Old Mar 31, 2006, 02:11 PM
Krashlnd is offline
Find More Posts by Krashlnd
Who Put that Tree There?
Krashlnd's Avatar
Athens, Tennessee
Joined Jun 2003
Hey Figure9,
In the 1st photos that you posted of the pondmaster, What did you use as a filler? ( The brown along the seams ) Also did you cover it or paint it?
I am at that point now.
Thanks Steve
Krashlnd is offline Find More Posts by Krashlnd
Old Apr 01, 2006, 03:34 PM
Krashlnd is offline
Krashlnd's Avatar
Athens, Tennessee
Joined Jun 2003
This Is what I have so far. This is a great building Plane. Cant wait to see it in the air.
Old Apr 03, 2006, 08:02 AM
Figure9 is offline
Find More Posts by Figure9
Figure9's Avatar
Granger,IN
Joined Oct 2001
Lookin good! For sealing the seams, I used polyuerathane glue on the inside, and then on the outside I used soome silicon sealer.
Figure9 is offline Find More Posts by Figure9
Old Apr 03, 2006, 08:54 AM
rmerk is offline
Find More Posts by rmerk
rmerk's Avatar
Augsburg Muehlhausn, Germany
Joined Jul 2003
Hi Steve,
nice build!
I seal my seams with water resistant white glue.
The bottom of my Fuselage is covered with tissue and water based parquet varnish to make it more scratch resistant. You can also use white glue instead of the varnish.
Greetings Roland
rmerk is offline Find More Posts by rmerk
Old Apr 03, 2006, 12:59 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Roland our white glue is water based and will return to a liquid state when put in water ..
Vyceroy is offline Find More Posts by Vyceroy
Old Apr 03, 2006, 01:04 PM
Krashlnd is offline
Krashlnd's Avatar
Athens, Tennessee
Joined Jun 2003
I went ahead and used Hot glue and wet my fingers then spread it out evenly. This is gonna be great. Not all I have to do is work on the wing.
Krashlnd
Old Apr 03, 2006, 01:06 PM
Krashlnd is offline
Krashlnd's Avatar
Athens, Tennessee
Joined Jun 2003
Remerk, what type of foam did you use to build yours? Did you use Balsa?
Would love to se more pictures.
Thanks Krashlnd
Old Apr 04, 2006, 09:25 AM
rmerk is offline
rmerk's Avatar
Joined Jul 2003
Hi,
In this case it is not a good idea to use white glue
I use original Depron for the whole plane. 6mm at the fuselage and ribs and 3mm to cover the Wing. No Balsa is used. Only two small pieces of plywood for the Wing mount.
Here some pictures of my plane (small version)
Old Apr 04, 2006, 10:13 AM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
love the wing Roland .. im thinking of changing my goose over to one .. the undercambered is a pain in the Butt (Can we say butt here??) lol
Old Apr 04, 2006, 10:32 AM
Krashlnd is offline
Krashlnd's Avatar
Athens, Tennessee
Joined Jun 2003
WOW!!!! That is awesome. Cant wait to get my depron in to build one out of it.
Krashlnd
Old Apr 04, 2006, 05:05 PM
Krashlnd is offline
Krashlnd's Avatar
Athens, Tennessee
Joined Jun 2003
Remerk,
I have a question about the wing Span. What is the distance from the 1 wing panel to the 2nd panel on the xl plans. It doenst show it anywhere. In your pic did you cut the wing in 3 pcs or 4? I just need to know the length of each pcs.
Thanks Steve
Old Apr 05, 2006, 09:13 AM
rmerk is offline
rmerk's Avatar
Joined Jul 2003
Hi,
At my next Parkflyer i will try this technique.
@Steve: The Wing is built in 3 pieces. One middle panel and one on each side. Each panel has a span of 476 mm (18,74").
Greetings, Roland
Old Apr 05, 2006, 09:37 AM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
its a good method Roland .. when i do make folded wings i do mine the same way except i just use foam for my spar ..
Old Apr 10, 2006, 03:08 AM
Krashlnd is offline
Krashlnd's Avatar
Athens, Tennessee
Joined Jun 2003
Almost Finnished. I have to sand the trailing edges smaller. Kinda thick. I am waiting on 2 BP21s and 2 controllers. What weight are you getting?
Thanks Steve
PS Ill post some pics later
Old Apr 12, 2006, 03:57 PM
Krashlnd is offline
Krashlnd's Avatar
Athens, Tennessee
Joined Jun 2003
All I need to do now is to install the 2 bp21s and brushless controls. I need some info on how to connect the 2 ecs's to the rx. Thanks for the info.
Steve
Build Log Depron Puddle Twin meatbomber Waterplanes 1586 Jun 16, 2016 11:07 PM
Video Depron Puddle TWIN Seaplane meatbomber Electric Plane Talk 20 Dec 04, 2011 06:29 PM
