Joined Sep 2006
Installing Floats on MM?
I just picked up a MM with the intent to fly off water using the Mutiplex floats.
I have not build the plane yet, as I am a little confused about the water rudder installation. The instructions suggested that the tail wheel must be installed, because the water rudder uses parts of the tail wheel. Do I need the tail wheel kit? My plan was to get her flying and trimmed with the stock landing gear, then install the floats. I am concerned that if I glue the fuse and install the landing gear, I will not be able to install the water rudder? Hopefully someone understands my question. I did see the post about using tape instead of glue, but I'm still not sure how to install the rudder. Thanks for your help, I'm looking forward to getting my MM feet wet! |
I did the tail-wheel. I believe for the water rudder you need to shape a piece of depron with the wire around it and use that. I think there is a template for it in the instructions. If you glue the fuse it will make installing a rudder or tail wheel difficult as the wire needs to pass through the fuse. I used some plastic tube through the fuse as a sleeve to keep the wire aligned and give it some strength. I used a short segment of plastic tube in the rudder itself with the wire glued in. Once I had everything aligned and ready I glued it all (stab, rear fuse, tailwheel) at once with foam safe CA. The wheel has held up to some pretty good abuse. A water rudder should experience less traumatic force.
Hope this helps-let me know if you need more pics. -Jon |
Worcester, Massachussetts, United States
Joined Feb 2003
Russ |
My MM arrived today. Much better all round quality than the E-Starter.
Anyway I might give those decals a miss and put something a liitle more conservative on the plane. A little paint will take away that boring white foam look also. There are a few US Army red and white Bird Dog pics on this thread-very nice. Maybe something like that. |
Joined Sep 2006
Thanks echoplanar. I do not have the tail wheel kit. Does that mean I should install the water rudder now, before I join the fuse halves, even if I intend to install the float later?
You are correct, the floats come with a template and a piece of stiff wire. Bend to shape, press over the included piece of depron, then trim to fit. If you have photos showing how the wire connects the wheel to the rudder, that would be helpful. Thanks again. |
The water rudder will drag on the ground and get destroyed if you attach wheels first. If you want to start with wheels and then have a water rudder you would need to mod the tail wheel so you could interchange a wheel and water rudder. This would require something outside of the template but is doable especially if you remove the wheel and do a more permanent water rudder when you are ready.
Perhaps someone else will chime on the real need for the water rudder-maybe you could taxi on water with just the rudder so long as there is enough speed. Slow speed taxiing would not work well though. -Jon
btw: another good tip I found is to use paper towels under the masking tape to prevent bleed over..
Joined Sep 2006
Thank you for posting the photos of the tail wheel, very helpful.
I can see how it would be difficult to install the water rudder after the fuse is sealed. Not sure what to do. I'd rather not maiden over water. I suppose I can fly over grass with the floats installed? Anyone tried landing on grass with the floats, or is that just asking for trouble? |
Jürgen
Latest blog entry: 12th. German- / 1st. European Indoor...
http://airtoimedia.nl/web/upload/Jur...Mag-floats.wmv Jürgen
-Jon |
Jürgen
| Thread Tools | |
| Skycat from Multiplex | RArch | Foamies (Kits) | 143 | Nov 20, 2002 06:01 PM |
| White Shark from Multiplex | Jurgen Heilig | Foamies (Kits) | 19 | May 14, 2002 02:36 PM |
| Not Just New Pictures, but New TJs from MULTIPLEX | James Frolik | Foamies (Kits) | 0 | Feb 02, 2002 03:50 PM |
| Warning: check postage rates when ordering from Multiplex!! | crazythumbs | Vendor Talk | 5 | Jul 13, 2001 11:31 PM |
| Warning: check postage rates when ordering from Multiplex!! | crazythumbs | Foamies (Kits) | 1 | Jul 09, 2001 08:52 PM |
