Old May 31, 2002, 10:35 AM
alvincfi is offline
Find More Posts by alvincfi
alvincfi's Avatar
Joined May 2002
What kind of paint for Tiger Moth?
Well I finnally picked up the Tiger Moth from the LHS. After reading all the posts and looking at some of the mod's, I've decided to paint the TM in the colors of the one at the Old Rhinebeck Aerodrome.
What kind/brand of spraypaints can I use that won't eat the foam?
Alvin
alvincfi is offline Find More Posts by alvincfi
Old May 31, 2002, 11:44 AM
RookieOne is offline
Find More Posts by RookieOne
Michele Somaschini, Spain
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
I used thinned TAMIYA acrilics for my Cub.
Covers OK and dryes very fast. Easy to clean (alcohol or water).
Use an airbrush for better covering. You'll save weight too.
RookieOne is offline Find More Posts by RookieOne
Old May 31, 2002, 01:05 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Testor Model Master is foam safe. Also the little cans of acrylic Krylon. Check the can.
The testors will eat the foam is applied heavy. Use light coats.
BC
Basketcase is offline Find More Posts by Basketcase
Old May 31, 2002, 05:17 PM
Darren Hintze is offline
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
The Krylons work but some of the metalics can eat some types of foam.
I think they are all safe for the TM's foam as I tried a little Chrome on part of an old TM before spraying my MiniMax with it.
The Chrome did attack an older expanded foam model I had. Others have been no problem.
Darren Hintze is offline Find More Posts by Darren Hintze
Old May 31, 2002, 06:58 PM
bblaske is offline
Find More Posts by bblaske
Franklin, NC, USA
Joined Apr 2001
Paint
Testors has foam paint that works; however, my son and I both went too fancy in painting our TM's and made them too heavy. Don't get carried away with adding stuff. Just fly it.
bob
bblaske is offline Find More Posts by bblaske
Old May 31, 2002, 07:06 PM
2wise4gas is offline
Find More Posts by 2wise4gas
Wpg, Mb, Great White North
Joined Jan 2002
Stock sucks!
I used Humbrol Acrylics thinned with a bit o' water and airbrushed on. Total paint weight was less than 9 grams. (yeah, I measured it before and after!)
Ok, ok, so corey painted it but it was my idea...
2wise4gas is offline Find More Posts by 2wise4gas
Old May 31, 2002, 08:01 PM
alvincfi is offline
alvincfi's Avatar
Joined May 2002
Wow!
DAAAMN! that is some paint job 2wise4gas.
I found some tamyia acrylic paint today, couldn't find the maroon and silver I liked so I'm doing it in Camo!! I saw a pic of one with green and brown camo with a yellow bottom on the fuse, I wish I could remember where I saw it... I didn't know you could thin the acrylic paint with water. I bought the acrylic thinner, oh well.
Old Jun 01, 2002, 09:34 PM
Joined Jan 2002
Thanks! I didn't know there was such stuff as acrylic thinner...
Old Jun 01, 2002, 10:01 PM
BamaFly is offline
Find More Posts by BamaFly
Florence, Alabama
Joined May 2002
Hey guys let me offer some suggestions. I come from a scale modeling background (you know, plastic models) so I have sprayed a little Tamiya in my time. If you will thin it with Isopropyl Alcohol when you airbrush, it will work great. Also remember that "flat" paints will give you much better coverage. If you love that gloss look, just airbrush your plane with Future floor wax. Thin it with a little water, and remember LIGHT coats, and it will really shine up your model. Keep your airbrush moving to avoid those dreaded puddles, and remember to keep it light so not to add weight. Also a tip for all of you using Tamiya acrylics, Windex window cleaner will clean up your airbrush lickity split, but keep it away from your model, it will also ruin that paint job. Happy modeling.........
Eddie Krieger
"There are no crashes, just hard landings"
BamaFly is offline Find More Posts by BamaFly
Old Jun 02, 2002, 12:48 AM
alvincfi is offline
alvincfi's Avatar
Joined May 2002
Tamyia paints
Well I finished painting the TM today. The tamyia paints arent too bad. I think that the tamyia acrylic thinner is nothing more than isopropyl alcohol. At least thats what it smells like. I can't believe I payed $7 for that little bottle. Oh well, live and learn.. anyway I'm posting a pic of it. It's my first attempt at painting foam in camo paint.
I'll post another when its all done and ready to fly.
Good paint for Tiger Moth? 1987tc Parkflyers 16 Aug 20, 2007 08:35 PM
What kind of paint for Stryker? ercman Foamies (Kits) 1 Oct 29, 2004 09:38 PM
What li poly for tiger moth? robman Parkflyers 3 Aug 04, 2004 06:25 PM
What is the stock motor for the Tiger Moth? DennisG Parkflyers 10 Jun 09, 2003 09:19 PM
What kind of paint for pop bottles? MtnGoat Foamies (Kits) 7 Jan 18, 2003 04:50 AM
