Old Dec 06, 2005, 02:10 PM
wirbech is offline
Find More Posts by wirbech
Pushing the Limits of FFF
wirbech's Avatar
United States, CA, Sierra Madre
Joined Jun 2005
Another thing to check is your prop. Make sure that it is on correctly. The writing should face the front of the plane.
John
wirbech is offline Find More Posts by wirbech
Old Dec 06, 2005, 03:24 PM
bigglesjets is offline
Find More Posts by bigglesjets
bigglesjets
bigglesjets's Avatar
Notts UK
Joined Jul 2005
Hi Submarco
Excellent! I do hope this sorts your problem out, I dont like to see guys disolusioned before they get off the ground,so to speak!
Regards
Alan
bigglesjets is offline Find More Posts by bigglesjets
Old Dec 06, 2005, 03:32 PM
gyronuts is offline
Find More Posts by gyronuts
gyronuts's Avatar
United Kingdom, Gamlingay
Joined Jul 2002
Just a thought but my F15 used to do that. I came to the conclusion that it was the flexing of the depron elevator/elevons at higher speeds which caused the pitch up . At which point the speed reduced and control recovered. The tailplane is very flexible and it does not take much to bend the whole surface and shaft. Bill
PS the nose high pitch up in the picture was not an intentional control input!!!
PPS I had a lot of trouble finding a prop that would give me good vertical performance yet a reasonable turn of speed level.
gyronuts is offline Find More Posts by gyronuts
Old Dec 07, 2005, 03:17 AM
submarco is offline
Find More Posts by submarco
ViruTs
Denver
Joined Mar 2004
flight report:
yes it was the cg, finally my f-18 flew decently, however, because of the dark I didi crash it. AT this point I think I will make a new one.
I will make sure to balance it on the cg, however, yes Gyronuts reported I think the pitch up is something structurally inherent to those kind of planes, that would make sense when I used to p˛wer system such as the mega 4t, but not so much when it came to the axi 2212/26 or teh bp21. Plus, still thinking on Gyronuts commentaries, yes I think the picking the right prop makes a lot of difference.
I will work on that to.
I plan to work on two projects, a new f-18 and the Cobra's F-20 tigersharck, lets see If I have more luck now.
submarco is offline Find More Posts by submarco
Old Dec 07, 2005, 06:36 AM
albireo is offline
Find More Posts by albireo
From Earth to the Moon!
albireo's Avatar
Sacramento, Ca.
Joined Jul 2003
This is what I've been looking for Tom. Just to clarify, you mean if the nose lifts when you cut the power you move the battery/weight forward to balance the plane, and if the nose dips down you move the battery/weight back not move the CoG mark on the plane/plans foward or backward, right? That is, you always stick with the CoG measurement mark on the plane/plans and move the CG by shifting weight in the nose...
Joe
Originally Posted by RCParkflyer
Sounds like your CG Location is off.
when you fly the plane, cut the power, if the nose lifts your CG is too far back. If the nose dips down, the CG is too far forward, just move it back.
Tom
albireo is offline Find More Posts by albireo
Old Dec 07, 2005, 09:15 AM
RCParkflyer is offline
Find More Posts by RCParkflyer
RCParkflyer's Avatar
Racine, WI AMA# 809291
Joined Nov 2003
Joe
You will end up with a new CG position, but it will be only a slight adjustment, as your pretty close already, your just fine tuning the plane at this point. Once the plane flys level, then you re-balance it, and mark the new CoG spot, then you just balance the plane on that new spot every time you fly.
RCParkflyer is offline Find More Posts by RCParkflyer
Old Dec 07, 2005, 04:28 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by submarco
flight report:
Sorry to hear about your crash - for the next one try the Axi 2212/26 with a 9*7,5 APC SF prop - Really rocks!!
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Dec 07, 2005, 10:35 PM
albireo is offline
albireo's Avatar
Sacramento, Ca.
Joined Jul 2003
I'll second that motor reccomendation, I use that exact same setup and my piggie Shumate design F-15 weighs a fat 24 oz and it really hauls - I mean much faster than I can fly it...
Joe
Old Dec 08, 2005, 05:53 AM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Joe
there is nothing like WOT!!
Ben_E
Old Dec 08, 2005, 10:54 AM
Wade Joos is online now
Find More Posts by Wade Joos
Wade Joos's Avatar
United States, UT, Salt Lake City
Joined Aug 2002
Cg
Guys,
I think either I am reading this wrong or there needs to be some clarification.
"This is what I've been looking for Tom. Just to clarify, you mean if the nose lifts when you cut the power you move the battery/weight forward to balance the plane, and if the nose dips down you move the battery/weight back not move the CoG mark on the plane/plans foward or backward, right? That is, you always stick with the CoG measurement mark on the plane/plans and move the CG by shifting weight in the nose...
Joe"
This would be the test for thrust line.
If the plane changes pitch - either up or down with throttle changes, then it is the thrust line of the motor that is incorrect.
To check for proper CG, set up the plane for level flight, then roll it over on its back. If the plane dives toward the ground it is nose heavy, if it pitches up, then it is tail heavy.
A nose heavy condition can also be detected by looking at where the elevator is trimmed for level flight. If the elevator has a lot of up" or "down", then the CG balance needs to be adjusted.
The maked "CG" spot on the plans is just a suggested starting point. Each plane may be a bit different from that location.
Once you have the plane flying normal and inverted with little input change required from the elevator, then that will be your correct CG location. Once you have found the sweet spot, put a mark on the plane & use that as a balance point from then on.
I hope this makes sense & helps
Later
Wade
Wade Joos is online now Find More Posts by Wade Joos
I give up on Bluecor... Not available in Canada... NetForce2K Foamies (Kits) 32 Sep 28, 2009 09:09 PM
Help! Just about to give up on helis. please fix my uncontrolable tail wag delamar Micro Helis 23 May 27, 2006 09:58 AM
Help! help me please, about to give up on RC flying xoon Parkflyers 60 Feb 03, 2005 07:18 PM
Should I give up on the FMA Razor??? soholingo Foamies (Kits) 20 Jul 22, 2002 06:28 PM
Help READY TO GIVE UP ON LITESTIK brudford Parkflyers 21 Apr 26, 2002 03:05 PM
