| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
Hobby Lobby's Telink Brand Convair XFY1 Pogo VTO Aircraft Review
According to the history, The U.S.Navy's Bureau of Aeronautics in 1951, after having ordered two prototypes of the revolutionary supersonic XF2Y-l seaplane, issued a Request for Proposals for a single-seat vertical take-off and landing fighter which could be used to escort convoys, based on cargo vessels which did not have flight decks. The U.S.Navy accepted Convair's submission and in March 1951 ordered the XFY-I as well as placing an order for Lockheed's project, which was designated XFV-1 (q.v.). In the first complete experimental flight: the aircraft achieved vertical take-off, subsequently carried out the transition from vertical to horizontal flight and flew normally for about 20 minutes, before lowering itself gently to the ground. Skeets Coleman was very enthusiastic about the XFY-I and his verdict was that he found it easier to handle and more maneuverable than any other plane he had ever flown. Before the test program was halted, however, the XFY-I flew for a total of 40 hours and earned itself the distinction of being the first vertical take-off and landing aircraft to fly successfully in the history of aviation.
Now, Hobby Lobby has brought this most unique full scale experimental aircraft to life as an indoor/outdoor foamie, and what a fun, exciting, attention-getting bird she is...and...an AWESOME hovering trainer to boot!!!
AssemblyWhile the instructions are pretty basic, they are more than adequate for an intermediate modeler to build this aircraft. As this is not a beginner's airplane, I won't belabor every step. Instead, here are some highlights and stumbling blocks...
Using Pogo to Learn to Hover
This aircraft is really ideal for a pilot learning to hover. The hardest challenge to learning to hover is managing to pull off a good transition from forward flight, at an altitude and position the pilot can clearly see and determine what the model is doing. Along comes the Pogo – a VTOL aircraft – so that the model simply transitions from sitting on its tail to hovering inches or feet above the ground, without any forward flight transitions to worry about. The pogo has a mild pull to the belly as it breaks the ground and tries to clear ground effect. The pilot will need to be ready to apply a bit of positive elevator to keep her upright during this transition. Learning to hover is best done outdoors with ABSOLUTELY no wind. Even 5 mph is going to make this much harder than it need be. The pogo will hover nicely indoors or out, but attempting it in even the mildest winds is not for the newcomer. Even though the pogo hovers with ease, for someone whose never tried before, hovering inches off the ground, and/or within feet in front of himself will be intimidating. Let's look at, step by step, how to go from never having hovered before to using the Pogo's VTOL skills to the max!
Vertical Take-Offs
Once you can hover her consistently and comfortably at any height you’ve chosen, are transitioning to forward flight with ease, and really feel you know the model well, its time to think about VTOL landings. VTOL landings are A LOT more challenging than VTOL take-offs, so be patient!
Vertical Landings
The first step to learning to vertical land is to, well, “pogo” with the Pogo. Do brief hops, just a foot or so off the ground. Up – hang – back to the tail on the ground. Do this until you can do so comfortably. Now try a little higher. Concentrate on getting it to hover, and then ease back down to the ground.
Now that you can transition from forward flight to a hover, its time to put all the pieces together – take off VTOL, hang, push to forward flight; fly around and do your favorite stunts. When you’re ready, use a harrier or traditional approach to come back to a hover as low to the ground as you can. Get a good, firm hover in place, and then ease out of the power and back down until she’s standing on her tail again!
Other Notes:
I chose to wait to secure the servos until after I made the pushrods and attached the pushrods to the control horns. The lower rudder control horn location wasn't pre-printed on the foam either. The Pogo is recommended with a Hitec Laser 4 as a quality radio that offers an inexpensive choice that includes elevon mixing. Later, I would wish I'd used my 9C so I could mix all 4 surfaces as ailerons for stronger 3D performance. The rudder servos had to be y-ed together with this radio system. I replaced the stock “heavy” antenna on the Micro 055 RX with a Lightenna from E Flight Products. The CG range was listed as 275-283mm. I was happy to find that the plane balanced at around 279 without the battery. This places the battery right on the CG making it possible to use different weight batteries without having to have multiple locations. 2 minutes
Flying!
Take-Offs:The Pogo cannot take-off conventionally; however, it hand launches easily. That said, the pogo VTOLs so well that I actually found it easier to do a vertical take-off than to hand launch the model!
Landings:
The Pogo will land conventionally, counting on the wire skids to protect the motor and the extra rigidity to keep the front end together. The prop could really use a prop saver here. It really does need to come in slowly – a harrier landing is ideal if you’re not going to land vertically. The side-bar covers in depth learning how to do VTOLs. The Pogo really shines as far as landing vertically, as long as there is absolutely no wind. Inside, where I had truly ZERO wind, vertical landings were easy. Outdoors, in roughly a 5MPH wind, I expected to be able to handle it as well, but with every attempt the wind blew it over before, during or after it touched down.
Windy Conditions:Wind and hovering the Pogo DO NOT mix. Even a 5MPH blew the pogo around in a hover, and it could not take off or land vertically. Forward flight in wind was fine.
