Old Jun 04, 2002, 10:14 AM
Mitch G is offline
Find More Posts by Mitch G
Mitch G's Avatar
Naperville, IL USA
Joined Nov 2000
How about a power system database?
I was wondering if it would be possible to create a database in which MEASURED setups could be input by folks for other folks to look at. It would be like a reality-based e-calc type of thing. Call it: real-calc.
The required fields for each record would be:
Motor Make (e.g. Graupner, Mega, Jeti, Hacker, etc.)
Motor Model (e.g. sp400, 22/30/3, B40-8S, etc.)
Gearing (if any) (e.g. none, 2:1, 4.6:1, etc.)
Prop Make and Model (e.g. APC-E, APC-Slow, Graupner CAM, etc.)
Prop Size (e.g. 12x8, 14x7, etc.)
Number of cells
Make of cells (e.g. Sanyo RC2400, Panasonic 3000, etc.)
Type of cells (e.g. NiMH, NiCad, Li, etc.)
Then, at least one (if not more) of the following fields would have to be populated:
MEASURED current
MEASURED RPMs
MEASURED thrust
Over time, the E-zone would have a nice, centralized database of real-life information. This would be great info if thinking about a given setup that's in the database. But, it would also be helpful when using calc programs to see how they compare to real life and then use that information to "refine" other calculations.
Mitch
Mitch G is offline Find More Posts by Mitch G
Old Jun 04, 2002, 11:28 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Measured? Where, in flight? Not many of us are able to do that.
Static tests don't really mean anything.. so the data would be of little use.
As far as in-flight performance, there are so many combinations, the DB would be huge. Fortunately there are at leat two commercial software packages (motocalc and electricalc) that can compute everything for us, and, despite the complaints, they both do a great job of predicting power and thrust at particular airspeed (which DOES matter) for every motor, cell, GB and prop combo you could come up with. The prediuctions are accurate to within a few % - limitations include GB losses and prop factors, which are not accurately measured and vary from system to system. There are also free versions - online web databases, that are not as flexible, but certainly able to provide the info. you are looking for - PCalc from Diverity Model Aircraft is just one example..
It's more interesting for members to post their power system experiences along with the models they used them in - in the gallery would be a great place to do this - I try to include this information in my own "gallery" page of model - click on the www link below to see what I mean.
..a
Old Jun 04, 2002, 01:55 PM
Mitch G is offline
Mitch G's Avatar
Naperville, IL USA
Joined Nov 2000
First of all, I meant static measurements. I figured most of us have at least a Whattmeter and many of us have tachometers as well. I also bet that most of us take current and RPM measurements when we install a new power train in a plane. So, I figured, why not provide a place to centrally store this wealth of knowledge.
I'm aware of the calc programs and use Motocalc a great deal. In fact, it is my experience with these programs that further supports the need for real world, measured data. For example, I've seen discrepancies between measured current and predicted current on the order of 20% (21A predicted vs 26A measured). So, just having data about the current draw of a setup would allow me to refine my interpretation of the calc program output. And, I figured, if the user is also able to provide RPMs and in the rare case thrust numbers, this would help folks even more. Furthermore, having a database as such may help the calc program developers refine their algorithms, which would only benefit us e-filers all the more.
My bottom line is that real world data is always useful even if it is not the complete picture.
As far as how much disk space such a database would require - I leave that up to the E-zone management to ponder as part of their benefit-vs-cost decision regarding this suggestion.
Mitch
Old Jun 04, 2002, 10:08 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Disk space would not be an issue.
..a
Old Jun 04, 2002, 11:01 PM
jbourke is offline
Find More Posts by jbourke
Administrator
jbourke's Avatar
United States, OR, Corvallis
Joined Nov 1998
I think its a neat idea. Its actually on the to-do list, but in a slightly different format than envisioned here.
We don't have a problem with disk space or anything like that. The real issue is money. I don't have the free time to devote to custom coding on the site right now, so I would have to contract someone out. This is expensive, so I reserve that for when we have a pressing need.
