Old Jan 20, 2006, 06:52 PM
Figure9 is offline
Find More Posts by Figure9
Figure9's Avatar
Granger,IN
Joined Oct 2001
Got to work on the plane a little bit more. Here is what I got so far.
Figure9 is offline Find More Posts by Figure9
Old Jan 25, 2006, 11:15 AM
georgeg is offline
Find More Posts by georgeg
United States, CA, Bakersfield
Joined Jan 2001
Originally Posted by rmerk
Hi,
i am the "Designer" of the Puddle Twin II.
Is there any chance you would be willing to post a version of these plans in .dxf or .dwg format? Your pdf defaults to a size bigger than the plotter I have access to at work. I'm more interested in the larger of the two versions and it would be much easier to plot from AutoCAD than trying to plot from the .pdf file.
georgeg is offline Find More Posts by georgeg
Old Jan 26, 2006, 08:58 AM
rmerk is offline
Find More Posts by rmerk
rmerk's Avatar
Augsburg Muehlhausn, Germany
Joined Jul 2003
Hi,
no problem, please send me your email address. I will convert it.
@Figure9: Nice! Which power setup do you plan to use?
Greetings, Roland
rmerk is offline Find More Posts by rmerk
Old Jan 26, 2006, 09:26 AM
Figure9 is offline
Figure9's Avatar
Granger,IN
Joined Oct 2001
I have 2 BP21's with 8X6 props. For batteries, I'm not sure if I want to use lipos or NiMh. I think the NiMh would be more durable since there is a chance they might get wet. The raw airframe right now is about 450g. I have the motor sticks mounted in the pods, and all surfaces are hinged. My next task is to add the controls for the ailerons. Not sure if I should use 2 sperate servos, or just one in the middle of the wing. This has been a fun project, thanks for the plans.
Old Jan 27, 2006, 08:09 AM
rmerk is offline
rmerk's Avatar
Joined Jul 2003
Hi,
i use 2 lightweight servos for each aileron because i don't like torquerods. A big drawback is you need a powerful BEC to power 4 servos.
It is very nice to see what other people built with my plans. So thanks for the Photos!
Greetings, Roland
Old Jan 30, 2006, 09:18 AM
Figure9 is offline
Figure9's Avatar
Granger,IN
Joined Oct 2001
I'm sure this has been covered before, but can I run both BP21's with one Kontronic Smile 40-12-6 esc? I think the BEC is good for 2A, but I'm not sure it would work on a twin. Has anyone ever tried this with this ESC?
Old Feb 03, 2006, 08:28 AM
JIM CALDWELL A is offline
Find More Posts by JIM CALDWELL A
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
NO!
Each Brushless motor need its own Controller!
Trying to run one controller on two brushless will destroy the controller.
This has been well docutemented, Do a search here.
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Old Feb 24, 2006, 08:03 PM
Figure9 is offline
Figure9's Avatar
Granger,IN
Joined Oct 2001
Puddle Twin
Almost done! Thanks for all the input. I'm using 2 ESC's and a ParkBec. Ran the motors this evening, and seemed to have plenty of thrust. 1250g RTF with 2 3s 2600 lipo's. Now all I need is some water, (warm water).
Old Feb 28, 2006, 05:37 AM
rmerk is offline
rmerk's Avatar
Joined Jul 2003
Hi,
very nice
Did you already maiden it?
Greetings, Roland
Old Feb 28, 2006, 06:26 AM
Figure9 is offline
Figure9's Avatar
Granger,IN
Joined Oct 2001
Xl
No, not yet. I still need to add the wing floats. I hope this weekend I'll have some time to go out to the lake.
Old Mar 18, 2006, 07:18 PM
Figure9 is offline
Figure9's Avatar
Granger,IN
Joined Oct 2001
Well, I guess you can call this a maiden flight. I went out to the side yard just to see if had enough power to pull through the grass. I powered it up and it started skipping on through the empty 1/2 acre lot next to us. Before I knew it, she was in the air. I made 2 passes then landed because my knees were shaking so bad. Just in that short flight I could tell this is going to be fun. I need to get to some water.
Old Mar 23, 2006, 06:39 AM
IWC is offline
IWC
Find More Posts by IWC
IWC
Joined Feb 2003
How will we know when that kit is ready? Very cool!
IWC is offline Find More Posts by IWC
Old Mar 23, 2006, 06:14 PM
Krashlnd is offline
Find More Posts by Krashlnd
Who Put that Tree There?
Krashlnd's Avatar
Athens, Tennessee
Joined Jun 2003
Do you have any more build pictures to share. I am getting ready to cut mine out tonight.
Krashlnd is offline Find More Posts by Krashlnd
Old Mar 23, 2006, 08:09 PM
Figure9 is offline
Figure9's Avatar
Granger,IN
Joined Oct 2001
No, I didn't take anymore pictures, but here are a few pointers:
Cut the top half of the wing a little wider because of the curve of the wing profile.
For the wing spar, I used a carbon arrow shaft imbedded in 3 layers of fff.
On the trailing edge, I sanded the last 1.5" to half thickness, so that when you fold the wing over, the trailing edge will not be so thick.
Before you glue the wing together, glue in some extra material where the wing floats get mounted.
Good Luck
Old Mar 24, 2006, 06:55 AM
rmerk is offline
rmerk's Avatar
Joined Jul 2003
Hello,
nice to hear your plane is maiden
I did not plan to kit this plane. But i am working on a CNC-mill (for a few years ). When i finish her anytime i can think about it to offer a kit...
Greetings, Roland
Build Log Depron Puddle Twin meatbomber Waterplanes 1589 Jul 04, 2016 03:08 PM
Video Depron Puddle TWIN Seaplane meatbomber Electric Plane Talk 20 Dec 04, 2011 06:29 PM
