Old Dec 10, 2005, 10:14 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Build Log
Orca -- Another One Comes to Life!!!
Since there's always room in this world for another Orca I thought I'd share this build. Even though it's been done before, there will be some changes on this one to fix a couple things I know weren't right on the p-type.
It all started by laying out the hull parts patterns on 1/8 lite ply. The parts were cut out and all the 1/4 sq, balsa frame bracing added.
P. Tritle is offline Find More Posts by P. Tritle
Old Dec 10, 2005, 10:21 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The Basic Hull Frame
Assembly begins with the keel. The front and rear sections are sandwiched between the aft doublers and clamped till the glue dries. The frames are assembled on the keel, and the whole assembly hot glued to the building board to keep it all straight. Finally, the chines were added using 3 laminations of 1/16 X 1/4 bqalsa and the whole assembly sanded to shape.
Old Dec 10, 2005, 10:41 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Planking theHull
Hull planking begins on the bottom at the keel. To keep the scale number of planks, 1/8 X 3 balsa sheets were ripped to 3/4" width so the right number of planks can be used.
The bow was planked crossways from frame #1 forward. It's a bunch easier then making the bottom planks twist into the stem!
The middle planks were cut in to clear the keel doublers and glued in place. A stealer was used to fill a gap at the front 1/3 of the hull. Then, working on both sides of the keel, one plank at a time, the rest of the planks are laid. Carpenters glue was used between the planks, and Cya was used to attach the planks to each frame. Clamps are used to keep the planks nice and uniform. The idea is that the lines between the planks will still show after all is sanded smooth.
PAT
Old Dec 11, 2005, 10:42 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Cool!!! Are you building this one full size to your original drawings or did you scale it down?
Aerominded is offline Find More Posts by Aerominded
Old Dec 12, 2005, 09:29 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Aero, This one is going up full size. Will try a couple things to improve over the original too. Should be a fun project all around.
PAT
Old Dec 14, 2005, 09:34 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The Planking Process Continues
The last of the bottom planks are in place now, and the first two side planks are in place.
Once all the bottom planks were glued in the hull assembly was removed from the board and the deck sheers laminated up and sanded to shape.
Side planking begins at the top, and is laid in flush with the sheer. As with all the balsa planking, the planks are attached to the frames with Cya and white glue is used on the mating edge. The planks are then clamped to keep the edges as true as possible.
PAT
Old Dec 15, 2005, 10:47 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The Hull Planking is Done
Got the last of the hull planking on today. With all the planks glued in place, the bottom plank was trimmed flush with the chine and sanded flush. The planks laid down real well with very little bulging along their edges, so no "pre-sanding" was needed before the gaps were filled.
To fill the gaps between the planks, a medium mixture of drywall mud was mixed up and squegeed over the entire hull. Mixed a little thin like this was, the spackle will shrink into the gaps and when sanded won't hide the lines between the planks. As ratty as this boat was, you have to leave the gaps showing and the boards a little uneven to keep it all looking true to scale.
PAT
Old Dec 16, 2005, 07:49 AM
k225 is offline
Find More Posts by k225
She'd roll on wet grass !
k225's Avatar
Ottawa, Ontario Canada
Joined May 2004
Pat
I have used drywall compound before but never thought of using it in a model boat. How does it hold up to being in water?
Steve
k225 is offline Find More Posts by k225
Old Dec 16, 2005, 10:35 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Steve, Drywall mud is my favorite filler for large areas for a couple of reasons. First and formost, "it's cheap", and second, because by using the dry mix the consistancy can be easily controled in any given situation. On a model like this you want it to crawl back in the gaps between the planks to insure a good seal, but you don't want to make the lines go away.
Sealing the dried mud isn't a problem, and so far I havent found anything that it's not compatable with. It accepts almost any kind of sealer much like balsa wood, and once sealed, sands just like balsa. On this one I'l probably seal it up with several coats of varnish , then prime and paint.
Old Dec 22, 2005, 05:57 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Sealing the Hull
With the filler applied to the outer hull and sanded, a coat of thinned resin was applied to the inside of the hull. Once cured, the stuffing box and rudder bearing tube were installed.
The stuffing box was madw frome 3/16 brass tubing with a 5/32 brass tube bushing in each end. The rudder tube is made from 5/32 tubing. Both were aligned and glued in place, then faired in with a mix of epoxy and micro balloons.
Once cured and sanded, the outer hull was given 4 coats of Nitrate dope to start the sealing process.
Old Dec 22, 2005, 06:01 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Mounting the Motor
The motor mount is made from 1/8 lite ply and 3/8 triangle stock and glued to the keel and ajoining bulkhead. The Dumas 6 volt high torque (Pitman) motor was secured to the mount with a gob of silicone and a pull tie. The Dumas dogbone coupler was used to connect the 1/8 wire prop shaft.
Work has already begun on the cabin and upper decks, will post up the photos as soon as they're "processed".
PAT
Old Dec 22, 2005, 06:19 PM
Joined Feb 2004
Looking great, Pat!
Old Dec 22, 2005, 07:33 PM
mr. fix-it is offline
Find More Posts by mr. fix-it
Joined Feb 2005
I have a question on electric boats. Is any type of gear reduction used on the propeller? I am thinking about building a hydroplane I have seen in a boat building book and wondered about the motor size verses the boat size, and propeller size. I would thank you for any input you can give. Also what about motor speed controls? Can you use one out of a car?
mr. fix-it is offline Find More Posts by mr. fix-it
Old Dec 23, 2005, 11:26 PM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fix, You can use a gear reduction unit on a boat, but you mention a hydro in the Question. The idea with a a gear drive is to turn a big prop more slowly to increase torque. With a fast boat, you want to turn a small prop real fast -- that's where the speed comes from. Typically, if you want slow speed and big torque, use a reduction unit. To go fast, go with direct drive.
You can definately use a car ESC in boats, and there's lots of them out there to choose from. However, you can also use airplane ESC's as well, but only if you don't need the reverse feature that only car controllers offer.
PAT
Old Dec 24, 2005, 09:25 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Building Up the Cabin
With the hull finished, the main deck in place and the whole thing pretty well sealed up, work can begin on the top side.
The cabin assembly began by framing up the cabin sides. This time, I lowered the bottom edge of the windows since that's the one thing on the original that always botthered me -- once I had noticed they were wrong!
The rest of the cabin was then cut out and glued in place. Another change on this one is that the aft cabin wall was made up in 3 pieces. The outer sections were glued in place on the cabin walls, the middle section will be glued to the cabin roof and will lift out with the roof to gain access to the Rx and ESC.
PAT
another one.... spinnetti Parkflyers 1 Jan 31, 2002 08:45 PM
Aspire Comes To Life!!! aireze Electric Sailplanes 7 Jan 31, 2002 12:28 PM
2 day wonder- scratched another one steve neill Foamies (Kits) 12 Oct 19, 2001 11:25 PM
Sky Scooter Throws Prop Adapter - Where can I get another one? mrebman Foamies (Kits) 3 Jul 16, 2001 01:19 AM
Another one sees the light Dereck Electric Plane Talk 12 Jul 10, 2001 06:24 AM
