Thoughts and ideas
O.K. so I've been working on and off again on this Typhoon. I have met with several pitfalls and found some good ideas to share.
The first was the problem of wide prop shaft spacing and a single 4" WTC. I tried three different u-joints set up both normally and as torque shafts...nix. Not one would run true enough at any real angle of deflection to even be considered. Pondering this for a while, I decided to try a belt drive schenario. With this I could even get some reduction, which could'nt hurt in my case. The end result works fantastic, super smooth and quiet. The next pitfall was the extremely limited amount of vertical space afforded for the rear hydroplane shafts...there is just no way to get a belcrank in there. So I made up a crankshaft, which seems to work well so far. It is not my idea but I did somewhat refine the info I found. Ideas comments? Chris
No, it's a scratch built hull made by a friend of mine. He has some online pics at www.rickosplace.com. I managed to get him to pull me a copy for an incredible price. It's a big hull, right at 6 feet, but it is just a hull, nothing more.
I like the third bearing idea and will look into that. Chris |
Well, at 6' it would be close to 1:96 scale I think. The hull has no scribe lines at all. It is a true modellers delight...basic shape and go from there. Rick also moved the sail forward a little for reasons of balance, I think. I have been debating moving it back to it's true life spot. This would not be hard, just a couple more cuts on the bandsaw.
I would love any info you have, please feel free to dump any and all you have to rom-109@comcast.net I appreciate that. Chris P.S I'll try to get some pics of the rest of it posted tonight. |
Here are some more pics of the sub, a long way to go I know, but it's coming together.
Chris
| Thread Tools | |
| Discussion Moved - Thoughts / Ideas for a Harrier - VTOL. What do you think? | FirmamentFX | Fuel Jet Talk | 5 | Nov 29, 2009 11:28 PM |
| Discussion Thoughts / Ideas for a Harrier - VTOL. What do you think? | FirmamentFX | VTOLs | 16 | Oct 13, 2006 04:49 PM |
| Discussion Thoughts and ideas for a new AP design | CoClimber | Aerial Photography | 151 | Jul 13, 2006 03:57 PM |
| Some thoughts and ideas | Extremeone | Aerial Photography | 15 | May 06, 2003 12:58 PM |