Forward flight:The Pogo is no trainer, but it flies comfortably in normal forward flight. It isn’t twitchy like a typical 3D aircraft. Loops, inside and outside, are easy. Rolls were more sluggish than I’d hoped. I would’ve liked the rudders to be mixed in to work as ailerons as well, but I didn’t have the Pogo set up on my computer radio. It didn’t give any hint of wanting to snap out at any time.
Knife-edge:The Pogo LOVES to be knife edge. It has a slight pull to the belly, which mixing or a CG adjustment could’ve easily resolved. It has plenty of power and authority for high alpha knife edge – you can even transition from high alpha knife edge slowed to a hangar without any gain in altitude! What fun!
3D aerobatics:
The Pogo is capable of the most common 3D aerobatics. The elevator was too sluggish for non-hovering maneuvers. I would’ve liked more aileron response. The CG was fantastic for hovering, but was too far forward for really performing most other 3D aerobatics.
Stalls:I didn’t attempt any spins. Stall entries, however, were very conventional, with it just dropping the nose, without any sign of dropping either wing or any other unpleasant behaviors.
Flight Video!
Conclusion:For every pilot who has ever wanted a VTOL aircraft, Hobby Lobby has truly filled the bill here. For every pilot wanting to learn to hover, but frustrated with twitchy 3D aircraft, or worried about breaking their planes, again Hobby Lobby has filled this niche. Even as a very experienced 3D pilot, both I and a friend who flew it indoors found the Pogo to be a lot of fun, and it certainly drew a lot of attention! Hobby Lobby has quite a winner here.
Hits:
Misses:
Thread Tools |
#2 |
My POGO flys just like yours,but i fly out side.People always stop,and watch me fly the bird. DAVE
#3 |
"Have Glue - Will Travel"
AnnMarie & Mike,
A very nice review, and the video was excellent also! |
#4 |
killickb
My version has the one servo driving both rudders by using adjacent holes on the servo arm and different lengths on the rudder horns to compensate, do the later kits suggest two rudder servos? Is a neat flyer though with any wind it is hard to stop from just tipping over on throttle up and before lift off --- seems as though the prop wash blows it over.
#5 |
Fun Manager
Kill,
We built ours as recommended in our packaging. Sweet, yes ours was the same outside. It blew over in even mild winds, especially if trying to land vertically. what a blast indoors though, and outside on calm days!!! sure drew a lot of attention. |
#6 |
i just recieved mine
Man i ordered it on the 22nd of febuary it arrived this morning
![]() (thats what living in South Africa does for you lol, i even paid the same in shipping as i did for the plane lol) Im going to build it this weekend. tell me any advise please Will this fly in slight breezes even if its not for hovering? any tips would be appreciated aswell i cant wait to fly,. |
#7 |
Fun Manager
Enjoy! It flies fine in slight breezes, but is very hard to land b/c it blows over.
lots of fun, enjoy!!! |
#8 |
ALMOST FINISHED BUILDING? tell me do you guys not think this is not very taught, in strenght? should i put carbon rods on the sides?
Servos? |
#9 |
Fun Manager
WLS, mine was pretty much bulletproof. wait until it is all tied together, mine did great. no worries at all. used the servos HL recommended.
#10 |
Ok got my POGO in the air this morning.
Its a bit to nose heavy? how far back are you guys putting your battery? i had to add almost 30 grams of weight to the tail? which has a huge effect on performance. very cool int he sky though. |
#11 |
Convair XFY1 Pogo
I noticed that this Thread is several years old, but I am very interested in this aircraft because my father worked at Convair from 1940 to 1975. He was a design engineer. I remember seeing the Pogo on the news in San Diego when I was a boy. I also remember seeing it parked by a hangar just off Harbor Drive. I was about 10 or 11 years old. I would like to build this model if it is still available. Recently I found that contra-rotating propeller systems are available using 2 electric motors. These are available in different sizes. Would it be feasible to mount one of these systems on this model? It would obviously be heavier, but would have more power and would have the advantage of not having to use ailerons to counter the motor's torque. In short, it would be more like the real one. Has anyone tried this yet? What do some of you experts think of this idea? Thanks, Steve
| Thread Tools | |
| Article Hobby Lobby's Alfa Brand Wildcat ARF Review | pda4you | Ezonemag Archive | 21 | Nov 03, 2007 07:17 AM |
| Article Hobby Lobby's Nikitis Brand Rebel Bipe Foamie 3D ARF Review | spaulj | Ezonemag Archive | 1 | Dec 03, 2005 04:23 PM |
| Article Hobby Lobby's Scorpio Brand Raven (Uberall-Powered) ARF Review | kepople | Ezonemag Archive | 1 | Sep 14, 2005 02:50 PM |
| Hobby Lobby's AeroCraft Pogo review posted! | dave_lilley | Electric Plane Talk | 0 | Sep 30, 2001 11:07 PM |
| Hobby Lobby's AeroCraft Pogo review posted! | dave_lilley | Site Chat | 0 | Sep 30, 2001 11:07 PM |
