Minimag with navigation lights
This is my Minimag with custom paint and navigation lights installed.
It flyies great, slow and stable and also glides almost as well as an Easystar. Only problem is that it requires a lot of aileron trim (see picture) to fly staright and level. This is both with motor on and off so it's not the thrust angle. Any thoughts ?
Joined Nov 2010
Great plane!! |
Thompsons Stn, TN
Joined Nov 2008
Have you checked the axial balance? Try taping a coin or two under the starboard wing... I'm guessing you've already checked the rudder alignment... Still might fly better with a little right rudder trim, rather than all that aileron. Just some thoughts....
![]() I am not sure how I could check for wing twist but I will certainly check the axial balance. So you recon it is better to compensate wil rudder trim rather than aileron? |
Thompsons Stn, TN
Joined Nov 2008
An easy way to check for wing twist is to tape a length of pushrod, cf rod, etc to a flat area on the bottom of the wing near each wing tip. You can really use anything on hand, as long as it's a foot long or so... I like to use bamboo skewers, since I always have them laying around. Then, with the two "sticks" in place, you can look down the length of the wing and they should align with each other... If they don't, somethings twisted. |
Hey all,
Have been flying the MM for some time now ... Love the little bird ! ![]() First flights i used the permax 400 motor and the standard prop <--- lack of power imo ! After that i tested the 400 motor with a 6/3'' graupner fold prop and 6/4'' APC <--- sound was better, power almost the same :- Then i ordered a towerpro-combo (1000kv) @ HK with a SF prop 8/3.8'' <--- What a difference ! Flew really nice and smooth on 2S lipo ... transformed into a little devil on 3S (vertical take-offs )Think i asked a little to much from the towerpro 2409-12 motor ... windings broke so this 1 wont fly anymore Common problem with this motors so ive heardTested the MM today with a Turnigy TR 35-36A (1450kv) motor and plush 40 Amp ESC / graupner cam fold prop 9/6'' with turbospinner (came from graupner junior s) Was a bit windy so i decided to go with the 3S 2200 mAh lipo ... Take-off after 2 meters followed by a gentil rise to higher air (so far so good )When the MM was high enough to gain confidence, i decided to throttle up ... Nice straight flight with very good airspeed ![]() However, when i turned the MM around (left turn) and tried to make a short pass flyby, the MM didnt respond to the elevator-input i was giving :S I was in a dive to gain some speed (wind from head of plane) and tried to pull up, but no respons ??? Even when throttle was cut ??? Nice crash was the result (how can a crash be nice ?) Damage report : Wing, no damage, only nylon bolt came off (lost the bolt, but hey, who's complaining ) Damn this Elapor is though !!!My question is .... Could the MM been to heavy for the MPX-servo to move the elevator on this speed ? Have the original red MPX servo's that came with the kit installed. AUW was 750 grams ... I know its 1/2 more then stock setup, but i really thought the MM could handle it ... Really could use some info on this problem, cause when i get a nylon bolt the same size, i could try it again, but not to keen on that tbh without some confirmation i'm doing the right thing ! Sorry for the bad English (from Belgium) and you should know i'm not a technician ... just a guy who learned it the hard (crash and repair) way never visited a flying club, maybe i should ... heard that before ![]() Thnx in advance
| Thread Tools | |
| Skycat from Multiplex | RArch | Foamies (Kits) | 143 | Nov 20, 2002 06:01 PM |
| White Shark from Multiplex | Jurgen Heilig | Foamies (Kits) | 19 | May 14, 2002 02:36 PM |
| Not Just New Pictures, but New TJs from MULTIPLEX | James Frolik | Foamies (Kits) | 0 | Feb 02, 2002 03:50 PM |
| Warning: check postage rates when ordering from Multiplex!! | crazythumbs | Vendor Talk | 5 | Jul 13, 2001 11:31 PM |
| Warning: check postage rates when ordering from Multiplex!! | crazythumbs | Foamies (Kits) | 1 | Jul 09, 2001 08:52 PM |
