May 15, 2001, 01:28 AM
Auburn, Washington USA
Joined Jan 2001
VWTechie is exactly right - ideally you need a prop the same diameter but with about 25 or 30% more pitch. Diameter doesn't help much. Of course, it doesn't look like you could do that anyway, looking at firebirdxl.com.
What prop comes with the airplane? It looks like a direct drive speed 400 type motor, and NOT the ubiquitous push-on Gunther prop, so there are some choices.
One more encouragement for me to write that "flying at high altitude" article for the Ezone I'm thinkin' about. But the bottom line is more pitch or a lower gear ratio. In your case, it looks to be direct drive, the only choice is more pitch.
