Old Dec 05, 2005, 03:26 PM
picard1 is offline
Find More Posts by picard1
Mount Shasta Rep, California, United States
Joined Sep 2004
Motor for a Wemotec micro fan?
I would like to find a motor with a 2mm shaft for my wemotec micro fan that would give me 13-18oz of thrust.
Any suggestions?
mike
picard1 is offline Find More Posts by picard1
Old Dec 05, 2005, 03:35 PM
Chris T is offline
Find More Posts by Chris T
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Why are you concerned about the shaft. From what I have heard, get a razor 300 and a fitting mount for 3mm shaft (I think that motor has a 3mm axis)
Chris
Chris T is offline Find More Posts by Chris T
Old Dec 05, 2005, 03:37 PM
Chris T is offline
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
wait a second. 18 ounces thrust. Maybe wait for somebody else to reply. That is quite a lot and I suppose that motor would also have a larger shaft diameter...
Chris
Old Dec 05, 2005, 03:45 PM
picard1 is offline
Joined Sep 2004
Chris,
I'm not familar with the razor motors which model would you recomend?
I'm thinking about putting two fans in a small jet that shoud weigh in around 22-26 oz and would like a thrust ratio greater than 1:1
Old Dec 05, 2005, 03:48 PM
picard1 is offline
Joined Sep 2004
Chris,
I just did a search on Razor motors and found the website. He is no longer in buisness.
Old Dec 05, 2005, 04:12 PM
Sal C is offline
Find More Posts by Sal C
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
I use a Hyperion Y22s 6000 kv with 3s lipos and measured about 12.5 ozs of thrust. Go with the Y22L 5000 kv and I'm sure your get at least 15+...
Here's a thrust test on a 11 oz AUW plane: http://www.salc.rchomepage.com/videos/BanditThrust.wmv
Here's a video of a flight: http://www.salc.rchomepage.com/videos/Flight2.wmv
Sal C is offline Find More Posts by Sal C
Old Dec 05, 2005, 04:36 PM
stacker is online now
Find More Posts by stacker
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
Sal,
That looks great, what kind of amps are you pulling with that setup?
Stacker
stacker is online now Find More Posts by stacker
Old Dec 05, 2005, 05:09 PM
Speed is Life is offline
Find More Posts by Speed is Life
Speed is Life's Avatar
FREE Gene!!! Get Banned!!!
Joined Jun 2005
I use a MiniAC 12/15/16 in an Alfa Mig with good results on 4s LiPo, and got interested enough to run MotoCalc to see what "picard1" might be looking at using the MiniAC in a MicroFan.
The MiniAC motors have 2.3mm shafts and would fit into the MicroFan.
The "problem" I see (using MotoCalc) is that to get 18oz of thrust you will need upwards of 70,000rpm/400watts to do it. The MiniAC 12/15/12 would do this at circa 23Amps on a 5s LiPo. No sweat there.
Would the MicroFan be happy or safe at this RPM? Hmmm.......Don't know.........stand back. Kevlar fan housing anyone?
Would the motor (any motor) last at that RPM? Hmmmm.......Don't know
I'll bet it would surely sound like a hoover on methamphetamine!
Maybe Roccobro wants to branch out to investigate.
-Mike
Speed is Life is offline Find More Posts by Speed is Life
Old Dec 05, 2005, 05:11 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
If you are a little creative, check out my thread, I use a Mega 16/7/3 with 3s TP 2100s and get over 17oz of thrust with a good inlet ring. I have This setup in my SuperBandit and it goes like stink This Motor is rated for 30 amps I pull 27 WOT and it hardly gets luke warm. I got over 53,000 rpm with the Prolites.
http://www.rcgroups.com/forums/showthread.php?t=428975
power is offline Find More Posts by power
Old Dec 05, 2005, 08:53 PM
Sal C is offline
Giddy up!
Sal C's Avatar
Woodridge, Illinois
Joined May 2000
Originally Posted by stacker
Sal,
Stacker
23-26...
Old Dec 05, 2005, 11:34 PM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
I just got done testing a "new" Himax/Wemo microfan combo from Randy at Dynamo Electrics. On 3s it pulled 13A max on TP g2 1900's. On 4s PQ 1800's it pulled max of 20A. I'll make a thread with the info I got and post the link here when done.
Mike's (Speed and Power )- I am interested in the longevity of the motors at these rpms as I was reading 56k on these 4s runs and almost 70k on the Alfa fan stuff.
Justin
EDIT:
http://www.rcgroups.com/forums/showthread.php?t=449469
roccobro is offline Find More Posts by roccobro
Old Dec 06, 2005, 02:18 AM
Fiasco is offline
Find More Posts by Fiasco
Future NFL Champs
Fiasco's Avatar
High Ridge, Mo USA
Joined May 2002
The Razor 2500 on 5S with a heatsink is a very powerfull microfan combination.
Razor may temporarily be shut down but those little motors are incredible. I have 5 razor 2500's.
Fiasco is offline Find More Posts by Fiasco
Question Out of these 2 motors whats better for a wemotec micro fan? lavochkin Foamy EDFs 6 Aug 10, 2007 09:20 PM
WTB: 2.3mm adapter for Wemotec Micro Fan turbojoe Aircraft - Electric - Airplanes (FS/W) 2 Jan 31, 2005 06:42 PM
Which motor for the Wemotec Midi Fan?? mrbaseballny Power Systems 4 Oct 20, 2004 02:04 PM
Rotor Pitch for KP-44, Wemotec Micro Fan, Vasa 55 nolasco Electric Ducted Fan Jet Talk 3 Jun 19, 2002 06:25 PM
Best Motor for Wemotec Micro-fan Gordon Electric Ducted Fan Jet Talk 16 Jun 10, 2001 10:23 PM
