Old Dec 20, 2005, 10:18 AM
jtraxler is offline
Find More Posts by jtraxler
Exline, Iowa,
Joined Dec 2005
easy way to use hi start
If any of you are like me, getting older and not able to pull back the hi start and hold the radio at the same time, perhaps you would be interested in building your own hi start launch platform. This has made it easier for me to enjoy my sailplanes. If you would like some information about how it is designed and how well it works, just post your questions. I will add a picture of a NSP Defiant sitting on the launch. I don't have the packing tape covering on it in the picture. The launch is for sailplanes that have a flat bottom area. I have used it on the Sig Riser and the House of Balsa 2x4. I know it would work great on the Gentle Lady. It just makes it possible for me to fly my sailplanes by myself because I can't pull the hi start back and hold it to get a decent launch.
It's inexpensive to make, and I just used some scrap lumber I had available. It will launch a sailplane in strong breezes or even no breeze at all. It's given me a chance to keep flying the sailplanes.
Jim
jtraxler is offline Find More Posts by jtraxler
Old Dec 20, 2005, 11:35 AM
Yardbird is offline
Find More Posts by Yardbird
Yardbird's Avatar
Northford, CT
Joined Feb 2005
Originally Posted by jtraxler
If any of you are like me, getting older and not able to pull back the hi start and hold the radio at the same time....
Isn't that what grandkids are for?
Yardbird is offline Find More Posts by Yardbird
Old Dec 20, 2005, 12:19 PM
jrgospod is offline
Find More Posts by jrgospod
jrgospod's Avatar
Fort Wayne, IN
Joined May 2002
Jim,
Good for you! I have seen foot pedal type of stations, but they are all at ground level. You have elevated the idea to new heights. Now all you need is a retriever so you donít have to pull the line back. Keep of flying!
John
jrgospod is offline Find More Posts by jrgospod
Old Dec 20, 2005, 12:57 PM
jojoen is offline
Find More Posts by jojoen
jojoen's Avatar
Norway
Joined Dec 2003
And that's the main important thing. To keep flying sailplane models. I hope I never stop doing that!!!
A little more expensive but...
http://www.git-r-built.com/imagemgr/...&box=&shownew=
jojoen is offline Find More Posts by jojoen
Old Dec 20, 2005, 02:01 PM
jrgospod is offline
jrgospod's Avatar
Fort Wayne, IN
Joined May 2002
jojoen
Now your talking. Put that in a lot next to a QD (with curb servics) under a canopy and I'll be on my way.
John
Old Dec 20, 2005, 11:32 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Jim,
That looks like a great design. Can you explain it it more detail?
What is the release mechanism?
Do you place the plane and then pull hte hi-start and attached it?
What size hi-start are you using?
aeajr is offline Find More Posts by aeajr
Old Dec 21, 2005, 10:10 AM
jtraxler is offline
Exline, Iowa,
Joined Dec 2005
Aejar
As the picture shows it's just a platform on a stand that has a little slope. There can't be too much slope or the sailplane will bind under the pressure and not release from the platform. I don't know the exact rise that I used, but I expect it's about 3 inches in a 30 inch platform.
The release device is just a compression spring inside a 2x4 block with a 1/8 threaded rod going through the whole thing. I will include a drawing I just made moments ago to give you an idea as to how it works. The rod extends about a half inch above the platform to insert into a hole in the plane that is five inches behind the tow hook.
I just stretch my hi start and place it on a hook on the front of the platform. Then I place the plane on the pin, hook the hi start to it, check my radio, and then step on the release and watch it go skyward.
Of course, I use a hard wood block on the plane where the pin goes through. On most models you can put it inside where it's not noticed, but with the House of Balsa 2x4 it has to be on the outside to make up for the slope in the body of the plane.
Here are a few pictures. I left the drawing large so that you can easily read it. Hope this give you some idea as to what I use. My hi start is just homemade. I bought some latex tubing from the local hospital and used 150 pound dacron kite line. The tubing is 50 feet of 3/8 with 1/16 walls. I use a 125 feet of line. I stretch it another 100 feet or more.
Jim
Old Nov 30, 2007, 07:54 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
I thought this great launch platform was something people would like to see again.
Old Nov 30, 2007, 09:42 AM
spinolio is offline
Find More Posts by spinolio
SoarNut
spinolio's Avatar
United States, MI, Kentwood
Joined Apr 2005
I'm glad you did, this is very interesting. I have a bad left knee and this would be a great solution.
spinolio is offline Find More Posts by spinolio
Old Dec 05, 2007, 01:44 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Any reason this could not work with a winch?
Old Dec 05, 2007, 01:55 PM
jbeanelliott is offline
Find More Posts by jbeanelliott
United States, WA, Orondo
Joined Feb 2003
Is there a reason it needs to be so high off the ground other than not needing to bend over to ready your glider?
(It would save room in my car if I the legs were only 3 inchs or so high.)
-John Elliott
jbeanelliott is offline Find More Posts by jbeanelliott
Old Dec 05, 2007, 02:08 PM
Liberator is offline
Find More Posts by Liberator
Joined Apr 2006
-John Elliott
You could make the legs either detachable or telescoping to make it more portable.
Jtraxler, do you have any idea what the pounds of pull is at the hook? So in other words when you are ready to place the line fully stretched onto the device, how many pounds of pull are you at?
Tom
Liberator is offline Find More Posts by Liberator
Old Dec 06, 2007, 09:05 PM
flyboyjimi is offline
Find More Posts by flyboyjimi
The sky is my playground
flyboyjimi's Avatar
Near the Ocean in Hunt. Beach Calif.
Joined Apr 2006
66666
flyboyjimi is offline Find More Posts by flyboyjimi
Old Dec 06, 2007, 09:06 PM
flyboyjimi's Avatar
Joined Apr 2006
90909
Old Dec 08, 2007, 02:12 PM
onethermal is offline
Find More Posts by onethermal
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
The main reason I see that it might not work with the winch is that you could not control the line tension before relese...Hi-Start would hold a constant tension on the line before relese.
the thought of winch is a good one but you would be better off doing a hand launch with the winch.
Clarence
onethermal is offline Find More Posts by onethermal
Learning to use a hi-start aeajr Thermal 485 Jul 15, 2016 12:54 PM
Easy Hi-Start Launch Roger K Slope 5 Dec 05, 2007 02:52 PM
Zagi: Way to use 1400SCR packs? Dan H. Foamies (Kits) 4 Dec 03, 2001 09:54 AM
Easy way to break in a .61? KMKAZE Life, The Universe, and Politics 4 Nov 24, 2001 08:00 AM
How can I make a hi-start?...I've got the materials kiwip Electric Sailplanes 6 Jul 02, 2001 10:14 AM
