Old Dec 06, 2005, 11:02 AM
ViruTs
Denver
Joined Mar 2004
Please Help:i Dont Wanna Give Up On Jets!
Foamy jet pilots I need your help.
I built the notorious f-18 parkjet and I love it despite the fact that is causing lots of frustartions!
I can`t get it to fly well.
I tried 3 different motos: axi 2212/26, mega 16/15/4 and bp21, all powered by 3s 1700 etec
With all three setup attempts I had problems. After many flights I found the jet affected by two main issues:
first of all, during the flight, at some random point, the plane would pull up like the cobra manouver (with no intention);
second, maybe due to the flat airfoiled wing, the plane seemed to be willing to fly only at full power. Otherwise diving like it was underpowered.
please help me figure out what's going on and what's wrong.
thank you, I really appreciate it.
submarco
submarco is offline Find More Posts by submarco
Old Dec 06, 2005, 11:07 AM
RCParkflyer's Avatar
Racine, WI AMA# 809291
Joined Nov 2003
Sounds like your CG Location is off.
when you fly the plane, cut the power, if the nose lifts your CG is too far back. If the nose dips down, the CG is too far forward, just move it back.
Tom
RCParkflyer is offline Find More Posts by RCParkflyer
Old Dec 06, 2005, 11:26 AM
ViruTs
Denver
Joined Mar 2004
Thanks Tom, I will try to check the cg again.
One question did anyone try to make an actual airfoiled wing for that plan
The few times I was able to fly it the airplane flew only with full gas .
Old Dec 06, 2005, 11:32 AM
bigglesjets
bigglesjets's Avatar
Notts UK
Joined Jul 2005
Hi submarco
I dont think it's the wing profile mate, I have the f!5 and F18 and they dont have this problem.I would agree with Tom check your CG position try bringing it forward 1/2" and adjust from there.check your motor thrust line make sure its not pointed up
good luck
Al
bigglesjets is offline Find More Posts by bigglesjets
Old Dec 06, 2005, 11:48 AM
It should be I was sad :)
Bournemouth, Dorset, UK
Joined Jan 2005
May also be your weight, what are you useing??
im-sad is offline Find More Posts by im-sad
Old Dec 06, 2005, 11:51 AM
ViruTs
Denver
Joined Mar 2004
Al and Tom,
first of all , just to make sure, where is located your f'18 cg?
secondly yap, actually I may have some thrust line issue, beause I made a mod inorder to mount my outrunner, the thrust line shoul be neutral or what?
Old Dec 06, 2005, 11:52 AM
Joined Nov 2003
It really doesn't need an airfoil, just round off the leading edge. The Lift on the jet is accomplished by the angle of the wing in flight. The slower you go the higher the nose should be, so you get a "High alpha" slow flight. You should be able to fly level at half throttle. Once you nail down the CG it should be a lot easier to fly.
Here is a High Alpha Demo video from 3D Foamy.
http://3dfoamy.com/Videos/f18_Catch.wmv
Tom
Old Dec 06, 2005, 11:56 AM
ViruTs
Denver
Joined Mar 2004
I am-sad ,
my f-18 is around 16oz and all three motor, at least in static test seemed to provide more than 1=1 thrust/weight.
Old Dec 06, 2005, 11:58 AM
ViruTs
Denver
Joined Mar 2004
Tom
what about the motor thrust line?
Old Dec 06, 2005, 12:08 PM
bigglesjets
Notts UK
Joined Jul 2005
Hi Submarco
Ive just measured my f18 and the CG is 4" from the leading edge in the center
The thrust line should be straight ,inline with the wing line or 0 degree.
I dont suppose it matters if you add slight down thrust not sure about up thrust
Cg 5.25" from rear line of wing
Al
Old Dec 06, 2005, 12:11 PM
ViruTs
Denver
Joined Mar 2004
cheers mate
Old Dec 06, 2005, 12:18 PM
ViruTs
Denver
Joined Mar 2004
Hold on!
You said 4 inches form leading edge, in the center.
By the center did you mean at longest chord, in teh center of the fuselage?
Because if that was the case my cg was off of almost 2 inches!!!!!!!!!!!! way to forward. Jeeze, that would explain the tenbdencies to go down and not gaining height.
Old Dec 06, 2005, 12:34 PM
bigglesjets
Notts UK
Joined Jul 2005
Hi Submarco
Lets get this right
5.25 inches from the wing trailing edge forward
Al
Old Dec 06, 2005, 12:50 PM
ViruTs
Denver
Joined Mar 2004
thanks,
I will check again
Old Dec 06, 2005, 01:08 PM
ViruTs
Denver
Joined Mar 2004
OK , 5.25 from Te going forward. Well, well I was off of 1.25 inches,still way forward.
Thank you very much for the clue.
I actually know what happened, when I was investiganting about teh Hornet I read some post form Steve Shumate warning pretty hard to move the cg some forward (I think it was 1/3 inch)but I must have down loaded the plans already updated with the new cg and then move it even forward thinking to follow Steve`s sugestion.
I give up on Bluecor... Not available in Canada... NetForce2K Foamies (Kits) 32 Sep 28, 2009 08:09 PM
Help! Just about to give up on helis. please fix my uncontrolable tail wag delamar Micro Helis 23 May 27, 2006 08:58 AM
Help! help me please, about to give up on RC flying xoon Parkflyers 60 Feb 03, 2005 06:18 PM
Should I give up on the FMA Razor??? soholingo Foamies (Kits) 20 Jul 22, 2002 05:28 PM
Help READY TO GIVE UP ON LITESTIK brudford Parkflyers 21 Apr 26, 2002 02:05 PM
