Old Dec 19, 2005, 02:05 PM
Velocity-8 is offline
Find More Posts by Velocity-8
Velocity-8's Avatar
Idea
EZ fix for the Blade CX lower rotor head pivots
This is an easy fix for any of the many people here that have snapped the blade pivots off the lower rotor head.
Remove the lower rotor head piece from the heli and drill a 5/64 hole through the part were the blade holder stalks used to be.
Cut 2 pieces of 5/64 linkage wire approximately 3/8 long. I cut the pieces off a broken inner shaft instead of lingage wire.
Slide the lower rotor head back on and insert the wire into the holes. Use a small drop of thin CA at the base of the wire. Remove from outer shaft and let dry before re-installing.
It did this fix yesterday since it will be at least three more days until my replacement part came in. My BCX is back in the air and flying good!
Velocity-8 is offline Find More Posts by Velocity-8
Old Dec 19, 2005, 02:26 PM
dribbe is offline
Find More Posts by dribbe
dribbe's Avatar
United States, FL, Venice
Joined Jan 2005
Are you sure it is 5/16? (not 5/64 or something?)
David
(Looks like the original is edited now! )
dribbe is offline Find More Posts by dribbe
Site Sponsor
Last edited by dribbe; Dec 19, 2005 at 05:00 PM. Reason: Post I was responding too was edited
copperclad is offline
Find More Posts by copperclad
Coaxially Fixated
copperclad's Avatar
Rochester N.Y.
Joined Oct 2005
hi
sounds like a good fix , thanks for posting , dana
copperclad is offline Find More Posts by copperclad
Old Dec 19, 2005, 02:59 PM
Velocity-8's Avatar
David
Opps! Sorry about that! I meant 5/64. I'll edit the post.
Old Dec 29, 2005, 02:20 AM
aeronuts is offline
Find More Posts by aeronuts
aeronuts's Avatar
USA, WV, Charles Town
Joined Mar 2005
Check out 3vw's fix:
http://www.rcgroups.com/forums/showp...5&postcount=18
I'm gonna try this one next.
aeronuts is offline Find More Posts by aeronuts
Question how do you replace the lower rotor head on a axe ez? howrd Mini Helis 1 Jun 04, 2007 05:59 PM
Wanted Lower Rotor for Blade CX dasdef Aircraft - Electric - Helis (FS/W) 3 Mar 18, 2007 05:37 AM
Discussion Cx Lower Rotor Head Help rolo Coaxial Helicopters 4 Oct 29, 2006 07:18 PM
Discussion Blade CX lower rotor head screws won't thread theblade Coaxial Helicopters 2 Oct 24, 2006 03:02 PM
Discussion blade cx lower rotor head fix anthony77 Coaxial Helicopters 2 Dec 30, 2005 07:26 PM
