Old Dec 13, 2005, 12:46 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Build Log
Aerodrome R/C 57" Albatros C.III Proto Build
About 14 months ago, I first floated the idea of enlarging the 38" Albatros C.III by Kurt Bengtson of Aerodrome R/C. He suggested that he would be willing to make a larger 57" version, and that I could do the prototype build. Rather than simply enlarging his smaller C.III, Kurt totally re-engineered the model, including much more detail, and a scale, under-cambered airfoil to boot. The wing attachment is unique, as it allows the left and right wing halves to be separated, and the top and bottom panels to remain together. This eliminates a lot of re-rigging when putting the airplane together.
The kit arrived today, and it was well worth waiting for!!!! The detail in the plans and the beautiful stack of laser cut wood are absolutely first rate. Notice the the 12" ruler in the photos; this is not a small model. Power will be an AXI 2826/10.
As this is the holiday season, things are a bit busy around the household at the moment. Construction will start in earnest after the holidays, although I don't think I can help myself but to start at least the tail feathers sooner!
Wolpertinger is offline Find More Posts by Wolpertinger
Old Dec 13, 2005, 01:20 PM
Canada, BC, Comox
Joined Nov 2003
Here's the planned colour scheme. Natural dark wood fuselage, poly span surfaces with dope.
The two seaters just never get the same respect as the fighters. This airplane has really nice lines, and will make a great flyer.
Old Dec 13, 2005, 01:58 PM
Wufnu is offline
Find More Posts by Wufnu
Pickin' an a Flyin'
Wufnu's Avatar
United States, TN, Knoxville
Joined Apr 2004
Schweeeeeeeeeet. I agree, not too many people model the recon/bombers it seems. I don't know why, they look just as nice if not more.
Do you keep all these planes you build flyable?!
Wufnu is offline Find More Posts by Wufnu
Old Dec 13, 2005, 02:41 PM
dottney is offline
Find More Posts by dottney
dottney's Avatar
United States, NY, Fairport
Joined Jun 2000
OOOOOOOOOO Frank, I can't wait to see you perform your magic. This is the same way I ended up doing Kurt's 54" Alb DV. What can you say when a guy totally redesigns a kit for you.
Have at it and show us the pics,
Dave
dottney is offline Find More Posts by dottney
Old Dec 13, 2005, 02:55 PM
Brian Allen is offline
Find More Posts by Brian Allen
Veni Vidi Volavi
Sterling, VA
Joined Jan 2002
Von
Looks great, keep us posted on the progress. I am doing a build for Kurts 54" SE5a. Lets meet at next years NEAT Fair and see who wins the battle!!!
Brian Allen
Veni Vidi Volavi
I came I saw I flew
Brian Allen is offline Find More Posts by Brian Allen
Old Dec 13, 2005, 04:28 PM
Rekitter is offline
Find More Posts by Rekitter
Rekitter's Avatar
Oakland, CA
Joined Nov 2002
Frank:
The CIII looks like a great project and I really like your color scheme. This is going to be a big bird! I can't believe that you are going to stray from your beloved silkspan! Good luck and happy holidays.
Alex
Rekitter is offline Find More Posts by Rekitter
Old Dec 13, 2005, 06:56 PM
Canada, BC, Comox
Joined Nov 2003
Tail Feathers
Here's the horizontal stab and elevators. Nothing too difficult, glue and pin the parts down over the plans. I use aliphatic glue; I just like having a bit more time to position the parts, and I like the way it sands. The parts are laser cut from 3/16 sheet, and fit perfectly. A few pieces of 3/16 square form the cross pieces. There was enough of a "Border" around the 3/16 laser cut sheets that I was able to strip off 3/16" sq strips with my balsa stripper! It's also nice to have the small slots cut out where the control horns fit in. A nice change from hacking them out with a knife when I scratch build.
Old Dec 13, 2005, 07:14 PM
edi is offline
edi
Find More Posts by edi
edi
Triplane addict
edi's Avatar
Elstertrebnitz, Germany
Joined Aug 2004
Hehe, Frank, I can see you are having fun. I also received a very nice kit today, but I'll finish the little Fokker Dr.1 first. I just love the color scheme with the white dragon! Pity I won't be able to come over for the maiden flight!
edi is offline Find More Posts by edi
Old Dec 14, 2005, 06:55 PM
Canada, BC, Comox
Joined Nov 2003
Fin & Rudder
The fin & rudder are also constructed from laser cut 3/16" balsa and some 3/16" balsa sticks. Once again, there was enough wood around the edges of the cut parts on the 3/16' sheet to strip off some square pieces.
Edi- a shame indeed! The dragon and crocodile paint will be a challenge, but at least there are only two colours. I think once it's done, it will be well worth the extra effort.
