Amp draw
Why is the Amp Draw so High on these Motors?
What was the pack voltage in the above comparison? I have a friend who used a Mega 16/15/2 4600kv, 35 Amp (recomonded) in a Foamy F-16, and it fly's great, but sounds like a dentists drill!! He's not burning up the sky with it though. The Parkjet is over 1 mt. long, and quite draggy (for a F-16) He's probably lucky if he hits 50 mph with it. Forgot to mention that I think he is using a 4 X 3 Prop. http://www.parkjets.com/F-16C_with_landinggear.wmv |
Indio, CA.
Joined Sep 2005
Magnum,
If you go to the JustGoFly web site you can see a video of an actual twin just with 2 JGF 400DF's on it, I think he has a video pass at 114 MPH. I think he is also running the APC 5x2.5 props. The 400 DF like the 450Th is a 3000Kv motor. My 450 pulls 37 amps static with the 6x4, and 42 static amps with the 6x5.5. The 6x4 works best with that motor on my plane. Check out JGF to get an idea. Mitchj |
Thanks everyone for the replies. The JGF motors are all outrunners right? It would be difficult to mount outrunners on the twinjet because they glue into a half circle of foam, although a ply back mount could work.
I maidened it today with the racer edition Permax 480 motors on 3S lipos. After landing I discovered one prop was on backwards (I can't remember the number of times I have read that here and though "Are you dumb or what?" ) and the performance was okay, but I want it to be the plane you pull out and watch peoples jaw drop when it goes vertical. I guess the 6 inch prop would be the best choice for that.
Indio, CA.
Joined Sep 2005
Magnum,
Yes the JGF motors are outrunners, They also have aa aluminum mount that is glued to the wing which enables you to mount the outrunner. Check out the video and still pix he has on his site. For vertical performance the longer prop you can safely turn is better, but for speed you need a shorter prop with more pitch. My motors are very happy turning the 6x4 prop, this gives me a "happy medium" of speed and vertical performance. With judicial throttle management I can safely fly my AeroCat without burning anything up and still awe the crowd. Mitch |
| Thread Tools | |
| Prop question, High pitch vs low pitch | jra111 | Parkflyers | 3 | Feb 17, 2004 02:51 PM |
| Direct drive small prop vs. geared big prop? | TEM | Parkflyers | 1 | Sep 14, 2003 06:39 AM |
| Direct small prop vs geared large prop | CAWayne | Electric Plane Talk | 4 | Dec 09, 2002 06:54 PM |
| prop rpm vs. static thrust/pitch speed | opualuan | Power Systems | 2 | Feb 19, 2002 07:48 AM |
| Big prop-low rpm or small prop-high rpm | Ninjak2k | Power Systems | 10 | Feb 13, 2002 04:28 PM |
