Old Dec 19, 2005, 03:20 PM
IronKnees is offline
Find More Posts by IronKnees
IronKnees's Avatar
Indiana
Joined Nov 2005
Pressurized fuel tank question..
Everything that I have uses a pressure line from the muffler to the fuel tank... I just installed a new engine in my 1/4 scale Sig Cub and got a J'Tec in-cowl muffler for it... This muffler does not have a fitting for that line going into the tank... Can I simply plug that line and forget about it, or do I need to raise that like up above the fuel level like way back in my U/C days...??? Thanks in advance. Signed; Confused Dave
IronKnees is offline Find More Posts by IronKnees
Old Dec 19, 2005, 05:05 PM
Maineiac63 is offline
Find More Posts by Maineiac63
Maineiac63's Avatar
Blissfield, Michigan
Joined Apr 2005
You shouldn't really need to pressure the fuel tank, however if you seem to have a problem then perhaps you might. what I would do is run the engine and see how it runs without pressure - you may find that you're good to go. If on the other hane you find that she doesn't perform the you can take measures to add pressure. I have a few 1/4 scale Sig cubs and I run pressure because the nipple is on the muffler, otherwise I would try things without and see what happens.. two of mine have 120 Saitos, one has a 150 Saito - but one has the O/S 160 Gemini twin (without pressure) and it runs super fine, maybe yours will also. Jim
Maineiac63 is offline Find More Posts by Maineiac63
Old Dec 19, 2005, 05:06 PM
jfacky is offline
Find More Posts by jfacky
What goes up must come down
jfacky's Avatar
USA, GA, Snellville
Joined Oct 2005
I think you will need to drill and tap the muffler for the pressure feed, depending what type of engine it is. If it's a pumped and regulated engine try this page. I know it's for YS, but it should help.
http://www.probuild-uk.co.uk/factsheets/ys_engines.php
JIM
jfacky is offline Find More Posts by jfacky
Old Dec 19, 2005, 05:18 PM
Maineiac63's Avatar
Joined Apr 2005
1/4 scale cubs
A couple more pictures of my cubs
Old Dec 19, 2005, 05:20 PM
IronKnees's Avatar
Indiana
Joined Nov 2005
The new engine is an OS .91 ...
Old Dec 19, 2005, 05:24 PM
Maineiac63's Avatar
Joined Apr 2005
A bit light on engine for the 1/4 scale cub, huh? Is it a two stroke?? I sent you a PM , check at top of page for private message from me - Jim
Old Dec 19, 2005, 05:29 PM
IronKnees's Avatar
Indiana
Joined Nov 2005
I flew it for quite some time with an old OS Max .61 and it flew just fine... It didn't "struggle" for altitude, but it didn't clime fast either... Once at altitude and throttled back, it looked and sounded very real... From that I know the .91 will be fine...
Old Dec 19, 2005, 05:32 PM
Guille is offline
Find More Posts by Guille
look mamma, I can Fly!!!
Guille's Avatar
Italy
Joined Aug 2005
mmmm I'd pressure the tank as JIM says... I'll ensure a nice fuel flow in any condition. Besides, I doesn't requires much work/money.
Cheers!
Guille is offline Find More Posts by Guille
Old Dec 19, 2005, 05:38 PM
IronKnees's Avatar
Indiana
Joined Nov 2005
Cheers!
I'll probably give it a go using that line as a vent, but if it's necessary drilling and tapping for a fitting is no big deal...
Old Dec 19, 2005, 05:54 PM
DGrant is online now
Find More Posts by DGrant
DGrant's Avatar
United States, CA, Clovis
Joined Mar 2004
I don't know if you specified a 2stroke or 4stroke.... it really does make a diff though... a 2stroke will run WAY more consistently with a pressure line from the tank, whereas a 4stroke doesn't necessarily need pressure for consistency and usually runs just fine without pressure. Dubro makes the fittings you need, in different sizes.. just get the one that matches your engine/tank so your assured uniform fits on everything.
DGrant is online now Find More Posts by DGrant
Old Dec 19, 2005, 06:25 PM
indoruwet is offline
Find More Posts by indoruwet
God's gift to mankind for flying anything.
Joined Aug 2004
When you do decide to add a pressure nipple, just look where it would fit nicely and easily installed. Make sure that is somewhere high above the mean center of the exhaust, and close to the inlet. The 8-32 sized one is the easy one, not too small.
HTH.
indoruwet is offline Find More Posts by indoruwet
Old Dec 19, 2005, 07:46 PM
IronKnees's Avatar
Indiana
Joined Nov 2005
2 stroke
Old Dec 19, 2005, 09:31 PM
downunder is online now
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
Almost every 2 stroke nowadays needs muffler pressure because the manufacturers use too large a carb so they can claim high HP at astronomical revs to sell their engines. Too large a carb doesn't want to draw fuel so they use the muffler pressure to force fuel from the tank. They'll still run perfectly without muffler pressure on the bench but the needle needs to be opened much more than normal. In flight though you can go very lean with the nose up or even just running the tank near empty (after it's been tuned with a full tank).
If you try it without muffler pressure then don't block that line unless you've got a third vent line (the air has to get into the tank from somewhere ).
downunder is online now Find More Posts by downunder
Old Dec 19, 2005, 09:54 PM
IronKnees's Avatar
Indiana
Joined Nov 2005
Problemo el solvedo....... I took a fitting out of an old muffler, found the right size bit, drilled, tapped with a same size thread screw, and now I have pressure other than that which my wife bestows upon me...
Old Dec 20, 2005, 06:04 PM
Maineiac63's Avatar
Joined Apr 2005
Well since it's a 2 stroke 91 O/S I see no problem with the power. Those engines were some strong - I still have one from a Cessna 182 which was plenty powerful! on the other hand the 91 Surpass 4 stroke would be a bit weak such as the one on my Tweety Bird - ya gotta make sure the valves are right on with 4 strokes which isn't an issue with 2 strokes...I am more into 4 strokes myself, however I still have quite a few 2 strokes that do just fine. I've been around the model plane business for over fifty years - such a fun hobby!! I'm just setting up the bench for another Winter building session - took delivery of a couple of C G Anniversary Cubs and a Bird Of Time Glider last evening from Tower Hobbies. So I'd better get busy !!
Fuel Tank Question docb64 Giant Scale Airplanes 1 Apr 21, 2004 06:02 AM
Pressure fuel tank question. bigbear3721 Fuel Plane Talk 1 Jan 11, 2004 05:43 PM
Glow fuel tank question... Arbo Fuel Plane Talk 7 Nov 27, 2003 10:16 AM
Question correct hookup for pressurized fuel tank ricfoust Engines 4 Oct 15, 2003 08:39 AM
