Old Dec 18, 2005, 08:09 PM
Twinkletoze is offline
Find More Posts by Twinkletoze
Smove from Manuel Nubel
Well I threw together a "Smove" from Manuel Nubel. The plans came out last week and it looks pretty good. It has sort of stationary speed brake struts.
Twinkletoze is offline Find More Posts by Twinkletoze
Old Dec 18, 2005, 08:37 PM
bamm is offline
Find More Posts by bamm
bamm's Avatar
Planet Jupiter
Joined Jan 2005
why the heck to you have the struts like that??????? looks good though
bamm is offline Find More Posts by bamm
Old Dec 18, 2005, 08:41 PM
It looks like it was to slow down "downlines" and I guess generally control speed . Maybe for the F3B schedule?????
Old Dec 18, 2005, 08:45 PM
Ryguy is offline
Find More Posts by Ryguy
Team Airfoilz
Ryguy's Avatar
Derby Ks
Joined Feb 2005
Also looks like it helps keep both wings from moving side to side.
Ryguy is offline Find More Posts by Ryguy
Old Dec 18, 2005, 08:51 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Cool. I see a biplane in my future.
The plans are available for download at http://www.slope-combat.de/shop/.
No email two step like with the Knuffel.
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Dec 18, 2005, 11:05 PM
Daniel Z is offline
Find More Posts by Daniel Z
Daniel Z's Avatar
Joined Dec 2004
have anyone seen the video?? pretty impressive!!
Daniel Z is offline Find More Posts by Daniel Z
Old Dec 19, 2005, 11:59 AM
bamm is offline
bamm's Avatar
Planet Jupiter
Joined Jan 2005
whats the WS on this beauty? I see that it looks like you are using a LittleScreemer on it.
I wonder how a CustomCDR would work... i'm sure it will ROCK with it!
Old Dec 19, 2005, 12:29 PM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
Permanently deployed "airbrakes" on Martin Müller's TwinSai 2 for improved "constant speed flying".
Trisquire is offline Find More Posts by Trisquire
Old Dec 19, 2005, 04:17 PM
bamm is offline
bamm's Avatar
Planet Jupiter
Joined Jan 2005
I don't get it............ I would say your flight time would be cut down alot with those
Old Dec 19, 2005, 04:58 PM
j_z_123 is offline
Find More Posts by j_z_123
BOSS
j_z_123's Avatar
New Jersey (excl EWR), United States
Joined Apr 2002
It's not about flight time. It's about constant precision and speed throughout the pattern.
j_z_123 is offline Find More Posts by j_z_123
Old Dec 19, 2005, 05:04 PM
bamm is offline
bamm's Avatar
Planet Jupiter
Joined Jan 2005
oh ok. soo... these are good for comp then..... hmmmm i'm gunna have to try this out! lol
Old Dec 19, 2005, 06:29 PM
I tried the first flights on the Smove outside at dusk today. This thing really grooves and really has a nice slooooowwww flight. High alpha knife edge is graceful and smoooth. Feels much better than my F3A shocky. Feels closer to a pattern plane than any other flat foamie that I've tried. If you like the Knuffle you will like this one, just keep the weight down. My .02.
Char
Forgot to add; The nose is hand cut EPP and makes a huge improvement. One of the elevator pull-pull lines came loose and the Smove went nose in with no damage. The other benefit seems to be in quieting down motor noise transmitted through the airframe.
Old Dec 19, 2005, 07:15 PM
pmackenzie's Avatar
Joined Dec 2002
What equipment did you use, and what is the AUW?
Pat MacKenzie
Old Dec 19, 2005, 07:17 PM
j_z_123 is offline
BOSS
j_z_123's Avatar
Joined Apr 2002
Do you or anyone else have a direct link to the video?
Jon
Old Dec 19, 2005, 07:25 PM
Hi Pat,
Two 5.5 gram generic servos, One HS55 for ailerons.
CC10 and 17t Little Screamer GWS 8x4 prop
Vampower 11.1v 620 battery
GWS receiver
I don't have a scale yet to weigh it.
Glued the 3mm Depron with GWS glue and used pull-pull on elevator and rudder.
J Z 123 try this
http://slope-combat.de/shop/index.ph...index&cPath=56
Contact flying vid inspired by Manuel Nubel bzzboy 3D Flying 96 May 13, 2005 11:05 AM
Contact Flying inspireed by Manuel Nubel rgood1 3D Flying 14 Nov 13, 2003 06:57 PM
