Old Dec 05, 2005, 08:36 PM
xFxLxYxExR is offline
Find More Posts by xFxLxYxExR
ParkFlyer
xFxLxYxExR's Avatar
Joined Nov 2005
What do you think?(pleas reply)
Hey, I put pleas reply not becuase i thought u wouldnt answer, but becuase i would like to hear everyones oppions. Ok so heres teh question. What would be the best brushless set-up for 150$ on a GWS formosa. Motor, Esc and Li-po battery. Thanks alout for your help and time!
....XF
xFxLxYxExR is offline Find More Posts by xFxLxYxExR
Old Dec 05, 2005, 08:49 PM
ParkFlyer
xFxLxYxExR's Avatar
Joined Nov 2005
Also, can you list the specs with the proper prop? Like thrust, speed ect...
Old Dec 05, 2005, 09:13 PM
AZcrashpro is offline
Find More Posts by AZcrashpro
AZcrashpro's Avatar
Mesa Falcon Fld, Arizona, United States
Joined May 2004
I would go with this motor and a 10X4.7 APC prop to start.
http://bmkdesigns.net/product_info.p...products_id=61
I would use the TP 1320 3-Cell.
Per Motocalc it will pull 11.3 amps and 24 ounces of thrust static.
A 10X7 APC prop would be 13.7 amps and 23.5 ounces of thrust.
AZcrashpro is offline Find More Posts by AZcrashpro
Old Dec 06, 2005, 09:04 PM
ParkFlyer
xFxLxYxExR's Avatar
Joined Nov 2005
bump
Old Dec 06, 2005, 09:58 PM
PlaneCrazee is offline
Find More Posts by PlaneCrazee
Burner!!
PlaneCrazee's Avatar
United States, AR, Sherwood
Joined Jun 2005
CC Pheonix 25(3amp bec) Gobrusless triple with 7 turns of double stranded 24 ga. terminated wye. Tanic 1080 3s Start with a 9X6 APC and check the amps. Set it for about 150 amps.
This is just a guess, I have never gotten around to buying a Formosa. It's on my list, but this is where I would start... and then retracts, and glassing...and
PlaneCrazee is offline Find More Posts by PlaneCrazee
Old Dec 06, 2005, 10:08 PM
ParkFlyer
xFxLxYxExR's Avatar
Joined Nov 2005
lol, the list will never end. THeres always somthing i want for this hobby
Old Dec 06, 2005, 10:43 PM
racer78bu is offline
Find More Posts by racer78bu
Racer78Bu
racer78bu's Avatar
Birmingham, Alabama, United States
Joined Jun 2004
Check out Vinnie at http://justgofly.com/
My dad runs the 400t w/8x4 prop and a 1500 mah battery. 9 amps
This setup is a good sport pattern flyer it'll hover it at full throttle (16.5 oz) but the battery is cool and you get good 12minute aggressive flights.
Vinnie has some more ballistic setups for a formosa that'll easily fit in your budget. You will not be sorry.
racer78bu is offline Find More Posts by racer78bu
What do you think about this tape for zagi's funflyer Foamies (Kits) 2 May 17, 2016 08:14 PM
pay pal system,What do you think of it?? KOMET 44 Electric Plane Talk 17 Jan 28, 2008 04:23 PM
What do you think of pop-up ads? jbourke Life, The Universe, and Politics 41 Jul 07, 2007 02:56 AM
Plan ideas - What do you think? PETERRAKE Scale Kit/Scratch Built 27 Sep 19, 2001 01:20 PM
Twin Star with 11" props?! What do you think? Bill Glover Foamies (Kits) 11 Sep 05, 2001 08:44 AM
