Old Dec 18, 2005, 07:34 AM
Leo L is offline
Find More Posts by Leo L
United States, NY, Queens
Joined Oct 2005
Bad motor or bad speed control?
How do you determine if the motor went bad or if the speed controller went bad. I've had about 50 flights with my plane, and now it doesn't have enough power to take off. I have tried two different battery packs with the same results. The batteries work fine in my other plane.
Leo L is offline Find More Posts by Leo L
Old Dec 18, 2005, 08:43 AM
lombafly is offline
Find More Posts by lombafly
Italian Member
lombafly's Avatar
Dalmine , Bergamo , Italy , Europe
Joined Feb 2004
Motor brushless or brushed?
lombafly is offline Find More Posts by lombafly
Old Dec 18, 2005, 08:51 AM
zeuglodon is offline
Find More Posts by zeuglodon
Tree Hater
zeuglodon's Avatar
Howland, Ohio
Joined Jun 2004
If its a brushed motor it's probably the motor.
zeuglodon is offline Find More Posts by zeuglodon
Old Dec 18, 2005, 08:52 AM
Jeremy Z is offline
Find More Posts by Jeremy Z
Senior User
Jeremy Z's Avatar
Northern IL
Joined Oct 2005
It is most likely a brushed motor, right?
The ESCs are solid-state; no moving parts, hardly EVER wear out unless abused.
Brushed motors on the other hand... They have carbon brushes which transport current to a rotating commutator into the armature. There is friction & arcing, which wear the brushes down. There are springs which feed the brushes into the commutator, but they can only make the brushes so long. So a point comes when the spring has fed the brushes as far as it is able, a gap between the commutator & brushes opens, there is more arcing, and less efficiency & power.
If it's a brushed motor, replace it. It'll probably cost you around $10. If that doesn't fix it, buy a new ESC, make sure it can handle the current the motor draws while running full throttle. Make sure the plane is not over-propped, so to speak.
Brushless motors would tend NOT to go bad, unless it is a bearing problem. There is no physical or electrical contact in a brushless motor to wear out. It works through pure electromagnetic induction. This means a longer life, and much higher efficiency due to lower friction. If you have a brushless motor, it is most likely the ESC.
Jeremy
Jeremy Z is offline Find More Posts by Jeremy Z
Old Dec 18, 2005, 09:20 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Usually when an ESC goes, it dies completely and you lose all motor control AND servo control. You probably just need to replace your motor. Or upgrade to a brushless and never worry about wearing out a motor again
Tres Wright is offline Find More Posts by Tres Wright
Old Dec 18, 2005, 11:01 AM
MKMotorsport is offline
Find More Posts by MKMotorsport
lawn darts r' us
Joined Sep 2005
probably the motor. easisest way would be to swap motors with a known good speed control or vice versa, this way you can rule out the faulty component.
Speed controls are typically an all or nothing deal, they either work or they dont, In all my years in R/C (used to do high perf electric boats), ive never seen one 'loose power'.
MKMotorsport is offline Find More Posts by MKMotorsport
Old Dec 18, 2005, 07:16 PM
Leo L is offline
Joined Oct 2005
Thanks for all of the replies. The plane is a stock PZ Cub that I bought used on e-bay. A replacement motor is $10, while a replacement ESC/RX is $28. I took a chance and ordered a motor. Looks like I made the correct choice.
Old Dec 18, 2005, 07:53 PM
SaMx is offline
Find More Posts by SaMx
I'm dangerously carefree
SaMx's Avatar
Media, Pa/Blacksburg Va
yup, and a motor is usually cheaper to replace, at least if it's brushed. So if you have problems, changing the motor is usually the best bet.
SaMx is offline Find More Posts by SaMx
Old Dec 19, 2005, 06:32 PM
johndreid is offline
Find More Posts by johndreid
(My website goes here)
johndreid's Avatar
Purvis, Mississippi
Joined Sep 2005
I've had two cheap ESC/RX boards go bad after a crash...each one would run the motor wide open when a battery was attached.
Anyone ever heard of that?
johndreid is offline Find More Posts by johndreid
Discussion Dead motor or bad esc on Trex ivorz Mini Helis 5 Oct 08, 2006 09:57 PM
Help! Bad motor or ESC Slope Newbie Power Systems 6 Sep 03, 2006 11:34 PM
Discussion bad Motor or ESC ? Help! killedbyboredum Foamies (Kits) 4 Jun 18, 2006 11:13 PM
Help! bad motor or bad battery beginningdave Beginner Training Area (Aircraft-Electric) 3 May 14, 2005 03:11 PM
Bad luck or bad charger? JamesD Parkflyers 7 Mar 04, 2002 04:40 AM
