Old Dec 31, 2005, 09:58 AM
lammy1000 is offline
Find More Posts by lammy1000
Joined Jan 2005
Effects of low temps on plane?
I fly a balsa plane w/so-lite covering (electric) in winter temps down to 18 degrees. Am I risking damage if the plane sits f/~4 hours at this temperature and then flown? I am concerned about the CA losing bond strength or hinge tape losing adhesion.
lammy1000 is offline Find More Posts by lammy1000
Old Dec 31, 2005, 01:54 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
The plastic will stiffen and often becomes a bit more brittle. I don't know about the hinge tape but check it often for signs of lifting. The plastic of the tape will stiffen but the glue hardens as well so it may not be a problem or it may start lifting. Cycle it a dozen or two dozen times and check for the clouding of the glue that indicates the tape is lifting. If it's OK then you're good to go.
The wood and glue will be fine.
BMatthews is online now Find More Posts by BMatthews
Wireless camera on plane thor4944 Electric Plane Talk 13 Sep 08, 2002 02:50 PM
can a skyscooter wing be it's on plane? darenm Foamies (Kits) 4 Aug 10, 2002 06:45 AM
Car ESC on plane? simingx Beginner Training Area (Aircraft-Electric) 3 Aug 03, 2002 11:06 PM
anyone have any info on a plane called WINDEX ? wonder Electric Sailplanes 2 Jun 06, 2002 06:08 AM
Ryan Hellcat 400, Need some info. on plane? speedo Scale Kit/Scratch Built 1 Jul 08, 2001 08:58 PM
