Old Dec 28, 2005, 07:11 PM
djdaveq is offline
Find More Posts by djdaveq
I'd rather be flying...
djdaveq's Avatar
New York City
Joined May 2005
anyone know an esc that does not CUT off motor as a battery protection?
my align esc 35 amp is cutting off way too soon and causing crashes sometimes. i want an esc that i can disable this feature or that it does not have it at all. any one know of any? websites please!
djdaveq is offline Find More Posts by djdaveq
Old Dec 28, 2005, 08:06 PM
gpeden is offline
Find More Posts by gpeden
-Flight enthusiast_
gpeden's Avatar
Lake Louise, AB, Canada
Joined Feb 2000
Hi there,
I love my TMM controllers and aslo sell them at littlheli.com The heli controllers do not cut off, but start flashing the super-bright LED to tell you to bring it on home. The warning voltage is programmable. Also, it has a very strong (up to 4 amp) BEC. I normally stock the TMMŪ 4012-3 HEL (just sold last one), as does my distributor, and wonder if your heli exceeds 25 amps constant or 30 amps for 5 seconds:
http://www.mgm-compro.com/main.php?i...12-3heli&m=122
Otherwise I might suggest the TMMŪ 4012-3 HELI or the TMMŪ 4016-3 HELI
Cheers!
Glen Peden
LOGOmania
MaxirMania
MaxirManiac's Forum
gpeden is offline Find More Posts by gpeden
Old Dec 28, 2005, 10:48 PM
djdaveq is offline
djdaveq's Avatar
New York City
Joined May 2005
i am running the new 430 3550 kv from align with a 35 amp esc from align im not sure if a 25 will do or do i need a 35?
Old Dec 28, 2005, 11:04 PM
skyhawk is offline
Find More Posts by skyhawk
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
How do you know it's not your battery?
Your asking for trouble if you do not have some kind of low voltage cutoff. There are ones out there that will slowly cut back on the voltage allowing you to land.
skyhawk is offline Find More Posts by skyhawk
Old Dec 28, 2005, 11:31 PM
djdaveq is offline
djdaveq's Avatar
New York City
Joined May 2005
cause i got 3 brand new fully charged TP batteries! i know when to land as far as the flight time i dont need my motor to cut to tell me, id rather wrek a battery than my heli
Old Dec 28, 2005, 11:38 PM
bikenboatn is offline
Find More Posts by bikenboatn
Get back here, you!!
bikenboatn's Avatar
Santa Ana, California
Joined May 2005
Castle Creations Phoenix ESC's LVC can be programmed at either specific voltages, or can be disabled completely. Keep in mind their BEC's can be a little marginal, and some people have problems getting Governor mode to work.
Brent.
bikenboatn is offline Find More Posts by bikenboatn
Old Dec 29, 2005, 12:01 AM
Kris NZ is offline
Find More Posts by Kris NZ
Kris NZ's Avatar
New zealand
Joined Aug 2005
im haveing that problem too. flying along then the heli turns into a brick, not good
Kris NZ is offline Find More Posts by Kris NZ
Old Dec 29, 2005, 03:24 AM
Minimole is offline
Find More Posts by Minimole
Sponsered By My Wallet!
Minimole's Avatar
Colwyn Bay, North Wales, UK
Joined May 2004
Get a lipo alarm.
Trust me, they are worth evey penny they cost.
If you can, get one with a buzzer, like the one from www.customidea.com
Duane.
Minimole is offline Find More Posts by Minimole
Old Dec 29, 2005, 04:14 AM
Tintin is offline
Find More Posts by Tintin
Tintin's Avatar
Akershus, Norway
Joined Mar 2005
I can almost guarantee you that this is completely wrong. I trust you are running a standard 3S setup. Your Align esc have possible LVC at 60, 65 and 70% of voltage.
Since you want it without cutoff I guess you are running on 60% which means your cutoff is at 12.6*0.6=7.56 volts which is much too low for proper battery protection. 70% would give you 8,82 volts which is still too low.
So if you have problems with esc cutting you are most surely ruining your batteries. (Been there, done that, with Align esc)
The 3550 is much more demanding on your batteries than older align motors.
What TP packs do you have?
Hwvr the Align esc is not supposed to cut, just reduce power so you can land...
Oh yeah. As MM says, get a Lipo alarm and stop flying at least when you reach 9V but preferably 9.3 or more which is a good while before esc will cut.
(And Customidea's one is good which I told them and they asked me kindly to let others know too, so I do, free of charge I have 2, one in each Rex, they go off a good while before the esc cuts...
Remember even if remaining voltage after flight is abv 9-9.3V it's still going a bit below this while flying if esc cuts and that is damaging, no doubt...
Tintin is offline Find More Posts by Tintin
Rant Yes I can't Spell! that does not mean I'm an idot lenniegordo Life, The Universe, and Politics 45 Apr 08, 2006 06:58 PM
Looking for an ESC that may not exist..... Cal Power Systems 17 Feb 08, 2005 10:53 AM
Can't get full throttle, esc seems to cut off motor, please help! Newbie1 Power Systems 10 Dec 08, 2002 02:39 PM
Does anyone know of an online shop that has gws 9x7 props. The Other Dave Parkflyers 3 Jan 04, 2002 09:33 PM
Does anyone know of an F 86 kit for the HW 609 Fan Joe Elston Electric Ducted Fan Jet Talk 7 Nov 01, 2001 11:44 AM
