Old Sep 12, 2010, 06:20 AM
rcjim11 is offline
Find More Posts by rcjim11
rcflyer
UK
Joined Jun 2010
i am using a kda 20-20l 1050kv with a 9x6 prop, i kind of get unlimited vertical but it topples over
jim
rcjim11 is offline Find More Posts by rcjim11
Old Sep 12, 2010, 10:31 AM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
I think you are pretty well at the max performance you can get out of that motor. If you want more, you will need a bigger motor...
Also, a high wing plane like this isnt really made to go "vertical".... that could be part of the problem...
dacaur is offline Find More Posts by dacaur
Old Sep 12, 2010, 11:11 AM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
i also have a turnigy 1100kv version of this one. the actual one doesnt seem to be on HK anymore
http://www.hobbyking.com/hobbyking/s...r_(Eq_AXi_2808)
jim
Old Sep 17, 2010, 12:33 PM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
Found it!
do you think that this will work with the bigger props?
Jim
Old Sep 17, 2010, 02:36 PM
dacaur is offline
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
well. It looks like a 10x5 would work out ok with that motor, but I wouldn't go bigger than that, and even thats pushing it a little.. But I say give it a try, assuming you have at least a 20 amp ESC....
Old Sep 18, 2010, 01:20 AM
rcjim11 is offline
rcflyer
UK
Joined Jun 2010
well i have a 40 amp esc so I recon it should do the job. Thanks
Jim
Old Sep 25, 2010, 10:13 AM
0leur is offline
Find More Posts by 0leur
Southwest VA, USA
0leur's Avatar
Joined Apr 2008
We need sturdier mounts for these MiniMags.
0leur is offline Find More Posts by 0leur
Old Sep 25, 2010, 09:50 PM
donsinger1 is online now
Find More Posts by donsinger1
aka KF7DS
United States, OR, Portland
Joined Nov 2009
Mine takes a lickin and keeps on tickin. I have learned more from my minimag than any other plane I have owned.
Don
donsinger1 is online now Find More Posts by donsinger1
Old Sep 26, 2010, 05:26 AM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
No, you just need to stop using such big props on your motors and practise your landings.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Sep 26, 2010, 05:58 PM
heymak is offline
Find More Posts by heymak
Long time newbie
USA, TX, Katy
Joined Nov 2006
Jürgen
While I normally agree with Jürgen, an aluminum motor mount does help out. I used this plane as a beginner and often had prop strikes when I landed using a 7 x 5 prop. After my stock mount broke I replaced it with a homemade aluminum one and using that in addition to a prop saver has made things much more fun. No more bent motor shafts or broken mounts. I do agree about his statement about too big props and motors. The minimag design can only take so much power before you've over done it.
heymak is offline Find More Posts by heymak
Old Sep 26, 2010, 07:06 PM
GassPasser is offline
Find More Posts by GassPasser
Pro Bro # 2398
GassPasser's Avatar
BoonVegas, Indiana
Joined Dec 2005
they do make aluminum motor mounts for the MM. i got one. google MM motor mounts or something like that. it was like 6 or 7 bucks.
GassPasser is offline Find More Posts by GassPasser
Old Sep 27, 2010, 12:35 AM
Joined Sep 2000
Originally Posted by heymak View Post
I used this plane as a beginner and often had prop strikes when I landed using a 7 x 5 prop. ...
Don't forget that the stock mount was designed for Permax 400 motors with 2.3mm shafts spinning 4.9"x4.3" flexible Günther Props. A new plastic mount is cheaper than a new motor.
That being said, I never had a problem with the stock mount even when going Brushless and using a GWS 8x4" HD.
Jürgen
Old Oct 19, 2010, 04:16 AM
gharar is offline
Find More Posts by gharar
Joined Feb 2009
i just bought a SPEKTRUM DX6i DSM2 2,4 ΤΧ for my MiniMag and other small planes. Do you think it is safe to fly the MiniMag with the AR6100E receiver (Microlite Parkflyer Rx)?
It is a park flyer receiver and it's small size (only 4,4gr) makes me feel unsafe. The description is: ''receiver for most any small electric model from mini profile foamies to 400 class helis'' .
Thanks in advance.
gharar is offline Find More Posts by gharar
Old Oct 19, 2010, 07:06 AM
heymak is offline
Long time newbie
USA, TX, Katy
Joined Nov 2006
Thanks in advance.
I've been using one for years with no problems. I don't fly so far that it's hard to see the plane though. I like seeing the airplane with out straining my eyes when I fly.
Old Oct 19, 2010, 09:17 AM
outngo is offline
Find More Posts by outngo
E-Gliders
outngo's Avatar
South Carolina
Joined May 2009
Thanks in advance.
That is a perfect rx for the plane.
outngo is offline Find More Posts by outngo
Skycat from Multiplex RArch Foamies (Kits) 143 Nov 20, 2002 06:01 PM
White Shark from Multiplex Jurgen Heilig Foamies (Kits) 19 May 14, 2002 02:36 PM
Not Just New Pictures, but New TJs from MULTIPLEX James Frolik Foamies (Kits) 0 Feb 02, 2002 03:50 PM
Warning: check postage rates when ordering from Multiplex!! crazythumbs Vendor Talk 5 Jul 13, 2001 11:31 PM
Warning: check postage rates when ordering from Multiplex!! crazythumbs Foamies (Kits) 1 Jul 09, 2001 08:52 PM
