Old Jun 05, 2002, 07:33 PM
Alfred is offline
Find More Posts by Alfred
Alfred's Avatar
Perth
Joined Apr 2002
BEC cut off point
Does anyone know at what voltage the BECs on the little GWS 100 ESCs cut power to the motors?
Alfred
Alfred is offline Find More Posts by Alfred
Old Jun 06, 2002, 07:04 AM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
BEC is the 'battery eliminator circuit'. This is that part of the speed control circuitry which powers the receiver from your flight battery, eliminating the need for a receiver battery.
Are you refering to the 'low voltage cutoff'?
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Jun 06, 2002, 07:32 AM
Alfred is offline
Alfred's Avatar
Perth
Joined Apr 2002
Yes I mean at what level does it cut off.
Alfred
Old Jun 06, 2002, 11:44 AM
Joined Sep 2000
Alfred
I have read where most ESC's will have a LVC around 5 v.
Old Jun 07, 2002, 01:57 AM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Many do. A lot don't. The best ones base the cutoff on the battery voltage when they're first fired up, so as to not over-discharge the drive battery. This is more important as the cell count goes up.
Even those that do have a fixed cut off (common in inexpensive ones) vary widely from about 4.5V to nearly 6.
I haven't had a GWS ESC so I can't say what it is, but I'd expect it to be somewhere between 5.0 and 6.0V.
BEC is offline Find More Posts by BEC
Old Jun 07, 2002, 07:12 AM
Joined Sep 2000
BEC,
I have wondered about the LVC on high cell count. Since I am flying no more than 8 cells and try not to flatten a pack in flight it has not been a problem. All of my ESC's are the inexpensive JETI types.
Old Jun 08, 2002, 05:23 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
http://www.rcgroups.com/forums/showt...&highlight=lvc
Standard cutout appears to be 4.2v, if you disable the lvc, it's 3.5v.
Gene Bond is offline Find More Posts by Gene Bond
Does the BEC have a cut off point woody uk Power Systems 2 Oct 30, 2005 02:36 AM
LiPo w/o correct BEC cut off? Kregg Batteries and Chargers 1 May 21, 2004 02:09 PM
3S series li-pos BEC cut off voltage AllenS Castle Creations 3 Dec 09, 2003 03:29 AM
Range check adivice - short range after BEC cut off !!! JensJakob Foamies (Kits) 0 Aug 08, 2001 01:38 AM
