Old Dec 26, 2005, 01:24 PM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
Can I use 3M "45" instead of 3M "77" on EPP Foam.
I am building a Hobby People "Wild Wing" made of EPP Foam. I need to lay out the Red packing tape on the top of the wing & was wondering if I should spray some 3M adhesive on the EPP foam before I start taping it up? Is it OK to use 3M "45" General Purpose spray adhesive on EPP type foam or do I need to lay out the $10 to get the 3M "77" spray??
-Thanks-
mrebman is offline Find More Posts by mrebman
Old Dec 26, 2005, 03:23 PM
Pezzer is offline
Find More Posts by Pezzer
The Original Slacker
Pezzer's Avatar
Bristol, TN
Joined Apr 2005
You most likely will need adhesive of some sort as tape doesn't want to stick and stay on EPP. Molded EPP I think is worse in this regard. As fasr as I was told you have to use the sticker 3M Super 77 to get it on good.
Spray a light dusting, you will see little fiber "hairs" on the surface. Let that coat dry for about 15-30 minuets. Then do another light coat or two and then fiber tape followed by the colored packing tape after the 77 dries a bit. We use the 90 on the fiber mesh (non fiber tape) method.
Hope that helps but if I'm wrong someone will chime in...
-Dave
Pezzer is offline Find More Posts by Pezzer
Old Dec 26, 2005, 03:54 PM
mrebman is offline
Joined Nov 2000
Thanks, the reason I was asking is that I used the "45" on the balsa elevons with the tape & it seemed to work fine. The "45" can says not to use it on Expanded Polystyrene Foam, is EPP the same thing?
- Thanks -
Old Dec 26, 2005, 04:00 PM
Pezzer is offline
Pezzer's Avatar
Bristol, TN
Joined Apr 2005
That was in reffrence to EPS, Expanded Polystyrene. I think the 45 melts it or at least deforms that type of foam. The 77 is, of course, safe for EPP and I think EPS too.
EPP is Expanded Polypropylene if I remember correctly. Diffrent but similer acting polymer. EPP is better for crushing resistance and EPS is better at tearing resistance. Each is not good for the other property thats why some early wings were a combo of EPP on the leading eadge and EPS for the main wing. EPP to resist the crushing of a leading edge crash and EPS for the main body as it is cheaper and I think a bit lighter too.
Good luck and clear skies!
-Dave
Discussion Can I use 220mm flybar instead of the 190mm one on the 450SE vadim Mini Helis 7 Oct 13, 2006 03:07 PM
Can I use flat-bottom wood replacement blades on Dragonfly/Esky FP helicopters? Johnny B Micro Helis 2 Sep 23, 2005 02:37 PM
Can I use a 3 or 4 bladed prop on my GWS Corsair??? Valid8r GWS (Grand Wing Servo) 10 Jan 18, 2005 07:38 AM
CAN I use 3s for my rx pack on a JR 6102 sbmon Batteries and Chargers 1 Dec 06, 2004 08:50 PM
Can I use a LiPo cell instead of 2AAA batteries in my Camera? Skid_Mark Aerial Photography 13 Oct 26, 2004 11:54 PM