Old Dec 14, 2005, 08:58 PM
Canada, BC, Comox
Joined Nov 2003
Fuselage Sides
I know, I said I would only do the tail feathers, and the rest would wait until after the holidays. But I just couldn't resist starting the fuselage!
Each fuselage side is laminated from 5 pieces of 1/16" balsa, forming a side that is 3/16" at it's thickest point. Kurt has been very clever here! The joints are such that they don't overlap, ensuring maximum strength. Slots are cut in the sides for the various formers.
The first step is to remove and identify all the fuse side parts. I can't stress enough how important it is to familiarise yourself with the plans and the parts to ensure you build a left and right half, with the proper orientation of all the parts! The parts are well marked, and the plans are very clear, so take your time and everything goes very smoothly.
You must first join the front and rear halves of both the middle and outer fuselage sides. I use Ambroid balsa cement for this, as it sands better than most glues. The final finish on the fuselage on the prototype will be natural wood, so I did not want to use CA on this joint, as I am planning on using wood stain to achieve the dark colour. Stain will not work on a CA joint, leaving a very tell tale light line. Ambroid takes a while to dry, and for best results, requires the "Double gluing technique". First spread a light coat on each surface to be joined, let dry, then apply more glue and join the parts.
Here's how I like to join balsa sheeting:
Old Dec 15, 2005, 12:47 PM
farnboro flyer is offline
Find More Posts by farnboro flyer
farnboro flyer's Avatar
Farnborough, Hampshire, England.
Joined Jan 2002
I somehow knew you would not resist the build after the fin and rudder!.
I'v been waiting for this one Frank.........looking good.!
ian
farnboro flyer is offline Find More Posts by farnboro flyer
Old Dec 16, 2005, 06:52 PM
Canada, BC, Comox
Joined Nov 2003
Fuselage Sides
I laminated the three layers together using Z-Poxy finishing and laminating resin. Using a plastic spreader, I spread a very thin coat of epoxy on the sides, aligned everything just so, and then piled weight on top until the epoxy cured. using a plastic spreader, you can get the glue on very thin, and it adds almost no weight. I didn't want to use CA because I wanted time to align things, and I was worried that aliphatic would cause warps. I did not put any glue between the layers at the nose, because there is quite a sharp bend at the front. I think if the 3 layers were solidly glued together, it would be very difficult to bend them later. That's one reason Kurt designed the sides like this, The grain of the middle layers runs perpendicular, making the bending easier. Once I join the sides, I'll add glue between the layers and bend them to shape. Once the glue dries, the bend will be permanent.
In the photo, I have pinned down a side and have started to add the longerons, stab mount doublers, and vertical reinforcements. (I got a little ahead of myself and installed a former when I should have waited.) The lines on the inside are something I do for every model. I draw a series of parallel lines 1/2" apart on the inside of the fuselage. When the fuselage is assembled, it makes aligning things like servo rails, etc, a breeze.
Old Dec 18, 2005, 07:57 AM
Canada, BC, Comox
Joined Nov 2003
The fuselage sides are joined together. It just seemed that with the shape of this fuselage, it was best to start at the rear and then work forward. Take your time, as this will decide whether you come out with a square fuselage.
Old Dec 18, 2005, 10:11 AM
Greg Knipp is offline
Find More Posts by Greg Knipp
Greg Knipp's Avatar
Manitowoc, Wisconsin
Joined Dec 2003
Lookin real good VonJ!!!! This should be a sweet bird......Greg
Greg Knipp is offline Find More Posts by Greg Knipp
Old Dec 20, 2005, 07:35 PM
Canada, BC, Comox
Joined Nov 2003
A few photos to show my progress. It is going together really well. The nose takes a very sharp bend, but the fuse sides are designed so that the bend happens quite easily.
So much for "Oh, I'll maybe just put the tail feathers together, and wait until the holidays are over to go any further."
Build Log Aerodrome R/C 1/6 Fokker Dr.1 Dreidecker Wolpertinger Scale Kit/Scratch Built 221 Jun 28, 2009 06:13 AM
Build Log Aerodrome R/C SE5a 54" Build Thread Brian Allen Scale Kit/Scratch Built 276 Apr 16, 2008 10:22 PM
Video Aerodrome R/C 1/6 Scale Dr1 Take off. Wolpertinger Electric Plane Talk 5 Apr 13, 2007 10:05 PM
Video Aerodrome R/C's 57" Albatros C.III Maiden Video Wolpertinger Electric Plane Talk 6 Jun 07, 2006 01:09 PM
Video Aerodrome R/C's 57" Albatros C.III Flight #4 Wolpertinger Electric Plane Talk 0 May 12, 2006 06:30 PM
