Old Dec 14, 2005, 05:29 AM
ZIPPER is offline
Find More Posts by ZIPPER
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
To get a thicker tip using the pivot method, do the bottom cut first then when you do the top cut space the wire higher at the pivot buy 1/4".
Glenn
ZIPPER is offline Find More Posts by ZIPPER
Old Dec 15, 2005, 09:30 AM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Thanks to everyone's suggestions, I'm just about there. I hope to cut some good ones today.
The key points were:
1. Lower the wire temp. I was cutting at 5 1/2 on my power supply dial. I find it can still make the cut at a setting of 4 1/2.
2. Make the blank wider. With the blank 1/2" wider, I can trim off the part with holes and get a nice clean TE.
3. Make the tip template slightly larger. I went to 12% thickness vs. 10%.
4. Keep the wire very clean. A fair amount of "slag" remains on it after each cut, and I have been scraping it off with an old #11 blade.
5. Get the geometry of the cutter right and use the gravity drop arm. I was having trouble with this and had switched to pulling by hand, but I would always get waves in the cut. The gravity arm makes a wave-free cut. (This is the part I still have to completely work out.)
Thanks everyone!
Bill
BillO is offline Find More Posts by BillO
Tips for cutting plans from depron. Art-Tistic Foamies (Kits) 6 Jun 29, 2005 03:52 PM
Any tips for launching high powered gliders? tigroot High Performance 9 Aug 22, 2004 10:34 PM
Tips for cutting radio gear pockets in EPP wing... konaboy Foamies (Kits) 12 Nov 21, 2002 08:41 AM
Ant tips or tricks for cutting a foam P-47 wing? kit basher Power Systems 0 Oct 28, 2001 09:23 AM
Looking for high wind tips for ZAGI PALADIN Foamies (Kits) 4 Jul 28, 2001 11:43 PM