Jim
jbourke is offline Find More Posts by jbourke
Administrator
Old Jun 04, 2002, 11:35 PM
Mitch G is offline
Mitch G's Avatar
Naperville, IL USA
Joined Nov 2000
Thanks for the response. I'm glad to see the basic idea is already on the to-do list. But, I understand the need to prioritize.
Mitch
Old Jun 11, 2002, 01:47 PM
Arbo is offline
Find More Posts by Arbo
Joined May 2000
Arbo is offline Find More Posts by Arbo
Reply With Quote  (Disabled)
Old Jun 14, 2002, 12:42 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
As Andy pointed out, the static measurements are of relatively little value in telling you about the in flight performance. Props can vary quite a bit, and you'd also need to record temperature, humidity and altitude if you are going to compare thrust.
The reason the calcs are so useful is that there are thousands of combinations of props, batteries and gear ratios for a single motor. High static thrust is a very poor way to choose among them.
There have been a number of compilations of "What Works" -- combinations of gear in successfully flown planes.
http://members.aol.com/KMyersEFO/page38.htm Good and bad.
http://www.slewin.clara.net/elec/sfreviews.htm
http://home.ptd.net/~rcm65/whatwork.html
Rick.
rpage53 is offline Find More Posts by rpage53
Old Jun 18, 2002, 02:06 PM
Arbo is offline
Joined May 2000
No Response...
Old Jun 18, 2002, 02:36 PM
jbourke is offline
Administrator
jbourke's Avatar
Joined Nov 1998
Re: No Response...
Originally posted by Arbo
I guess I'll have to take a lack of response as a negative.
Sorry about that. Sometimes I just don't pay attention very well. Due to "thread drift" I sometimes tune out of discussions and miss important things. You should post a new thread to get my attention.
I'd love to have your help. We use PHP and Mysql extensively. If you are familiar with those tools you can dig in during your free time.
I have to get to know you a bit before you can have access to our servers, though.
Jim
Administrator
Old Jun 18, 2002, 06:37 PM
Stregone is offline
Find More Posts by Stregone
Stregone's Avatar
Manassas, VA, USA
Joined Feb 2002
Static test are a good way to compare different setups. You can also take things into consideration and use your experience to infer how it will behave in the air.
Stregone is offline Find More Posts by Stregone
Old Jun 18, 2002, 08:35 PM
Arbo is offline
Joined May 2000
Jim...
Old Jun 18, 2002, 09:54 PM
Stregone is offline
Stregone's Avatar
Manassas, VA, USA
Joined Feb 2002
I think a good idea would be predefined selections for the components with an 'other' box you can fill in if you have something odd. Also predefined selections for the measurement unit, so that you could automaticaly convert it and users could select what unit they wanted a certain measurement in.
Old Jun 19, 2002, 12:18 AM
Mitch G is offline
Mitch G's Avatar
Naperville, IL USA
Joined Nov 2000
I think predefined options for the inputs would help searches since the system designations would be consistent.
I would be concerned that an "other" option would deteriorate into a bunch of non-predefined options. Instead, I would like to see the user be able to send an email indicating when things aren't available in the list and then have them put in officially.
Obviously this makes extra work for the person maintaining the tool, but I think it will make the database all that more useful.
Mitch
Old Jun 19, 2002, 02:43 AM
Arbo is offline
Joined May 2000
So....
Discussion question about my slow stick power system chase4556 Power Systems 0 Jan 14, 2006 01:56 PM
How about 3 blades on High power systems ? Protocooler High Performance 10 Oct 22, 2005 02:50 PM
Rave Whats so good about your power system ?. spankedchrome Power Systems 22 Oct 20, 2005 06:28 PM
HOW and WHY do you choose a power system for an aircraft? (Antic e-conversion) steve crewdog Power Systems 17 Jun 20, 2005 01:54 PM
Poll: MP-AP Power System and how many flights? thinair7000 Aerial Photography 0 May 24, 2005 03:27 PM
