Old Dec 22, 2005, 10:04 PM
X-spec is offline
Find More Posts by X-spec
Joined May 2004
Need plan, 3D view or Autocad On F/A-18C
HI! Guys,
I 'm planning to build a F-18 Hornet using two Wemotec 480 fan with HET2W-20 on this project but need a plan for scratch build any of the guys here have the plan or 3 view,Autocad? I saw something on ParkJet.com but not those plan that I want please help thanks You.
X-spec.
X-spec is offline Find More Posts by X-spec
Old Dec 23, 2005, 05:37 AM
jjantti is offline
Find More Posts by jjantti
jjantti's Avatar
Finland
Joined Sep 2004
Hi
3-view is easy.
Download .gif 's. For example from airwar.ru
Open with your autocad. -> insert -> raster image
Scale up to the size you need
Print to paper or draw your own plans on top of them.
Exact cross sections is the difficult part.
You'll get something from the front and back views but nothing precise...
And those intakes are... small.
/Jyri
jjantti is offline Find More Posts by jjantti
Discussion need help with motor set up on 3d f-18 lawn jockey Pusher Prop Jet Models 3 Feb 04, 2006 08:10 AM
Need plan or good 3-view of Vickers Wellesley The Wanderer Foamies (Kits) 13 Jan 24, 2006 08:08 AM
Wtb Or Wtt Aveox F-16, Have F-10 If You Need One BobStewart Aircraft - Electric - Airplanes (FS/W) 0 Feb 20, 2003 06:56 PM
Need to Buy: Futaba/Hitec Tx Crystal on Channel 41 or 27 Jamie- Aircraft - Electric - Airplanes (FS/W) 0 Nov 02, 2001 10:52 AM
XL wing or standard on Flying Styro F-16? Tom J. Electric Ducted Fan Jet Talk 4 Oct 29, 2001 10:53 AM
