Old Jun 17, 2011, 06:31 AM
cgoffa is offline
Find More Posts by cgoffa
cgoffa's Avatar
Joined Dec 2009
power systems
While we are discussing power systems, I run an parkzone f-27c brushless inrunner with a 7x4x3 apc prop and its a blast, I put supercub floats on it and to be honest it flies like a thompson cup racer more than a trainer now
Originally Posted by Jurgen Heilig View Post
I am less worried about broken props, but don't want the prop to strike the waves during take-off from water or do extensive grass cutting on our flying field.
Jürgen
cgoffa is offline Find More Posts by cgoffa
Old Jun 17, 2011, 06:40 AM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Great looking plane, but the flying site is even better! It's hard not to feel envious. Us inner-city types can't hope for much more than some muddy puddle somewhere, and even then access is likely to be restricted.
I can't see a rudder in your photos. Does it steer alright and maintain course during take-offs even without a rudder?
EDIT: After looking a bit more closely, did you add a downward-projecting fin to give it more directional stability?
H2SO4 is online now Find More Posts by H2SO4
Old Jun 17, 2011, 02:40 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
The thing about an overpowerd plane, is that you dont HAVE to use all that throttle.... If you think you might not be able to controll yourself, set the throttle endpoint lower...
dacaur is offline Find More Posts by dacaur
Old Jun 17, 2011, 03:04 PM
Roblister is offline
Find More Posts by Roblister
North West UK
Joined Nov 2010
I did that, but as a safeguard had the lower endpoint switched in. I think I had it too low though as it was struggling to climb out. Thats when I switched back to full power in a hope to get it to climb. As I said in the thread, for some reason the motor cut for a few seconds then went full power. By that time it was pointing at the ground and the inevitable happened.
As a side note. I am just putting the motor back but the holes in the plastic mount glued into the fuselage are a bit worn now. Two of them just go around and around. Other than another mount or larger screws I might be stuck.
Roblister is offline Find More Posts by Roblister
Old Jun 18, 2011, 09:07 AM
cgoffa is offline
cgoffa's Avatar
Joined Dec 2009
mini-mag got back!
Yes I added a 2/32 plywood fin under the main vertical member. If you try to fly on floats without one you will be lucky to land in one piece, I ignored multiplex directions the first time I tired it and got lucky to flop it down in one piece. The rudder that comes on the plane works pretty well for steering at low speed and once the plane is up on step, when it is plowing along you haven't got much control but that phase of take off is short and as long as the floats have some toe in they will track straight during this part of your takeoff run. Believe it or not the flying site is one of Broome County NY's public parks, and its 5 miles from the county courthouse more or less.
Old Jun 18, 2011, 09:42 AM
North West UK
Joined Nov 2010
Yes.
2200kv inrunner + 3S + 6x4E + 30A ESC is just about the most common configuration for both Minimags and EasyStars.
Slight change of plan. My 2200Kv wasn't too well after all. It looks like the last knock it took has done more damage than I thought. Chap at local model shop had used a different motor in his apparently with a lot of success. A Tornado Thumper C2830 850kv outrunner. It's a 280W 20A max motor and should be a bit calmer than the 2200 with a 6x4. I will put a 9x6 slow fly on this motor. Not sure if I should use a 3S or 2S battery though. I know I will need to do a bit of surgery on the mount before it fits.
Old Jun 19, 2011, 04:21 AM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
Definitely 3s.. you will never want to go back to 2s
rcjim11 is offline Find More Posts by rcjim11
Old Jun 19, 2011, 07:49 AM
heymak is offline
Find More Posts by heymak
Long time newbie
USA, TX, Katy
Joined Nov 2006
Don't know if I agree here. The cool thing about the minimag is, on 2s it can be a smooth relaxing flyer and on 3s it can be more sporty. It just depends on what type of flying you prefer. Lately I like mine with 8x3.8 slofly prop on 2s, but my motor esc combo can handle a 7x5 Thin Electric Prop on 3s as well.
heymak is offline Find More Posts by heymak
Old Jun 19, 2011, 08:03 AM
North West UK
Joined Nov 2010
Is that with a similar 850kv motor?
Old Jun 19, 2011, 08:11 AM
heymak is offline
Long time newbie
USA, TX, Katy
Joined Nov 2006
My bad saw the 2200kv, with 850kv you're right, you would probably need a bigger prop than woulld fit the minimag with 2s. 3s is the way to go. Sorry if I cause any confusion.
Old Jun 19, 2011, 10:29 AM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
I fly mine on 3s 1300's with a 400 outrunner that is about 950 KV and an APC 8x3.8 SF prop. It flies fine. Yours will be overpowered, but as someone said, you don't need to use all the throotle just because it is there.
wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old Jun 19, 2011, 12:33 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
I use 3 cell packs on my planes not because I get more power, but becuase I can buy cheaper batteries and cheaper (lower amp) esc's....
In my experience, the same perfomance that takes 20 amps on a 2 cell pack, takes 12 amps on a 3 cell pack so, as an example, I can pay $15 for an 8c 2000mah battery instead of $30 for a 20C 2000mah battery....
Old Jun 20, 2011, 12:59 AM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
I used to fly mostly 2 cells on my parkflyers. Then I discovered that a smaller 3 cell, weighing not much more than the 2 cell, will only need 50-60% power to fly, instead of 80-90%. So it flys about the same duration as the 2 cell, at the 2 cell speed, but you have a bunch of extra power if you need it and the motor is more efficent.
Butch777 is offline Find More Posts by Butch777
Old Jun 21, 2011, 12:43 AM
eagleswings is offline
Find More Posts by eagleswings
Wind Rider
eagleswings's Avatar
United States, CO
Joined Dec 2006
Hi Guys,
I used to have the Mini Mag and loved it! I'm thinking about getting another one soon - just saw that BP Hobbies has the RR version for $79 and thought I would share the price in case anyone else was interested.
The only thing I've ordered from them before was some Easy Star parts and it was a good experience.
Out of curiosity, does anyone know how the MPX Easy Cub or Fun Cub flies in direct comparison to the Mini Mag?
Michael
eagleswings is offline Find More Posts by eagleswings
Old Jun 21, 2011, 06:26 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
I have an Easy Cub. I think is is a better 3 channel plane than the Mini-Mag on 3 channels. It is a very smooth airplane. More dihedral than the Mini Mag
Have not flown my MM on 4 channels yet, so don't know how it compares to the Fun Cub
Wolfe
Skycat from Multiplex RArch Foamies (Kits) 143 Nov 20, 2002 06:01 PM
White Shark from Multiplex Jurgen Heilig Foamies (Kits) 19 May 14, 2002 02:36 PM
Not Just New Pictures, but New TJs from MULTIPLEX James Frolik Foamies (Kits) 0 Feb 02, 2002 03:50 PM
Warning: check postage rates when ordering from Multiplex!! crazythumbs Vendor Talk 5 Jul 13, 2001 11:31 PM
Warning: check postage rates when ordering from Multiplex!! crazythumbs Foamies (Kits) 1 Jul 09, 2001 08:52 PM
