1/8 " more on each wing. That's EZ.
You guys can do this. Check where I've replaced the 19.5 with a 26" CF rod. I had to do some pushing and twisting to get it to fit.
http://www.rcgroups.com/forums/showt...&page=20&pp=15
Post 296
sargentw is offline Find More Posts by sargentw
Old May 19, 2006, 07:07 AM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
Originally Posted by BrianRickman
Very nice.
Is that EPP foam?
What size box will you use?
Do you know how much it will cost to mail yet?
Brian,
Thanks. The foam is packing foam, used in shipping to help secure items in a box during shipment. I found this site, it looks like it's the same stuff. I've seen this foam around for 20 years now, so it's a common item. Maybe check with your shipping dept at work if you have one?
The box measures 43 x 21.5 x 11. I do not know how much it will cost to mail yet. When I know, I'll post it.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old May 19, 2006, 03:42 PM
jellied is offline
Find More Posts by jellied
Not so fast....
Boulder, Colorado
Joined Apr 2005
Originally Posted by Ginger Adam
Brian - I'm sure the EZ* is perfect out of the box but there's nothing in this world that can't be improved . My EZ* is lighter, less noisy and stays aloft for 30+ minutes.
Adam
I am thinking of going brushless, mostly so that I can get my EZ up high as soon as possible (I fly in a quite small area). I fly very early in the mornings, so having a less noisy motor would also be useful. Is a brushless motor really appreciably quieter than the stock brushed one?
jellied is offline Find More Posts by jellied
Old May 19, 2006, 04:26 PM
BrianRickman is offline
Find More Posts by BrianRickman
United States, PA, Hatboro
Joined May 2002
How small is "quite small" ? Landing may be a problem if it's smaller then a baseball field.
If the two motors turn the same prop at the same speed, then they will make the same amount of noise. If the brushless motor turns the same prop faster, it will make more noise.
The only way the brushless would be quieter is if it were spinning a bigger prop at a lower speed. This would produce more thrust, which is good if you are trying to get up high in a hurry. The bad part is that to use anything bigger then a 6" prop you will need to mount the motor higher up, which will require a bit of creativity.
I often fly at 6AM at a local park. The people out walking and/or jogging do not appear to mind the noise of the stock motor/prop combination, but there are no houses nearby. I find that once the ES is over 100 feet up, it seems to get much quieter. Running at half throttle also reduces the noise level substantially, and still provides enough power to climb. Using 1/2 throttle when it's above 300 feet I can barely hear it.
BrianRickman is offline Find More Posts by BrianRickman
Old May 19, 2006, 05:03 PM
Socomon is offline
Find More Posts by Socomon
Joined May 2006
After lurking a reading for a while I finally ordered my EZ* today from hobbly-lobby. I got the ARF kit witht he "everything you need package".
I just wanted to say hi and introduce myself. I'm sure I'll be bugging y'all with questions sometime soon.
S
PS - Has anyone tried the Coldheat soldering tool they show on TV?
Socomon is offline Find More Posts by Socomon
Old May 19, 2006, 05:17 PM
ElectroBill is offline
Find More Posts by ElectroBill
ElectroBill's Avatar
A land Far, Far away
Joined Aug 2002
Welcome Socomon, You will love this plane...
Just made my first flight with a camera. Would like to show the video but can't seem to get it posted????
This is the very best plane for shooting video that I have found! So easy to fly that you have time to look around and think of what you want to shoot...now if I could just learn to edit,,,
ElectroBill is offline Find More Posts by ElectroBill
Old May 19, 2006, 05:23 PM
FRAMEDNLVS is offline
Find More Posts by FRAMEDNLVS
Joined Jun 2004
gone fishing
FRAMEDNLVS is offline Find More Posts by FRAMEDNLVS
Old May 19, 2006, 06:47 PM
jellied is offline
Not so fast....
Boulder, Colorado
Joined Apr 2005
I thought that the motor itself was less noisy because there is much less friction without the brushes?
I fly in a baseball field, and landing is sometimes a problem, for sure. The EZ loves to glide and so my approaches have to be nice and long. How do you all get your EZ back to earth in small spaces? You can't side-slip it (which works great on full scale aircraft) because there are no ailerons!
Old May 19, 2006, 07:00 PM
EricUtah is offline
Find More Posts by EricUtah
What fence?
EricUtah's Avatar
Henderson, NV
Joined Nov 2005
Stock prop question
Will the stock prop do 45,000 rpm, ie. will it work on a 4000kv brushless motor at 11.1v? It has flown off twice when I've tried it on a bench test. The epoxy doesn't seem to bond very well with the smooth inside lining of the rubber spinner/grommet that holds the prop onto the shaft. I understand that the included Permax Speed 400 does 2900kv and is rated for 7.2-8.4v (21,000 to 24,000 rpm).
I'm concerned that not only will the rubber prop spinner not handle the increased power, but that the prop itself may come apart if spun twice as fast. I kept everything original on my build except the motor -- but now I'm wondering if the prop & spinner have to go too.
EricUtah is offline Find More Posts by EricUtah
Old May 19, 2006, 07:41 PM
sargentw is offline
"SARGE"
sargentw's Avatar
Joined Jun 2003
S
Welcome aboard! I'd avoid the Coldheat soldering tool. Don't get me started again on similar products like Ronco's Mr. Michrophone or the Pocket Fisherman...
Old May 19, 2006, 07:53 PM
Joined Jun 2004
gone fishing
Old May 19, 2006, 08:00 PM
CRASHED AGAIN is offline
Find More Posts by CRASHED AGAIN
Tenino WA.
Joined May 2004
Chris bet ur gonna get swamped ++++++++++
AS SEEN ON TV ???????????????????????
CRASHED AGAIN is offline Find More Posts by CRASHED AGAIN
Old May 19, 2006, 08:42 PM
Joined Aug 2002
Try posting here: http://www.rcgroups.com/forums/forumdisplay.php?f=273
I did, no luck!
Don't know what im doin' wrong, but thanks anyway it's a lot of fun combining flying and photography (two expensive hobbies I might add!)
Question Multiplex Easy Star brucie1dog Beginner Training Area (Aircraft-Electric) 12 Dec 01, 2009 09:32 PM
Multiplex Easy Star Built on time! Speed E Freak Foamies (Kits) 10 Sep 01, 2009 11:30 AM
Discussion Multiplex EasyStar 2007 A discussion of anything Easy Star and sometimes more alexeames Foamies (Kits) 10990 Dec 31, 2007 06:12 PM
Discussion Multiplex Easy Star Thread #21 - what more can I say?? Gort@69 Foamies (Kits) 2015 Dec 31, 2005 10:33 PM
Question Multiplex Easy Star RTF Help! brucie1dog Beginner Training Area (Aircraft-Electric) 2 Feb 22, 2004 11:49 AM
