Old Dec 06, 2005, 09:01 PM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Tips for cutting high-taper core?
OK, so now I'm trying to cut the fin for my Jart plug and it isn't easy. The fin has a 7 3/8" root and a 2" tip and it's only 6" high so it is highly tapered. The hot wire goes so much slower at the tip that the foam is getting burned. I'm using the "pivot block" described in the FeatherCut instructions.
One suggestion made in the manual is to cut the tip template slightly oversize to account for the excessive kerf. Does anyone know how I can print out a slightly oversize template using Profili?
There are two options I can see -- skin thickness and drawing thickness, but I wonder if either of them makes the actual outline any bigger.
Thanks for any suggestions!
Bill
BillO is offline Find More Posts by BillO
Old Dec 06, 2005, 09:22 PM
Les Horvath is offline
Find More Posts by Les Horvath
East Stroudsburg Pocono, Pennsylvania, United States
Joined May 2003
cutting
Bill
Hello Bill.
Increase the tip to 3", than cut it. After cut, glue the 2" template to the root
than send to conture.
Les
Les Horvath is offline Find More Posts by Les Horvath
Old Dec 07, 2005, 07:35 AM
Phil Barnes is offline
Find More Posts by Phil Barnes
Germantown, Maryland
Joined Apr 2004
  • Click on "airfoils' and then "airfoils management" from the drop down menu.
  • Select an airfoil from the list and click on it.
  • Click on "process" from the menu at the top of the window.
  • Click on "process selected airfoil" from the drop down menu.
In the airfoils processing window you will see the option for changing the thickness of the selectes airfoil.
Phil Barnes is offline Find More Posts by Phil Barnes
Old Dec 07, 2005, 09:24 AM
BillO is offline
Firecracker!
BillO's Avatar
Hi Phil -
Thanks, this is just what I was looking for!
Bill
Old Dec 07, 2005, 12:00 PM
I'm Rick James is offline
Find More Posts by I'm Rick James
Nucking Futs
I'm Rick James's Avatar
Southern Killafornia
Joined Jan 2005
Can you lower the temp any? To reduce the kerf, oftentimes I'll dial the temp way way down and tension the bow higher. Takes a bit longer but the foam loss is much lower.
HTH, IRJ
I'm Rick James is offline Find More Posts by I'm Rick James
Old Dec 07, 2005, 01:38 PM
BillO is offline
Firecracker!
BillO's Avatar
I'll give that a try too. My power supply is just a dimmer connected to a transformer and it isn't all that accurate or linear. Maybe I'll have to upgrade. Thanks.
Bill
Old Dec 07, 2005, 10:47 PM
GaryO is online now
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
That's really an extreme taper. Why not just sand the core shape from a rectangle, the way Dr Drela does for hlg tails. Really simple and takes next to no time.
Cut the airfoil profile as a rectangle, with the proper thickness taper. Then sand some tangents and fair.
A little looking on the hlg forum should find the info, or go to the Charles River RC sit and look under their plans section, in Apogee, for info on cutting airfoils in balsa. Works the same in foam.
Gary
GaryO is online now Find More Posts by GaryO
Old Dec 07, 2005, 11:15 PM
BillO is offline
Firecracker!
BillO's Avatar
Gary - yep, that's a good idea. I was thinking I may use balsa as it will be stronger than foam, but it's basically the same thing. I'll give the Feathercut a couple more tries at it and if it doesn't work, then it will be on to sanding...
Bill
Old Dec 08, 2005, 01:59 AM
Kevin Matney is offline
Find More Posts by Kevin Matney
Kevin Matney's Avatar
United States, MI, Erie
Joined Mar 2000
First draw 2 lines, 1 down the LE past the tip so when you draw line 2 Fron The TE they come together. to a point. This is now the pivot point for 1 end of your Bow. Add a piece of MW to make a leg for this end and pivot off this.
On the tip end use a small fan to cool the wire it will help alot. I do this on a short run of cores.
Kevin Matney is offline Find More Posts by Kevin Matney
Old Dec 08, 2005, 06:48 AM
Joedy is offline
Find More Posts by Joedy
My other TX is a P4000.
Joedy's Avatar
USA, VA, Raphine
Joined Sep 2002
Yep, I use Kevin's technique. I drilled a small hole at the pivot point and stick the end of the bow into it. This way, I only have to freehand the other side of the bow.
One thing about this method, though, is that for long span panels, you will need a very long bow in order to reach the pivot point and still have enough cutting wire to reach past the opposite side of the core.
-joedy
Joedy is offline Find More Posts by Joedy
Old Dec 08, 2005, 11:49 AM
BillO is offline
Firecracker!
BillO's Avatar
Hi Kevin -
The setup you describe is exactly the "pivot block" method I'm using. The idea about the fan is interesting though. One more thing to try.
Bill
Old Dec 10, 2005, 04:47 AM
durone is offline
Find More Posts by durone
Italy
Joined Jan 2003
This is not a precise way to oversize an airfoil, as you need an offset function and not a simple thickness change.
Tru to add a negative skin thickness in Profili....
durone is offline Find More Posts by durone
Old Dec 10, 2005, 12:10 PM
Sled Driver is offline
Find More Posts by Sled Driver
Knowledge increases life's FOV
Sled Driver's Avatar
Third Stone from the Sun
Joined Nov 2003
Pivot Cutting Photos...
The photos below show a two different pivot cutting examples and resulting cores...
Sled Driver is offline Find More Posts by Sled Driver
Old Dec 10, 2005, 06:11 PM
BillO is offline
Firecracker!
BillO's Avatar
Durone -
I tried using a negative skin thickness and it seems to do the right thing. Thanks. Fortunately in this case, accuracy is not essential. It's just a symmetrical foil for the fin.
Sled Driver -
So the two methods are 1) use a bow and fix one end to pivot around and 2) no bow, just stretch out a wire?
Bill
Old Dec 11, 2005, 10:11 AM
Joined Nov 2003
The first set up shows using slotted pivot, which works fine for longer pivot length cuts where the heigth of the wire at the pivot does not matter. The second set up shows a notched pivot that keeps the wire at a heigth the chord height for short pivot length cuts.
Tips for cutting plans from depron. Art-Tistic Foamies (Kits) 6 Jun 29, 2005 03:52 PM
Any tips for launching high powered gliders? tigroot High Performance 9 Aug 22, 2004 10:34 PM
Tips for cutting radio gear pockets in EPP wing... konaboy Foamies (Kits) 12 Nov 21, 2002 08:41 AM
Ant tips or tricks for cutting a foam P-47 wing? kit basher Power Systems 0 Oct 28, 2001 09:23 AM
Looking for high wind tips for ZAGI PALADIN Foamies (Kits) 4 Jul 28, 2001 11:43 PM
