Old Dec 29, 2005, 12:56 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Build Log
Banckert Tug
I started building my Banckert, I think Billing Boats forgot to add the instructions with the pictures. They say a picture is worth a thousand words, Well Iím speechless.
I have built the Billing Dragon sailboat, I think the instructions were better.
Don M.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Dec 31, 2005, 02:49 PM
TorViking is offline
Find More Posts by TorViking
TorViking's Avatar
Crosby,near Liverpool,England
Joined Oct 2005
Andy
nkert as my first kitboat about 23 years ago and it was **** then! Have you got the ABS or plank on frame hull version? I had the ABS one and I still have the plans in my model cupboard.If you need em let me know maybe I can post em to you.
Full speed ahead and best wishes from Liverpool
TorViking is offline Find More Posts by TorViking
Old Jan 02, 2006, 12:22 AM
MILLERTIME's Avatar
Joined Apr 2004
I found a old 7.2 V. drill, it has a Johnson motor. The motor works so I will use it, I think it's a 550 or 600. I did not like the wood rudders so I made new aluminum oneís.
Don M.
Old Jan 03, 2006, 12:28 PM
MILLERTIME's Avatar
Joined Apr 2004
Last night I made a oil tube for the stuffing box. I made the top funnel shaped, and threaded it for a plug.
Iím using Neoprene ďOĒ rings for the seals, has anyone done this, will it work?
Don M.
Old Jan 03, 2006, 12:50 PM
LtDoc is offline
Find More Posts by LtDoc
McAlester
Joined Nov 2004
Don,
Will it work? Sure. Got to be sort of carefull with the 'O' rings, not too tight a fit on the shaft (tight fit = brake, like you didn't know that, right - lol?). Without getting into a big discussion about what you use for oil, not all petroleum products are compatible with plastics or whatever 'O' rings are made of. Just a word of warning...
- 'Doc
LtDoc is offline Find More Posts by LtDoc
Old Jan 03, 2006, 05:52 PM
MILLERTIME's Avatar
Joined Apr 2004
Thanks Doc,
''O'' rings are Neoprene, should work with almost any oil.
Old Jan 03, 2006, 11:14 PM
LtDoc is offline
McAlester
Joined Nov 2004
Don,
I certainly hope you're right. Being a good learner from mistakes, the worst the mistake, the better I learn, all 'O'rings are not compatible with brake fluids, for example. Unfortunately, those 'O' rings were not on a model. Didn't kill myself, but took years to remove the stains from the upholstery (the line-boy wondered what the smell was - LOL).
- 'Doc
Old Jan 04, 2006, 12:20 AM
jeepers1940 is offline
Find More Posts by jeepers1940
Madison, MS
LtDoc, Who would have O-rings that small, a plumbing supply place? If not there, do auto parts places have them that small? Thanks.
Bill
PS - hope you're safe from the fires over there.
jeepers1940 is offline Find More Posts by jeepers1940
Old Jan 04, 2006, 12:56 AM
Rex R is offline
Find More Posts by Rex R
Joined Nov 2005
my local hardware store carries o-rings from 3/32"(plumbing), autoparts may have them for carburators.
Rex R is offline Find More Posts by Rex R
Old Jan 04, 2006, 01:28 AM
MILLERTIME's Avatar
Joined Apr 2004
Pep Boys has a good supply.
Don
Old Jan 04, 2006, 12:40 PM
C Thrower is offline
Find More Posts by C Thrower
Casey Thrower
C Thrower's Avatar
United States, AL, Meridianville
Joined Jul 2004
I used "Permatex WL-9" white lithium grease in my stuffing boxes. Works really well to keep the water out.
C Thrower is offline Find More Posts by C Thrower
Old Jan 06, 2006, 01:18 AM
Madison, MS
To answer my own question, yes, local auto parts places do have a small cabinet with a very large selection of O-rings. The smallest that NAPA had was a perfect fit for my 1/8 inch prop shaft. The price was right - 37 cents each. They're supposedly made of neoprene, which should be oil-compatible.
My local well-equipped plumbing supply house didn't have anything close to what I needed.
Bill
Old Jan 06, 2006, 02:58 AM
lasatalayas is offline
Find More Posts by lasatalayas
PeŮŪscola, Spain.
Joined Dec 2005
For many years I have used 'Dow Corning DC4 (used to be MS4) Silicon Compound' when sealing 'O' rings. it is also a great a waterproofer.
One can also make your own 'O' rings by buying lenghts of the rubber, cutting with a scaple and then glueing the two ends with CA glue.
A useful reference is http://www.thesealman.com/pages/orin...ook/index.html
lasatalayas is offline Find More Posts by lasatalayas
Old Jan 14, 2006, 05:44 PM
MILLERTIME's Avatar
Joined Apr 2004
Ready for sea trials, made a motor mount and couplers for the prop shaft.
I added wood reinforcements to the bow, and some Styrofoam for floatation.
I made a brass bracket for the oil tube. I installed a JR Beat Gear radio and Traxxas
ESC for the sea trials.
Old Jan 22, 2006, 12:46 AM
MILLERTIME's Avatar
Joined Apr 2004
The sea trials went good. It didnít sink.
Iíve been working on the cabin, the kit didnít come with a instrument panel
so I made one.
The kit came with plastic portholes, I didnít like them. I went to Hancock Fabrics and got some brass eyelets, and used them. Next I will be putting lights on the mast.
