Old Dec 25, 2010, 04:15 AM
mavlo77 is offline
Find More Posts by mavlo77
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Good idea to not forget that we have to fly is as well ....
I post a video of my mechanism, maybe it's helpful:
Puddle Twin 2 XL retract mechanism (0 min 41 sec)
This video was before I closed the bottom.
mavlo77 is offline Find More Posts by mavlo77
Old Jan 14, 2011, 05:04 PM
bicyclemonkey is offline
Find More Posts by bicyclemonkey
bicyclemonkey's Avatar
Fayetteville, AR
Joined Jan 2010
It would be neat to see a 4-motor version of this. I think this'll be my first plane I build from plans.
bicyclemonkey is offline Find More Posts by bicyclemonkey
Old Jan 15, 2011, 03:03 AM
mavlo77 is offline
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Somebody did this.......
http://www.rcgroups.com/forums/showthread.php?t=919265
Old Jan 15, 2011, 07:41 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Yes, I was following Larry's progress for a while before he kinda shelved it for a bit. I thought about doin that too, but really, where would I store it?
Derek_S is offline Find More Posts by Derek_S
Old Jan 15, 2011, 07:51 AM
mavlo77 is offline
mavlo77's Avatar
The Netherlands
Joined Oct 2008
You could store your other aircrafts IN it ...
Old Jan 17, 2011, 10:24 AM
Fayetteville, AR
Joined Jan 2010
Are there perhaps a copy of these plans that have been written in English?
Old Jan 17, 2011, 01:13 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
NOt that I am aware of, but if you look carefully most everything becomes self explainatory. It is of course in metric measurements. Any particular part you are unsure of? I can look at my marked up plans, I made notes.
Old Jan 17, 2011, 02:35 PM
Fayetteville, AR
Joined Jan 2010
I'm getting ready to start my build. How many sheets of the 6mm and 3mm depron did you end up using?
Old Jan 17, 2011, 07:21 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
I used all FFF so I cant answer that. Hopefully someone else can!
Old Jan 17, 2012, 06:47 PM
Wormboy is offline
Find More Posts by Wormboy
Wormboy's Avatar
Australia, WA, Madeley
Joined Jul 2011
I know its an old thread but the design is too nice to fade away into the archives.
Another Puddletwin IIXL is born.
All cut and dry-fitted. Ready to be glued.
Name: 2012-01-18 07.22.35.jpg
Description:
-Mat-
Wormboy is offline Find More Posts by Wormboy
Old Feb 18, 2012, 01:02 AM
Wormboy is offline
Wormboy's Avatar
Joined Jul 2011
Puddle twin progress.
Fuse and lower wing glued. Just waiting on electrics befoe I close the wing.
I'm thinking of fixing the middle section of the wing to the fuse, complete with the nacelles, semi permanently and allowing the outer thirds of the wing to be removable.
That way i can dismantle it for travel and only have to join the flaperon servos when i'm in the field.
Old Feb 18, 2012, 03:49 AM
mavlo77 is offline
mavlo77's Avatar
The Netherlands
Joined Oct 2008
VERY nice!!! You didn't make dihedral? Looks nearly anhedral?
Still need to finish my Puddle XL... Want to fly it at the float fly-in in April...
Old Feb 18, 2012, 06:48 AM
G550Ted is offline
Find More Posts by G550Ted
Row 0, Seat A
G550Ted's Avatar
Savannah, GA
Fuse and lower wing glued. Just waiting on electrics befor i close the wing.
Thinking of fixing the middle section of the wing with the nacelles semi permanently and allowing the outer thirds of the wing to be removable.
Very nice! Looking forward to more detailed pics as you progress.
Ted
G550Ted is offline Find More Posts by G550Ted
Old Feb 18, 2012, 09:05 AM
Wormboy is offline
Wormboy's Avatar
Joined Jul 2011
Thanks for the compliments folks
Yes, i made the wing without dihedral, I went with ailerons instead.
I agree that it looks like anhedral, but that is just the soggy 2 piece spar.
I have fitted new spars with a strong joiner tube just tonight, Its beautifully straight now and much nicer.
Old Feb 18, 2012, 09:48 AM
mavlo77 is offline
mavlo77's Avatar
The Netherlands
Joined Oct 2008
I see. It's looks cool anyway!
I also plan to make ailerons, so I also will minimize the dihedral. Actually I even was thinking of some nice flaps for scale like effect. But I will only do this when it fits and I can make a very light single servo solution for this.
Build Log Depron Puddle Twin meatbomber Waterplanes 1580 May 17, 2016 12:48 PM
Video Depron Puddle TWIN Seaplane meatbomber Electric Plane Talk 20 Dec 04, 2011 06:29 PM
