Old Dec 20, 2005, 08:11 AM
Guest
n/a Posts
Long range light weight radio modem for a small UAV
Can I ask some expert advice to select radio modems to be used in a small
UAV (a model airplane infact) ?
Desired specs for the radio modem;
o Range : 5km (or more)
o Weight : Lighter than 150gm
o Data rate: 56-115.2K bits/sec
o Interface : RS232 (and/or TTL)
o Price : Must satisfy budget constraints of five uni students (ie. as
low cost as possible)
Old Dec 20, 2005, 12:11 PM
Doug McLaren
Doug McLaren
Guest
n/a Posts
Re: Long range light weight radio modem for a small UAV
In article <43a80b79$1$18197$afc38c87@news.optusnet.com.au> ,
| small UAV (a model airplane infact) ?
You can, but I'd think that one of the ham radio groups would be a
better choice, as anything you find that meets your specifications is
likely to be on the ham band.
Without using ham band equipment, your best bet might be a cell phone
with a modem of some sort.
That 5+ km requirement is the problem -- you can find 900, 2400 and
5800 MHz radio gear that will give you the desired data rate, but
their ranges are likely to be less than one km due to the very limited
power.
(I'm assuming that the situation is the same over in Australia as it
is here in the US. I don't know for sure.)
And then there's the issue of a UAV. Over here in the US, the FAA
generally leaves us modelers alone, as our planes are always under
direct control and in visual range. But UAVs operate under different,
far more restrictive rules, and while the line between the two is
rather vague, it's generally less about size and more about how the
plane is controlled and how far away it can operate. If your plane
was 5 km away, I seriously doubt the FAA would consider it to be a
normal model airplane anymore.
Maybe things are signifigantly different down under. But I doubt it.
Doug McLaren, dougmc@frenzy.com
Cable. It's more wonderful than I dared hope. --Homer Simpson
Old Dec 20, 2005, 06:11 PM
Lyman Slack
Lyman Slack
Guest
n/a Posts
Jeff -- You might contact the Aeronautical Engineering group here at the
University of Florida http://www.ufl.edu They have been designing UAVs for
some years now and compete and have won in the worldwide competitions. I
believe the latest winner had a maximum dimension in any direction under 5"
and carried a TV camera and transmitter -- it was flown with virtual
goggles. Drop me a note and I'll give you the addy of one of their
professors.
Cheers -- \_________Lyman Slack________/
\_______Flying Gators R/C___/
\_____AMA 6430 LM____ /
\___Gainesville FL_____/
Visit my Web Site at www.LymanSlack.com
<Jeff Rina> wrote in message
news:43a80b79$1$18197$afc38c87@news.optusnet.com.a u...
Old Apr 14, 2009, 04:39 AM
Owild1 is offline
Find More Posts by Owild1
Joined Mar 2008
http://www.xtremepowersystems.net/index.php It is the best and most cost effictive
Owild1 is offline Find More Posts by Owild1
Radio Control for UAV, What do you use and how much range do you get ???? JettPilot UAV - Unmanned Aerial Vehicles 17 Apr 14, 2009 12:47 PM
Found Light weight brushless and esc for Switchback 1987tc Aircraft - Electric - Power Systems (FS/W) 3 Aug 06, 2007 10:56 AM
Wanted Long range Micro Rx 15g and under for Futaba Radio nbj6879 Aircraft - General - Radio Equipment (FS/W) 0 Dec 01, 2005 05:41 PM
Need light weight folding prop for sp 400 aireze Electric Sailplanes 3 Oct 26, 2002 12:21 AM
Looking for light weight/full-range receiver Danny Van Hoecke Electric Plane Talk 3 May 03, 2002 07:23 AM
