Old Dec 26, 2005, 04:40 PM
Supra!!!!!!
Speed Stick 3D's Avatar
Las Vegas Nv, USA
Joined Oct 2005
what does kv stand for
i am going to buy a brushless motor and the one i bought is rated at 1100 kv
what does that mean?????????????????????????????????????????????? ??
Speed Stick 3D is offline Find More Posts by Speed Stick 3D
Old Dec 26, 2005, 04:44 PM
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
It is RPM/volt. So a 1100 kv motor turns (or tries to!) 11,000 rpm with 10volts.
Old Dec 26, 2005, 06:38 PM
Fly Fly Fly Crash
Dragon 2's Avatar
Montrose Co
Joined Aug 2005
volts X kv = rpms a motor should turn.
Dragon 2 is offline Find More Posts by Dragon 2
Old Dec 27, 2005, 08:55 AM
Resurgam's Avatar
Vienna, VA, USA
Joined Dec 2005
Kv of 1100 is a fairly "cool" motor - it will be happiest swinging a rather large prop at fairly low rpm with a low current draw (relatively), and will likely be most suitabe for a plane that flies rather slowly. A "hot" motor might have a kv of 5000, and will want to spin much faster, so you'd put that with a small prop in a fast plane - or gear it down to spin a bigger prop more slowly.
Resurgam is offline Find More Posts by Resurgam
Old Dec 27, 2005, 11:53 AM
Go get them Meg!
lrsudog's Avatar
Cabin 21...
Joined Jan 2001
Higher KV motors also tend to be able to accept more amps, so sometimes a high KV motor in a GB is a better choice for slow flying planes that require a lot of power, such as 3D planes.
lrsudog is offline Find More Posts by lrsudog
Old Dec 27, 2005, 12:10 PM
Supra!!!!!!
Las Vegas Nv, USA
Joined Oct 2005
I have a gws slow stick after i installed the motor it seamed like i had no power well you know what i mean is seemed like the stock motor put out more power than the brushless 1100 kv so i took the motor off and returned it for a 1750 kv motor i am swinging a 10 by 4.7 i can now leap off the ground at full throttle an hover i get around a 35 min flight i am very happy because i spent under 58 dollars ...............
kms KMB 31/21 brushless motor 1750 kv
castle creations THUNDERBIRD 18 esc
apc 10-4.7 prop direct drive
kms 31/21 stick motor mount
here are a few pics of before and after the brushless was installed
you can see the old setup and motor on page 2 0f electric plane talk called brushless motor good for ss.........
Old Dec 27, 2005, 05:02 PM
Resurgam's Avatar
Vienna, VA, USA
Joined Dec 2005
What prop were you using with the 1100 kv motor?
Old Dec 27, 2005, 07:50 PM
Supra!!!!!!
Las Vegas Nv, USA
Joined Oct 2005
i was using the recommended prop 10-4.7 and 9-4.7
Old Dec 28, 2005, 06:41 AM
Resurgam's Avatar
Vienna, VA, USA
Joined Dec 2005
Since the 1750 kv motor performs well with a 10x4.7, it sounds like the 1100 kv motor just needed a bigger prop, maybe 12x6 or something - or a higher voltage battery.
What does AUW stand for?? Runyond Beginner Training Area (Aircraft-Electric) 28 Sep 08, 2010 06:37 PM
What does tic stand for? mgerald Life, The Universe, and Politics 32 Jul 25, 2003 03:20 PM
what does ROG stand for billyboy Electric Plane Talk 17 Jun 19, 2002 08:37 PM
What does EH stand for in this pack? [N-600AA (EH)] Skysaurus Electric Plane Talk 1 Nov 27, 2001 10:41 AM
