Old Dec 22, 2005, 07:01 PM
igo
Joined Apr 2004
Hornflankful
i've always like the lines of the f/a-18, su27 and mig 29. so i drew this.
none of it is to any scale but it looks most like a hornet.
- bluecor
- 24 in wingspan
- taileron
- cd rom motor
igo is offline Find More Posts by igo
Old Dec 23, 2005, 12:02 AM
igo
Joined Apr 2004
test glider...
...works. now i know where the cg is. time to make some templates.
Old Dec 23, 2005, 01:06 AM
RSteel's Avatar
Sacramento, Ca.
Joined Jul 2005
Intresting. Hope it works out for ya. Why tailerons?
Ray
RSteel is offline Find More Posts by RSteel
Old Dec 23, 2005, 01:25 AM
igo
Joined Apr 2004
hello Ray, yeah, i hope it works too!! i don't have a taileron plane. but if there is a reason why that's not a good idea, i'd like to know and why.
Old Dec 24, 2005, 07:15 AM
It should be I was sad :)
Bournemouth, Dorset, UK
Joined Jan 2005
COol. It needs the intakes of the Su-27 in it tho. looks a bit empty with no intakes.
im-sad is offline Find More Posts by im-sad
Old Dec 24, 2005, 10:18 AM
igo
Joined Apr 2004
i didn't want intakes because i was thinking that this plane is a pusher with no need for an intake.
Old Dec 25, 2005, 01:19 AM
Joined Jan 2005
well you dont need them to be fungtional, just for looks great like this too!! Merry Christmas!!
Old Dec 25, 2005, 07:41 PM
igo
Joined Apr 2004
it flies
merry christmas to you too!!
here's the finished plane, some details and maident flight report.
final wingspan: 18 inches
auw: 6.8oz
motor: cd rom 18mm stator, 5x5x1.5mm n50 12pc nsnsns..., 13t 26gage wye, ball bearings
control surfaces: taileron
servos: gws pico (2)
receiver: gws pico
esc: castle creations phoenix 10
battery: thunder power 3 cell 830mah
amp draw: measure 6.8amps
maiden report: i had too much up elevator and it went up pretty quick at 3/4 throttle. i also had to trim it left. otherwise, it was great to fly and normally i don't do any stunts at maiden but it loops, rolls, immelmann, split s, cuban 8, half cuban,verticals, inverted with no problem. 9 minute flight. very stable. pretty good speed too. good glider too which makes landing very easy.
Old Jan 09, 2006, 12:39 PM
igo
Joined Apr 2004
pdf
in case anyone is interested or gets bored or wants to try something new or has extra foam and needs a project...
Old Jan 10, 2006, 02:39 PM
registered foam addict
chara's Avatar
Munich, Bavaria
Joined Dec 2004
igo, very nice lines in deed! A lovely blend of some great looking fighters.
would be cool to see a full fuse verion of this one fly.
greetings
chara
chara is offline Find More Posts by chara
Old Jan 12, 2006, 11:21 AM
igo
Joined Apr 2004
hi chara, i orignially wanted to build it full fuse but i got lazy.
Old Jan 23, 2006, 07:17 PM
igo
Joined Apr 2004
made a change to the motor. it's now an 11t, 24gage, wye, 5x5x1mm, 12 n40 nsnsns..., 20mm stator. 9oz thrust from thunder power 1320mah 2 cell drawing 9amps. this set up flies faster than previous 3 cell setup. the previous motor had an18mm diameter stator, 12 n50 nsnsns..., 5x5x1.5mm, 13t, 26 gage, wye.
Old Jan 23, 2006, 11:01 PM
Micro Brushless crazy
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
Looks great! Any idea how much wing are you have on this?
-Tnx,
Uttam
Uttam1 is offline Find More Posts by Uttam1
Old Jan 23, 2006, 11:29 PM
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
And where's the CG? 50% root chord?
-Tnx
Old Jan 24, 2006, 11:32 AM
igo
Joined Apr 2004
hello Uttam, if you count the leading edge root extension and all of the flat area behind it then the wing area is 150 sq inches. if not then about 80 sq in. the cg is about 1.6 inches from the intersection of the wing leading edge and leading edge root extension. if you want pictures i can supply.
i really like your micro brushless motors!!
