Old Jan 27, 2003, 09:08 AM
Greg Covey is offline
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
I have skipped several steps here that will show up in my conversion write-up but it installed very easy with foam-safe CA and 4 or 5 tape strips for hinges.
Click here for a larger image.
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Jan 27, 2003, 09:12 AM
Rochester, NY, USA
Joined Aug 2000
The aileron seemed sufficiently sturdy with the stock taped trailing edge but the wing was still rather flimsy. I re-cyled my carbon flat bars from the old wing set and epoxied them onto the wing underside.
Sine the Sky Runner will fly incredibly slow on less than half throttle of the KP-00 motor, I was not concerned with adding a little extra weight.
Old Jan 27, 2003, 09:19 AM
Rochester, NY, USA
Joined Aug 2000
The connecting rod is a small piece of stripped solid wire from the RFFS100 module kit.
Old Jan 27, 2003, 09:24 AM
Rochester, NY, USA
Joined Aug 2000
The finished wing half was duplicated for the other half and is then ready to assemble onto the fuselage and plug into the RFFS100 module.
Since there are two sets of pins, one set for each aileron, I tested the aileron movement for opposide direction before soldering on set of pins to the top of the other set.
Old Feb 17, 2003, 09:27 AM
Rochester, NY, USA
Joined Aug 2000
My Sky Runner finally flew well using dual ailerons and offsetting the droop with magnets.
Old Feb 17, 2003, 09:31 AM
Rochester, NY, USA
Joined Aug 2000
Since the fly-in last Saturday, I have increased the dihedral a bit to improve the steering even more and replaced the 0.1oz Penny nose weight with a second 230mAh LiPoly cell to double the duration.
Old Feb 17, 2003, 09:35 AM
Rochester, NY, USA
Joined Aug 2000
After all the pummeling that this model took, the stock high-impact rubber nose and stock plastic skid kept the plane undamaged. Having a pusher prop configuration keeps the KP-00 motor very safe in the back.
The only component that was jarred loose was the crystal so I held it in place with a tiny piece of servo tape in between the crystal bottom side and the top of the IC chip that it rests on.
Old Feb 17, 2003, 10:21 AM
Fly_joy is offline
Find More Posts by Fly_joy
Fly_joy's Avatar
Rochester, NY
Joined Mar 2001
Greg's plane flew very well. I was surprised how fast it was.
Larry
Fly_joy is offline Find More Posts by Fly_joy
Old Feb 17, 2003, 03:20 PM
Jgardner is offline
Find More Posts by Jgardner
Fanfold abuser
Jgardner's Avatar
Rochester Monroe Cty, New York, United States
Joined Aug 2002
First aileron plane choice?
Greg,
Would this be a good choice for someone contemplating their first aileron plane?
It did look like a great flyer. I would think it could handle a bit of breeze in the backyard, as well.
Jgardner is offline Find More Posts by Jgardner
Old Feb 18, 2003, 10:25 AM
Rochester, NY, USA
Joined Aug 2000
Hi John,
My goal is to make it a good first plane period. It really only has ailerons because it seemed an easier design approach than adding tailweight with a new rudder assembly. It flew fine outside before I tried it indoors and needed better turning response.
It has many things that I am looking for that will help bring more people into micro flight. My goal here is a simple to convert, simple to fly, and durable indoor flyer.
  • safe pusher configuration
  • rubber nose for crashing
  • charging station
  • On/Off switch
  • cheap $10-$13 ARF
  • big wingspan for 2oz
  • durable foam construction
I have updated my conversion article here.
All that remains is to post some flying shots when they return from the developer.
Let's see how much better it flies at the next meet. With double the duration without adding any weight, and, additional dihedral, we can pass the stick around.
Regards.
Sky Runner from Harbor Freight digsy Scratchbuilt Indoor and Micro Models 2 Jan 16, 2005 11:21 AM
New visor magnifying lens from Harbor Freight Jim_W Parkflyers 0 Jan 04, 2005 08:33 PM
23" span free flight from Harbor Freight. dvint Free Flight 4 Aug 29, 2003 11:55 PM
vacuum pump from harbor freight sventek1 Hand Launch 5 Jan 17, 2003 11:41 PM
CNC setup for mini mill from harbor freight stealthy Life, The Universe, and Politics 0 Jan 21, 2002 02:32 AM
