Old Dec 14, 2005, 12:26 PM
world_hobby is offline
Find More Posts by world_hobby
Joined Aug 2005
Is there much difference between 12G & 14G Wire.
Is there really any difference in weight or resistance between 12G & 14G wire considering how much is used in a plane. (probably no more than 40cm all up.
What would make you choose one size over another, is it your connectors, heat shrink insulation size, you want to stay in step with your Motor/ESC/battery's wire guage or just personal preference?
world_hobby is offline Find More Posts by world_hobby
Old Dec 14, 2005, 01:23 PM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
This short thread might shed some light on the resistance question:
http://www.rcgroups.com/forums/showt...ce#post3670565
30 cm. of #12 "Wet Noodle" silicone insulated fine-strand wire weigs 14.1 grams, same length, same kind #14 weighs 8.3 grams.
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Dec 14, 2005, 01:39 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
http://www.cirris.com/testing/resistance/wire.html
hoppy is offline Find More Posts by hoppy
Old Dec 14, 2005, 01:57 PM
Joined Jan 2002
Expunge, remove, make disappear...
Last edited by RD Blakeslee; Dec 14, 2005 at 02:25 PM. Reason: Thought better of lame humor attempt.
Old Dec 14, 2005, 03:55 PM
JohnMuchow is offline
Find More Posts by JohnMuchow
CamLight Systems
New York City, USA
Joined Oct 2003
There's not too much difference in weight but if you have a really critical situation, every gram helps.
Where possible, I use the largest gauge wiring I can fit into the largest connector possible. If it's larger than the existing ESC/motor wiring, good! Then I have less of a power loss along the wiring. Wherever possible, I change the ESC/motor/battery pack wiring to a larger gauge too. But, I'm comfortable with disassembling things and soldering on new wiring (with strain relief, etc.).
There isn't a huge practical difference between the two, but if you're concerned about every last bit of performance and can afford to have the extra weight and size, go for it. As long as the extra weight doesn't offset the increase in performance (higher battery pack voltage being delivered to the motors). Only testing can tell you that though.
JohnMuchow is offline Find More Posts by JohnMuchow
Old Dec 14, 2005, 04:12 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
RD, you mean you don't use Romex for all your wiring?
Old Dec 14, 2005, 06:45 PM
hermperez is offline
Find More Posts by hermperez
know it all
Miami, Fl
Joined Nov 2003
I use #14 AWG at 45 amps in my twin, the wires are noticeably warm at the end of a fligth.. I should have used #12 instead.
Herm
hermperez is offline Find More Posts by hermperez
Old Dec 14, 2005, 07:58 PM
Joined Jan 2002
*mumble*
Old Dec 14, 2005, 11:04 PM
know it all
Miami, Fl
Joined Nov 2003
speaking of romex.. I considered using it in a foamie twin.. solder noodle cable at the ends and middle for the batteries and motors.. it would act like a spar in the foamie wing.. most likely I will use #12 aluminum wire with copper noodle at the ends and middle..6ft of #12 awg copper wire is a lot of weight. Its a 70" wingspan A-26, about 500 watts per motor.
Herm
Old Dec 14, 2005, 11:23 PM
CamLight Systems
New York City, USA
Joined Oct 2003
hemperez, watch out for aluminum's resistance, 1.64 times that of copper.
You might actually be able to use a smaller (lighter) gauge copper wire and have lower power losses in the cable too, compared to aluminum.
Old Dec 15, 2005, 02:29 AM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
And, be careful of AL to CU splices - they can be a problem.
Bill
ebill3 is offline Find More Posts by ebill3
Old Dec 15, 2005, 09:51 AM
know it all
Miami, Fl
Joined Nov 2003
thanks everyone, so much for that idea..
Herm
Old Dec 15, 2005, 10:08 AM
CRT_PJ is offline
Find More Posts by CRT_PJ
Da Uper
Joined Oct 2003
Aluminum has the lightest weight per resistance(do the research), which is why they use it for power lines. Making connections would be the hard part. Tight mechanical connection with something to prevent oxidation.
CRT_PJ is offline Find More Posts by CRT_PJ
Old Dec 15, 2005, 10:31 AM
Giz is offline
Giz
Find More Posts by Giz
Giz
Tony Rogers
Giz's Avatar
Bath, UK
Joined Sep 2003
Herm
Herm,
The ESC uses the wires as a heat sink. Do you think that your warm wires could be being heated from there?
Giz is offline Find More Posts by Giz
Old Dec 15, 2005, 03:44 PM
know it all
Miami, Fl
Joined Nov 2003
they get hot near the battery, both esc are about 1ft from the battery.. see the attached drawing..
all the wiring is #14, the battery wiring is also #14.. should change that to #12, and the wiring from the connector to the main wiring in the wing to #12 also.
I use 45amp sermos connectors, crimped on. I should measure the voltage drop and see if it is worthwile.
Herm
Originally Posted by Giz
Herm,
Discussion Much difference between motors on p38? Forester Power Systems 2 Sep 17, 2006 08:14 PM
Is there a big difference between END to END soldered packs and TIN strip packs? BING! High Performance 42 Jun 17, 2005 11:13 AM
How much difference between 6.55:1 and 6.6:1? Tram Power Systems 3 May 01, 2005 07:46 PM
How much difference between Hacker B50-13S and B50-10L Balin Power Systems 2 Feb 01, 2003 03:27 PM
Is there any difference between a whattmeter and a super whattmeter The Other Dave Electric Plane Talk 1 Sep 25, 2002 11:03 PM
