Old Dec 20, 2005, 08:37 AM
Brownwood is offline
Find More Posts by Brownwood
The Colony TX
Joined Jun 2005
Balsa Products test stand
I saw a little test stand on the BP website that included a simple lever system and a a scale to measur thrust. Anyone have any experience with these or plans for something better? How accurately would this measure thrust? I assume it would probably work for relationship purposes.
Brownwood is offline Find More Posts by Brownwood
Old Dec 20, 2005, 01:57 PM
Valid8r is offline
Find More Posts by Valid8r
Valid8r
Valid8r's Avatar
Boston and Belgium
Joined Jul 2004
This design has been around for some time and the kit is a simply constructed and functional system. It measures thrust well. If you do a search in the construction forums you'll find more plans for the same idea, but then you've got to go and cut all the pieces and ensure 90 degree alignment. I've bought and used the unit a lot for testing motor thrust - I like it.
Jon
Valid8r is offline Find More Posts by Valid8r
Old Dec 20, 2005, 06:59 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
You can try making this one - I've calibrated it carefully and it is accurate. The BP one, to my mind, is a bit narrow and I'm not sure how frictionless it is (mine uses high quality ball-bearings for the axle).
http://www.rcgroups.com/forums/showthread.php?t=421578
Dr Kiwi is offline Find More Posts by Dr Kiwi
How can I reach Balsa Products? krajesj Electric Plane Talk 5 Dec 26, 2007 11:34 AM
Whick flight pack..tha GWS, or the one at balsa products. ramw5p Parkflyers 5 Aug 06, 2001 08:16 PM
Anyone use the new S1 IPS on the DustStik from Balsa Products? EFoil Parkflyers 7 Jul 30, 2001 03:44 PM
geared 280 from Balsa products fill Parkflyers 3 Jun 20, 2001 12:38 AM
Balsa Products t-turley Parkflyers 14 May 31, 2001 09:20 AM
