Old Oct 02, 2010, 12:17 PM
mavlo77 is offline
Find More Posts by mavlo77
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Another idea as alternative for plywood. Use epoxy board. This is very strong material. So strong that it destoys your saws and drills...
mavlo77 is offline Find More Posts by mavlo77
Old Nov 26, 2010, 04:50 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Well, finished my PTIIXL this past week and maidened today. Flew good, but definatly like rudder in the turns, which I have a bad habit of not doing. I will probably end up mixing it into my radio and cheating a little.
I couldnt get it to taxi in the water. The wing floats kept dipping into the water. I need to revamp them.
Looked great in the air. It now deserves some paint.
After that I can mark it off my list and add either the drake or another polaris to my list. I like seaplanes...
Derek_S is offline Find More Posts by Derek_S
Old Nov 26, 2010, 04:59 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
I googled it. where would I find some of a suitable size for our purposes? Most of it looks large, obviously for surfboards..
Old Nov 27, 2010, 02:06 AM
dniweerf is offline
Find More Posts by dniweerf
dniweerf's Avatar
Kampen, the Netherlands
Joined Nov 2008
Hi there Derek...
Any chance of showing us a video of your PTIIXL ?
regards Gert
dniweerf is offline Find More Posts by dniweerf
Old Nov 27, 2010, 02:16 AM
mavlo77 is offline
mavlo77's Avatar
The Netherlands
Joined Oct 2008
You're right, on the internet difficult to find. I just got some pieces from my colleague. It is used for making circuit boards, so most companies will buy in large quantities.
See this:
http://www.alibaba.com/countrysearch...ate-sheet.html
But 200 kg minimum order.... is a bit too much...
I will check where I can find lower volumes. Strange that this material is not popular in RC, because it is really strong and durable. It's a bit heavy, but because it is so stong you only need to use thin pieces and on critical parts (motor mounts, gears, levers, etc).
Old Nov 27, 2010, 02:20 AM
dniweerf is offline
dniweerf's Avatar
Joined Nov 2008
just buy the material that is used to make PCB's yourself ! Just etch off the copper, and your good to go !
I did it several times, and works great..
Gert
Old Nov 27, 2010, 04:19 AM
rawy is offline
Find More Posts by rawy
e-powered foam
rawy's Avatar
swiss watch makers area
Joined Dec 2002
HI
Believe you will find what you're looking for googling for G-10 or G 10
regards
rawy
rawy is offline Find More Posts by rawy
Old Nov 27, 2010, 06:51 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Originally Posted by dniweerf View Post
Hi there Derek...
regards Gert
Sorry, I couldnt get a video since I was soloing. Pics would be the best I could do.. ?
Old Nov 27, 2010, 07:56 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
See this:
Hav e you seen kydex? It is the plastic commonly used to make knife sheaths and gun holsters. It is a typically black plastic, and is available in different thicknesses for hobby sheath/holster building. I bought some of it in the past after reading that it was very durable, but easily formed under heat. I never got around to trying it but it may work as well if I can get the hinge pins to hold in it.
I really want to ge the amphibious thing working. It just has a great cool factor, plus at my dad's place there is a lake and a paved drive for nice landing variety.
Old Nov 27, 2010, 08:02 AM
mavlo77 is offline
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Interesting! No never seen. I might need something like that for the main gear.
I totally agree, I also want to have it amphibious. My front gear is nearly finished. I just have to pull / push a rod to activate the retract mechanism. So next stip is to make it automated. Will post some pictures soon. But consumes a lot of time. Aspecially finding the right materials and thinking about how to constuct it.
Will post some pics later.
Old Nov 27, 2010, 09:07 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Yes, very tue. I found some air/pneumatic gear cylindars on HK and they are very cheap. I prefer electric actuation, but I am wondering if the pneu would be a good choice for wet applications...? It should operate well even if it gets damp.
I also think I could build the A arms from aluminum or anything, but the wheel rod/hub is what I am having trouble with. It needs to be tough, but a material that is able to hold the axle as well has hinge rods. Machining fom aluminum is the best choice probably, but I just havent had time to go to the machine shop and chop it out.
Please post your progress. maybe some back and forth brainstorming will yield some results.
Old Nov 27, 2010, 09:26 AM
mavlo77 is offline
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Good point, because I think I have found a very strong front wheel arm. It is suspended trailing link setup. It's a aluminum strip bent into an arm. But will make some pictures and schematics. I am editing some home video's, and during encoding I can make something .
Old Nov 27, 2010, 09:36 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
I posted pics in my blog, but here is mine. Looks very typical. My favorite mod is the removeable windshield so I can get to the battery without removing the wings. The body has been 'glassed with tissue and WBPU as per Warhead's instructions. It looks good! The wings will be done later... Spent a good bit of time on the water yesterday with no apparent leaks throught the covering. Very happy with it, just time intensive compared to raw foam building
Old Nov 27, 2010, 09:54 AM
mavlo77 is offline
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Looks nice! No dihidral as in the plans?
Old Nov 27, 2010, 11:13 AM
mavlo77 is offline
mavlo77's Avatar
The Netherlands
Joined Oct 2008
I have attached a construction drawing. A 6 mm tube is fixed between 2 washers (note the M4 nut on one end, and the horizontal wheel axle with M4 thread on the other end). This 6 mm tube with the 2 washers form a plain bearing with the inside of the 8 mm tube. This allows steering, and this 8 mm tube is also the main support. I didn't draw the spring on the front between the steering lever and the wheel arm, but you will see it in the pictures I will post later.
Build Log Depron Puddle Twin meatbomber Waterplanes 1589 Jul 04, 2016 03:08 PM
Video Depron Puddle TWIN Seaplane meatbomber Electric Plane Talk 20 Dec 04, 2011 06:29 PM
