Old Dec 24, 2005, 12:00 PM
twinster2 is offline
Find More Posts by twinster2
Check your six....
twinster2's Avatar
Kalamazoo Kal/Btlcrk, Michigan, United States
Joined Nov 2001
Balsa USA Smoothie Conversion
Has anyone every electrified a Balsa USA Smoothie. If so, let me know what you used in the way of power. I have the plans and will scratch build one to keep it light. The plane has a 52 inch WS and will weight approximately 3-4 pounds.
Don
twinster2 is offline Find More Posts by twinster2
Old Dec 25, 2005, 11:46 PM
feathermerchant is online now
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Is this the old control line Smoothie? If it's close, I say the AXI 2820/10 a Phx 45 ESC an APCE 11X5.5 or 12X6 and Tanic 3S 3,650 would make a plane out of it.
feathermerchant is online now Find More Posts by feathermerchant
Old Dec 26, 2005, 12:45 PM
Check your six....
twinster2's Avatar
Joined Nov 2001
smoothie
Thanks for the recommendation. The plane I'm referring to was originally a CL model which BALSA USA made into a RC model back in the 1980. It has been discontinued for about 15 years now. I had two, one from a kit and one scratch build from plans. The flew great with a 40 FP. I'm consider building a new one (much lighter) and electrifying it. Was thinking about an AXI 2814/12 but it may not be enough motor unless I can keep the overall weight less than 4 pounds.
Don
Old Dec 26, 2005, 05:17 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
My SA CAp40e weighs 2lb 10oz at 55" wingspan.
It has the power system recommended above.
Performance is unlimited vertical and very aerobatic.
Old Feb 06, 2006, 12:00 PM
skypix is offline
Find More Posts by skypix
Aviation photographer
skypix's Avatar
near Albany, NY
Joined Sep 2004
I built a smoothie kit, control line stunt plane, when I was living, briefly, in Havana Cuba, winter of 1959. I'm wondering if this is the same plane. For a 13 year old, it was very big...52" seemed huge at the time. as i recall it had a semi-elliptical wing, very beautiful, which is why I bought it. I never flew it but it was fun to build.
if it sounds like the same plane, where could I find the plans?
thanks, good luck with your project.
skypix is offline Find More Posts by skypix
Old Feb 06, 2006, 01:19 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
>Plans< Me too
Like I need another project.
Old Feb 06, 2006, 04:16 PM
electric-2000 is offline
Find More Posts by electric-2000
San Diego, CA
Joined Oct 2001
Veco Smoothie CL
Here is a eBay link for the vintage Veco Smoothie u-control kit. There should be a few of the Balsa USA kits floating around, they are selling for around $150-$175 for the kit.
electric-2000 is offline Find More Posts by electric-2000
Site Sponsor
Old Feb 06, 2006, 04:26 PM
skypix is offline
skypix's Avatar
near Albany, NY
Joined Sep 2004
brodak.com sells rekitted versions of the original Bob Palmer control line Smoothie for $100, or ARF versions for a little more. Apparently the modern kits are much better than the original, which were great for their day (1950s)
BTW, Bob Palmer died yesterday
Old Feb 06, 2006, 07:41 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Forgot about Brodak. Don't tell my dad.
Old Feb 06, 2006, 10:59 PM
Check your six....
twinster2's Avatar
Joined Nov 2001
Smoothie
Here is a picture of the my first smoothie I built in 1988. It was powered by a OS 40FP 2 stroke engine. It builts heavy but was a pleasure to fly. I plan on building it "light" with build up tail feathers and 1/16" wing sheeting. Probably won't get to it this year but maybe next. WS is 53" and weight is 4-5 pounds for the glow version.
Old Feb 06, 2006, 11:15 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Based on what I saw at Brodak, it doesn't look much like the original.
Gallery Balsa USA Dr.I Conversion k_sonn Glow to Electric Conversions 33 Sep 13, 2006 05:21 PM
Question Balsa USA 43" span P-51 conversion flying jeep Glow to Electric Conversions 10 Aug 23, 2006 05:32 PM
1/4 Scale Balsa USA J3 Cub Conversion Bill Sanford Sport Planes 16 May 17, 2005 08:39 AM
NIB: Balsa USA Smoothie twinster2 Aircraft - Fuel - Airplanes (FS/W) 0 Nov 17, 2003 11:08 PM
Citrabia Pro - Balsa USA E Conversion Rod Scale Kit/Scratch Built 9 Feb 08, 2003 12:20 AM
